DualSense Edge Back Buttons Replacement
Introduzione
Vai al passo 1Follow this guide to replace the back buttons in your Sony DualSense Edge controller.
Cosa ti serve
Strumenti
Mostra di più…
Place the controller on a work surface with the joysticks facing down.
Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
Lift the controller up, leaving the front trim on the table.
Flip the controller over so the joysticks are facing up.
Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
Slide the joystick out from its slot.
Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
Slide the opening pick towards the bottom of the grip to release the clips.
Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
Slide the opening pick around the edge of the rear trim to release the clips.
Slide the opening along the edge of the trim on the other grip.
Once all clips are released, remove the trim.
Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
Use the spudger to pry out the L1 button.
Repeat this process to remove the R1 button.
Rotate the controller so the grips are pointing towards you.
Use a pair of angled tweezers to lift the right end of the release bar spring off of the white post.
Use a pair of tweezers or your fingers to slide the release bar to the left.
Slide the release bar away from the controller to remove it.
Remove the nine screws securing the rear case:
Seven 6.4 mm‑long screws
Two 10.5 mm‑long screws
Insert the point an opening pick in the gap along the outside edge of one of the controller grips, near the bottom.
Pry with the opening pick to separate the rear case from the front case by releasing the clips that hold them together.
Continue prying along the edge of the controller until one side is separated.
Hold the main body of the controller with one hand.
Lift the rear case with your other hand. It should lift at an angle.
Pushing slightly towards the L and R buttons, lift the rear case off of the controller and remove it.
Use a pair of tweezers or your fingers to lift the cover from the controller.
Slide the flat end of the cover under the plastic tab in the rear case.
Lift the battery and move it to the right, so the connector underneath the battery is accessible.
Use the flat end of a spudger to pry up the low profile connector.
Remove the battery.
While holding the back button switch down, remove the two 6.4 mm‑long screws securing the back button bracket.
Use a pair of tweezers or your fingers to lift and remove the back button switch, being careful not to lose the plastic covers on the sides of the switch.
18 Commenti
Hey! Great video! By the way, any luck finding a source to buy the black piece you pick up at 8:07 in the video? I was able to glue them back in place, but I know that will just be temporary.
Same here,where can we buy that black piece
I also need that black piece, if someone knows where to buy it please let me know!
extremrate is about to release this fixing piece
I also need this black piece :(
Me too, need this piece as well.
I am looking for taht same piece
Folks, I heard that extremrate is about to release this fixing piece. Can't wait to fix my back buttons.
Can you fix playstation edge controller back buttons mine just stopped working and only had it since Christmas
I need the black piece too. Please let me know where to buy it!
Hi, any Idea where to buy the PCB for the back paddles, my left won't click anymore and although functional I reckon it needs replacing.
Is there a link for the replacement button?
