Salta al contenuto principale
iPhone XR LCD and Digitizer Replacement
Cosa ti serve
  1. iPhone XR LCD and Digitizer Replacement, Remove the pentalobe screws: passo 1, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Remove the pentalobe screws: passo 1, immagine 2 di 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
    One of my gaskets was as shown in your second photo, the other had been worked into the threads (as if smeared) probably from the factory and was completely unusable.
    In place of replacements (unsure of where to purchase) I just used a clear silicone caulking on both screws upon reassembly to offer at least some water seal. I wish these gaskets were included with the gasket waterproofing sealant kit!
    Erica - Replica
    Is there any place to buy these screw gaskets? I haven’t seen it mentioned anywhere but one of mine was pretty much chewed up. Silicone should work but I’d prefer the oem solution.
    Chilinh Nguyen - Replica
    I found a place on Amazon that sells them. It's cheapest to get a full set of screws than to get just these. $5-$6 USD.
    J Olin -
    Can it be dead?
    Lulu navarro - Replica
    If I transfer the data from the old to the new battery with an icopy, don't I get an error message?
    David Julian Krause - Replica
    how am i supposed to know if the battery is below 25% if the screen won't turn on?
    Beth Jackson - Replica
    Spoiler alert! I just followed all the steps and if you bought the anti-clamp you might save a lot of time and some unreversible steps.
    I recommend that you read all the steps before beginning and follow the steps up to the point where the guide removes the screen (step 23). After that read again the precautions of step 41 and try the next thing:
    - Using something like the iOpener hot bag, heat up the back side of the phone where the battery is glued to for some minutes
    - Alternatively use a 3d printer heat bed at 60 degrees Celsius
    - Once the back of the phone is hot to the touch, enough to make it uncomfortable to the touch, find a portion of the battery with a smooth surface and attach the anti-clamp to it and the back of the phone
    - Follow the steps 4 and 5 to detach the battery from the frame
    If this procedure works you will not have to remove some elements such as:
    - lower speaker black tape (step 28)
    - lower speaker water proof gasket (step 33)
    I hope that someone find this helpful. Happy fixing!!
    Julio Beltran - Replica
  2. iPhone XR LCD and Digitizer Replacement, Mark your opening picks: passo 2, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Mark your opening picks: passo 2, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Mark your opening picks: passo 2, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Replica
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Replica
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Replica
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Replica
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Replica
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Replica
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Replica
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Replica
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Replica
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Replica
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Replica
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - Replica
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - Replica
  3. iPhone XR LCD and Digitizer Replacement, Tape over any cracks: passo 3, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: passo 3, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: passo 3, immagine 3 di 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
    How to detect my Iphone what screen it is, OLED or LCD?
    sabrihakulii - Replica
    It’s OLED. You can find the specs here, https://support.apple.com/en-us/HT201296
    When you find your phone, at the bottom of the description click on, See the tech specs…
    mcr4u2 -
    The included suction cups were stiff and worthless. They would not lift the screen. Also, I tried every type of tape on the screen to help the suction cups stick without success. Heavy duty suction cups were for my bathroom also failed. However, I had an old GoPro mount with some preapplied double sided 3M VSB tape and stuck that on the screen near the bottom. Magic! This method had the added bonus of being able to use a GoPro attachment as a handle to lift the screen, and propped up the screen like a kickstand in step 12.
    Tawan Khamapirad - Replica
    Very cool! Thanks
    Antonio -
    My screen was pretty stuck… would not budge. Heated, super glued the suction cup, tried gorilla tape. Ended up doing the GoPro mount with 3M VSB tape method mentioned. Worked great. That 3M tape is the bomb.
    Rich Wachtel - Replica
    The included suction cup took a few tries but ended up working for me.
    charlotte - Replica
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003 thick goes right in. Work your way up until you can get the pick or supplied pry tool in.
