Salta al contenuto principale
How to Repaste a Laptop
Carsten Frauenheim
Carsten Frauenheim
Ultimo aggiornamento il 18 lug 2024
10 - 30 minuti
Facile
Guida In Evidenza
Introduzione
Vai al passo 1
Use this guide to reapply thermal paste on a laptop.
This is a general guide—the exact procedure for your laptop will differ from these instructions—but the process should be the same. To reapply thermal paste in a phone, follow this guide.
Thermal paste is an essential part of our devices, responsible for conducting heat away from the processor and into the heat sink, keeping our devices cool and happy. Reassembling a laptop, tablet, phone, or PC without reapplying thermal paste will cause the processor to overheat, possibly resulting in permanent damage.
Remember: follow general electrostatic discharge (ESD) safety procedures when disassembling your device.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Repaste a Laptop, Power down and prepare your laptop: passo 1, immagine 1 di 1
    • Completely power off and unplug your laptop before you start.
    • Close the display and flip the entire laptop upside-down.
  2. How to Repaste a Laptop, Expose any hidden screws: passo 2, immagine 1 di 2 How to Repaste a Laptop, Expose any hidden screws: passo 2, immagine 2 di 2
    • If your laptop has hidden screws underneath rubber feet, use the tip of a spudger or an opening pick to remove them.
    • If any feet are adhered, it might help to lightly heat them with an iOpener or a hair dryer to soften the adhesive underneath.
  3. How to Repaste a Laptop, Unfasten the back cover: passo 3, immagine 1 di 2 How to Repaste a Laptop, Unfasten the back cover: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $31.41
    • Use a screwdriver to remove the screws that secure the back cover.
    • Every laptop is different, and the types of fasteners used will vary.
    • Use the most snug-fitting screwdriver or bit size for your laptop.
    • A screwdriver or bit that's either too small or too big can strip the heads of screws. To extract a stripped screw, follow this guide.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  4. How to Repaste a Laptop, Pry up the back cover: passo 4, immagine 1 di 2 How to Repaste a Laptop, Pry up the back cover: passo 4, immagine 2 di 2
    Suction Handle
    $2.99
    • Use the flat end of a spudger or an opening pick to pry up the back cover.
    • On laptops with extra tight back covers, a suction handle is a useful tool to help create a gap big enough to insert an opening pick.
    • Work your way around the whole perimeter of the laptop, twisting your tool as you go to unclip the back cover.
    • Most laptops use plastic clips in conjunction with screws to keep the back cover secured in place.
  5. How to Repaste a Laptop, Remove the back cover: passo 5, immagine 1 di 2 How to Repaste a Laptop, Remove the back cover: passo 5, immagine 2 di 2
    • Once all of the clips have been disengaged, lift the back cover up and away from the laptop to remove it.
    • Lift slowly and carefully, checking that no cables are attached to the back cover before you fully remove it.
  6. How to Repaste a Laptop, Disconnect the battery: passo 6, immagine 1 di 3 How to Repaste a Laptop, Disconnect the battery: passo 6, immagine 2 di 3 How to Repaste a Laptop, Disconnect the battery: passo 6, immagine 3 di 3
    • Don't skip this step. Disconnecting your laptop's battery is a vital safety step before any repair.
    • Use the tip of a spudger or your finger to disconnect your laptop's battery.
    • All battery connectors are different. Some slot into place, some press and snap into place. Some have locking mechanisms, and some have pull-tabs.
    • If it's unclear how to safely disconnect your battery, consult your laptop's manual.
  7. How to Repaste a Laptop, Unfasten the heat sink: passo 7, immagine 1 di 3 How to Repaste a Laptop, Unfasten the heat sink: passo 7, immagine 2 di 3 How to Repaste a Laptop, Unfasten the heat sink: passo 7, immagine 3 di 3
    • Some laptop heat sinks and fans connect as one assembly, and some have separate fans.
    • Disconnect, unscrew, and remove any fans that sit atop your laptop's heatsink.
    • Use a screwdriver to remove the screws securing the heatsink to the chassis.
    • During reassembly:
    • Tighten the heat sink screws around the CPU or GPU in an "X" pattern.
  8. How to Repaste a Laptop, Remove the heat sink: passo 8, immagine 1 di 2 How to Repaste a Laptop, Remove the heat sink: passo 8, immagine 2 di 2
    • Lift the heat sink away from the motherboard to remove it.
    • If the heat sink feels stuck, check for heat pipes caught underneath case overhangs, screws you forgot to remove, or stickers or tape.