    William Olstad - Replica
    where can I buy 3M VSB plis!!
    gerardo artigas cuellar - Replica
    3M VHB tape is at auto stores and other big box stores, or online.
    nicO -
    I used the tweezers that came with the replacement screen and jammed one of them into the glass and that eventually worked. Heating with a blow dryer is also important. The suction cup was helpful in loosening the adhesive for sure, but just not enough to get the display to come out.
    J Olin - Replica
  4. iPhone XR LCD and Digitizer Replacement, Tape over any cracks: passo 4, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: passo 4, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: passo 4, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    This looks like a repeat of Step 3.
    GenjideGaulle - Replica
  5. iPhone XR LCD and Digitizer Replacement, Anti-Clamp instructions: passo 5, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Anti-Clamp instructions: passo 5, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Anti-Clamp instructions: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  6. iPhone XR LCD and Digitizer Replacement: passo 6, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement: passo 6, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement: passo 6, immagine 3 di 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  7. iPhone XR LCD and Digitizer Replacement: passo 7, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement: passo 7, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement: passo 7, immagine 3 di 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Please UPDATE THIS STEP to say 'insert the opening pick underneath the PLASTIC FRAME OF THE SCREEN' and not the screen. Way too many people are taking this as the way to do it then posting their screen looks different when it's open when they've actually removed the screen leaving the frame in place. It's not rocket science.
    [deleted] - Replica
    Thanks for the suggestion! We updated this step to clarify that.
    Arthur Shi -
  8. iPhone XR LCD and Digitizer Replacement, Heat up the screen: passo 8, immagine 1 di 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    An alternative to the Iopener or heat gun is to heat water to EXACTLY 80 degrees F (cooking thermometer is great for this) and pour into a reinforced ziplock type bag. Leave the bag on the screen, but be sure that none of the hot water rests on the zipper portion, as the water is hot enough to soften that seal and leak out on to your device! This meat had is my personal favorite as the heat is distributed very equally and precisely as compared to a heat gun, but is more accessible than the Iopener.
    Colin Wylie - Replica
    When using an iOpener, rest the glossy (transparent) side on the phone so it contacts the phone and conducts heat easily
    Afiq - Replica
  9. iPhone XR LCD and Digitizer Replacement: passo 9, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement: passo 9, immagine 2 di 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  10. iPhone XR LCD and Digitizer Replacement, Lift the display slightly: passo 10, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Lift the display slightly: passo 10, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Lift the display slightly: passo 10, immagine 3 di 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  11. iPhone XR LCD and Digitizer Replacement, Separate the screen adhesive: passo 11, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Separate the screen adhesive: passo 11, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Separate the screen adhesive: passo 11, immagine 3 di 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    I think it's important to note that depending on how a screen was damaged, make sure to insert the pic under the black bezel directly under the actual screen. This bezel is a frame around the digitizer. I unknowingly inserted the pic between the bezel and the screen, and separated them both. I did this all the way around the phone. So I basically had to struggle to keep together two different sections of the display assembly because of this mishap, until I removed all the ribbon connectors. It made things much more difficult.
    Dave - Replica
    An edit to my above comment: by digitzer, I mean the LCD shield. My apologies.
    Dave - Replica
    Yeah it’s helpful to just look at the screen they sent you. You’ll have a better idea of where to pry or stick your razor blade under!
    ryandlent - Replica
  12. iPhone XR LCD and Digitizer Replacement, Screen information: passo 12, immagine 1 di 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick at the marked spots, as you may damage the cables.
  13. iPhone XR LCD and Digitizer Replacement: passo 13, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement: passo 13, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement: passo 13, immagine 3 di 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    My replacement screen for the XR has a black rim but it looks pink. Is that normal?
    Irwin Cantor - Replica
    You can use some Isopropyl alcohol in a syringe with a thin needle to soften even more the adhesive around the screen. But be careful so as not to overdo it. Just a few drops. It will become more easier to remove the screen.
    Dan Brock - Replica
    Step 11 says not to insert your pick around the right side to avoid damaging cables, then Step 12 says to insert it on the right side. Help, I'm confused!
    ingwis - Replica
    Hi there!
    Thank you for the feedback! The wording in step 11 was definitely ambiguous, so we have changed it! You only need to avoid the marked spots rather than the right edge.
    Alex Diaz-Kokaisl -
  14. iPhone XR LCD and Digitizer Replacement: passo 14, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement: passo 14, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement: passo 14, immagine 3 di 3
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  15. iPhone XR LCD and Digitizer Replacement: passo 15, immagine 1 di 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  16. iPhone XR LCD and Digitizer Replacement, Open the iPhone: passo 16, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Open the iPhone: passo 16, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Open the iPhone: passo 16, immagine 3 di 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    sure looks like the "hinge" is on the right hand side to me.. not left...!
    Doug Trout - Replica
    If you leave the suction cup attached to the screen during the “hinging” process, it makes for a very handy holder for the screen until it’s completely detached.
    Richard Deubler - Replica
    What about the sticky black adhesive clinging to the inside of the case?
    Ronald - Replica
  17. iPhone XR LCD and Digitizer Replacement, Unscrew the battery connector cover: passo 17, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Unscrew the battery connector cover: passo 17, immagine 2 di 2
    Magnetic Project Mat
    $19.95
    • Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
    • Remove the bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Definitely make sure all three lobes of your tool are aligned before use (it’s a little harder to tell with this style of bit) and apply even and adequate pressure to ensure it grabs as you spin the driver to prevent disfiguring the lobes/slot of the screw head.
    Unfortunately my Y000 tool was perhaps not the best fit (tolerance a bit off) in these screws and I ended up stripping out the heads of all three of these. I started to panic but after I sanded the tip of my Y000 bit down a little with super fine grit (1000CW-C) sand paper to flatten the domed tip (visible with macro lens) and give it a bit more bite I was able to remove and reinstall without issue—in fact I had to remove and install them twice since I forgot my adhesive tape during reassembly, so the screws survived and the sanded bit worked.
    Erica - Replica
    +1 to above comment. I bought a cheap kit from Amazon and the Y000 screw driver is not good for this job. I’m concerned that I may have disfigured the heads and i type this comment in the midst of my fix :D Be gentle and assess if you can remove at least one screw with your driver before rummaging through all three and other similar screws holding display connector as well.
    Shan Potti - Replica
    Update to above comment. I got hold of a Y0.8 screw driver bit (lucky to find an ORIA screw driver kit in my office) and it works like wonders :) Now back to work…
  18. iPhone XR LCD and Digitizer Replacement, Disconnect the battery: passo 18, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Disconnect the battery: passo 18, immagine 2 di 2
    • Use the point of a spudger to pry the battery connector straight up out of its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone XR LCD and Digitizer Replacement, Unscrew the display connector cover: passo 19, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Unscrew the display connector cover: passo 19, immagine 2 di 2
    • Remove the two 1.2 mm Y000 screws securing the display connector bracket.
    What if the screw is damaged and you can’t get one out?
    Kashawn Benjamin - Replica
    Same issue here. These screws are a lot thighter than the others. Maybe add a caution notice to be patience with these ones.
    What you can try is superglue to make it attached to the screw.
    Lennard - Replica
  20. iPhone XR LCD and Digitizer Replacement, Disconnect the digitizer: passo 20, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Disconnect the digitizer: passo 20, immagine 2 di 2
    • Use the tip of a spudger to pry up and disconnect the digitizer cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  21. iPhone XR LCD and Digitizer Replacement, Disconnect the display: passo 21, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Disconnect the display: passo 21, immagine 2 di 2
    • Use the tip of a spudger to disconnect the display cable connector.
    The new display cable isn’t snapping in but I was just able to snap in the old one. Did I break the new one somehow?