    • The existing thermal paste may still be tacky. It might help to gently wiggle the heat sink side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes may be susceptible to bending or creasing.
  9. How to Repaste a Laptop, Clean off the old thermal paste from the heat sink: passo 9, immagine 1 di 2 How to Repaste a Laptop, Clean off the old thermal paste from the heat sink: passo 9, immagine 2 di 2
    • Before applying new thermal paste, you must first remove any old thermal paste and leftover residue from both the processor surface and the heat sink.
    • Use the flat end of a spudger to scrape as much solidified thermal paste off of the heat sink as possible.
    • Scrape gently. Avoid gouging or poking the copper contact surface.
  10. How to Repaste a Laptop: passo 10, immagine 1 di 2 How to Repaste a Laptop: passo 10, immagine 2 di 2
    Arctic Silver ArctiClean
    $9.99
    • Use a coffee filter or a lint-free cloth and a couple drops of isopropyl alcohol (a.k.a. IPA, >90% concentration) to clean the remaining thermal paste residue off the thermal contact surface of your heat sink.
    • Alternatively, you can use a dedicated cleaning agent such as Arctic's ArctiClean or isopropyl alcohol swaps or wipes.
    • Once the surface is mostly clean, use another, fresh piece of coffee filter or lint-free cloth with more IPA to further remove any oils or extra residue.
    • Avoid touching the heat sink's contact surface once it's clean. Small dust particles or even oils from a fingerprint can reduce the effectiveness of the thermal paste application.
    • Allow the heat sink to dry completely.
  11. How to Repaste a Laptop, Clean off the old thermal paste from the processor: passo 11, immagine 1 di 1
    • Don't use any metal objects or tools for this step, as they could mar the fragile, exposed processor.
    • Use the flat end of a plastic spudger or the edge of an old credit card to remove any large chunks of solidified thermal paste from the surface of the processor.
    • Don't use excess force here—you don't want to gouge the surface.
    • Be careful working near any small soldered components on the motherboard surrounding the chip.
  12. How to Repaste a Laptop: passo 12, immagine 1 di 3 How to Repaste a Laptop: passo 12, immagine 2 di 3 How to Repaste a Laptop: passo 12, immagine 3 di 3
    $9.99
    • Like with the heat sink, use a coffee filter or a lint-free cloth and a couple drops of >90% isopropyl alcohol to clean the remaining thermal paste residue off the processor surface.
    • You can alternatively use a dedicated cleaning agent such as Arctic's ArctiClean or isopropyl alcohol swaps or wipes for the processor as well.
    • Avoid touching the processor during this procedure. Small dust particles or oils from fingerprints can reduce the effectiveness of the thermal paste application or otherwise harm your chip.
    • Allow the processor to dry completely.
  13. How to Repaste a Laptop, Apply new thermal paste: passo 13, immagine 1 di 1
    • Use your tube of thermal paste to apply a small drop to the middle of the processor die, about the size of a grain of rice.
    • The mounting pressure from reinstalling the heat sink will usually adequately spread the thermal paste out, but some applications recommend manually spreading the thermal paste. Follow this guide for how to do that.
    • If you accidentally get a little bit of thermal paste on the green PCB surface surrounding the processor die, don't worry! It won't cause any problems.
    • You don't need to apply any thermal paste to the heat sink—only the processor.
    • The processor is now ready for the heat sink to be reinstalled.
    • Return to Step 8 and follow the instructions in reverse order to reassemble your laptop.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
Altre 9 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Carsten Frauenheim
Membro da: 03/10/20
145.708 Reputazione
424 Guide realizzate
iFixit Membro di iFixit
Staff
119 Membri
21.687 Guide realizzate
3Commenti sulla guida
i cant unscrew the screws in my heatsink and accidentally loose them i dont want to put pressure the board i might break it any way to fix and unscrew them??
Shiraiki - Replica
muss ich die Capacitors und den Vram auch repasten wenn ich die / den Heatsink entferne?
finde keine klare antwort im internet dazu
Alibi - Replica
Alibi, ich verwende Online-Übersetzung, daher ist mein Deutsch möglicherweise nicht das Beste. In den meisten Anwendungen verwenden diese Komponenten Wärmeleitpads anstelle von Wärmeleitpaste. Wenn sie gerissen oder gerissen sind, müssen sie beim erneuten Einfügen möglicherweise auch ersetzt werden, wenn Sie die ursprüngliche Dicke erreichen können.
Carsten Frauenheim -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 61
Ultimi 7 Giorni: 438
Ultimi 30 Giorni: 1,737
Tutti i Tempi: 43,453