    Andrew Pierson - Replica
    Same it is really frustrating, just keeps slipping up and its bound to get damaged
    Daniel Maldonado - Replica
  22. iPhone XR LCD and Digitizer Replacement, Unscrew the logic board connector cover: passo 22, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Unscrew the logic board connector cover: passo 22, immagine 2 di 2
    • Remove the five screws securing the logic board connector bracket to the rear case:
    • One 1.3 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • Three 1.2 mm Y000 screws
    • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
    Phillips screw 1.3 mm on last step is not working. The small clipped bracket has been damaged. This screw perhaps should be the first, before 1.2 Y000. - To be confirmed by others.
    Dmitri - Replica
    I’m not sure it makes much if any difference, but we went ahead and swapped the order for you guys. Thanks for your comments!
    Jeff Suovanen - Replica
    I just repaired another XR, and you are right! It doesn’t make any differnerce in the order these screws come out. I still damaged this fragile piece. As I work on more of these, I’ll figure out a way to remove this screw without damaging the clip. For now everyone, just use extra caution when removing the 1.3mm phillips screw! Thanks Jeff
    fabianowens -
    I’ve now done at least 6 of these so far and I have fairly consistent good results by taking the 2 Philips head screws out first, then doing the Y screws.
    Stow -
    Is this piece important for the repair if broken? I have broken it on a home repair. What is it used for? Is it a grounding connection or is it completely unimportant. More information needed please
    Squishy Horses - Replica
    I’m wondering that too. Is this piece important?
    Phillip Gross -
    My clip broke too! on iphone XR. Any word on necessity?
    Beth Buer - Replica
    I can confirm that taking out the 1.3 mm screw first then the 1.5 mm screw works the best. If done correctly, you should be able to to remove the rest of the screws and pull the panel off with the clip still attached to the panel. For reassembly, start with the 1.5 mm screw then the 1.3 mm screw.
    Carlos Oulman - Replica
    I don’t remove the small screw at all. I just slide out the metal cover plate and slide back in to reassemble.
    Kyaw-Zin Win - Replica
    this is what i have done as well. Care is still needed to avoid damaging this part. However, it is seemingly far less prone to damage or loss and thus less risky for this repair process.
    Justin Parsons -
    I too broke this shield. In looking over this problem I believe it’s best to loosen, but not remove, either screw first then the other. To be clear, loosen the red or yellow screw but only just to break it free, then the second screw. Then remove both and the others and the shield should remain in one piece. I put it back with the broken part (on the red screw) and made sure the two are in contact so there’s conductivity as these shields serve a purpose other than just holding in connectors. My phone works fine with this fix.
    pgrobin - Replica
    Is this small bracket important if broken??
    Phillip Gross - Replica
    Mine is broken
    Easy Repair - Replica
    Mine is broken and my apple pay doesn’t work. Something to do with NFC antenna this little clip??
    Marcos Fernández - Replica
    I'm guessing so. I replaced a screen on a phone I bought from a friend. I noticed this bracket was broken when I disassembled the phone but didn't think much of it. When I reassembled it my NFC also does not work. Bummer. A lot of people in these comments have asked if it is crucial that this bracket be connected. Can someone from iFixit or other please reply to those comments?
    Larry Jorgenson -
    On the 1.3 mm screw I actually chose not to remove it. I broke it loose then used the tip of the spudger to simply twist the bracket out of the way, with the screw still attached. Then I could remove the larger bracket.
    mpalma - Replica
    Kyaw-Zin is right because the shield contains of two tin parts. But there is another option:
    1. Unscrew the yellow and orange screws first.
    2. Lift the shield gently that it can turn about 20° anticlockwise.
    3. Open the red screw and let the shield turn with it the first degrees.
    Daniel Brehm - Replica
    The first time I did this repair, I didn’t see the comments ahead of time and broke the bracket, even removing the 1.3mm screws first. The second time I did the repair, I was prepared and being extra careful, but the simple act of turning the 1.3mm screw head was enough to break it. If I ever have to do this repair again, I’ll just leave the screw in and try to slide the plate out with the screw (and bracket, hopefully) still in tact, as per Kyaw-Zin Win.
    Debbie Thompson - Replica
    None of the screw driver bits I got fits the 1.3mm and 1.5mm screws. How do I remove them?
    Jonatious Joseph Jawahar - Replica
    Same issue as above. The bits provided in the kit do not work with the 1.3mm and 1.5mm screws
    Graham Hammell - Replica
    Further to above comment about bit not working. Had to go and purchase another PH000 from Home Depot and that worked
    I’ve broken that little bracket attached to the red screw. Is it important and can I get a replacement????? Thanks all
    steve.arfa - Replica
    Broken the clip. Is this important??
    kyledrumtutor - Replica
    Yikes, broke mine too. Oh god. Think perhaps the delicate 1.3mm should come out first when everything else is secure...
    Ronald - Replica
    Don't remove the 1.3 Phillips screw! Twisting this screw will break the smaller bracket that is clipped to the larger. Remove all the other screws. Block the smaller bracket from moving as you gently slide the larger bracket horizontally toward the battery until free. The smaller bracket can stay in place while the screen is replaced. When reassembling, support the small bracket by backing with a spudger or similar tool.
    doug68242 - Replica
    I just broke the smaller bracket also :( I didn´t notice these comments until now :(
    It looks like part of the antenna for NFC, as all except NFC works on my iPhone now.
    It should be repairable using some wire wrap wire, either twisted around the two screws that connected that part of the bracket (or soldered in place). I will try and report back if it works.
    Richard Croyle - Replica
    Success!! I managed to re-construct the small arm of the bracket by screwing the 1.3mm screw back in with some 0.3mm enamel wire soldered into what was left of the small bracket arm on the screw, then the other end of the enamel wire I wrapped under the 1.5 wire screw's head (enamel exposed to bare metal), then screwed both screws down. also I lifted up the small metal arm with a screw driver (to make sure it reconnects with the display grounding square) ..and NFC worked again (slightly different antenna pattern mind (need to place cards slightly higher up the rear of the phone). Anyway works again :)
    do you think it would be possible to repair without the use of microsoldering?
    i brought a new bracket set for the xr and replaced the old one but even with that nfc/apple pay still doesn't work. i'm questioning if i put a wrong size screw or something else
    prolificgmabit -
  23. iPhone XR LCD and Digitizer Replacement, Disconnect the front sensors: passo 23, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Disconnect the front sensors: passo 23, immagine 2 di 2
    • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
    During testing, make sure your proximity sensor is not on upside down, as it’s easy to connect upside down. Your phone will boot loop if it’s on incorrectly.
    Tristan England - Replica
  24. iPhone XR LCD and Digitizer Replacement, Remove the display assembly: passo 24, immagine 1 di 1
    unclear if this is where screen removal ends
    I had the same question, but the answer is yes. Steps 21-30 are removing parts from the original screen that need to be reattached onto the new screen. You are no longer working inside the frame, but on the back of the screen itself.
    amclean78 - Replica
    I apologize for missing these comments initially, but yes that’s correct, the screen is removed now and the rest of the guide goes on to other parts, either in the phone or on the back of the screen. Good luck with the repair!
    Adam O'Camb -
    The alternate method of removing the battery should be highlighted as a standard option. There is so much more work and potential to damage the parts than if you left them in place and carefully with plenty of heat remove the battery. I so wish I had seen this before!
    Martin Kappeyne - Replica
  25. iPhone XR LCD and Digitizer Replacement, Unscrew the earpiece speaker: passo 25, immagine 1 di 1
    • Remove the four screws securing the speaker/sensor assembly to the back of the display:
    • Two 1.6 mm Phillips screws
    • One 2.3 mm Phillips screw
    • One 1.2 mm Y000 screw
    Do you really need to do step 21-30, because it says to replace, do it in reverse. Which means you are taking the components off and putting them back on without touching the screen? sorry if this is a dumb question, i’ve never done this before.
    ExplodingRage - Replica
    Good question! It depends on which guide you are completing. If you are replacing the screen, you do need to complete steps 21-30, in order to remove the front assembly and transfer it to your replacement screen. The front assembly contains the Face ID hardware, which is biometrically linked to the logic board.
    Now, if you are completing other guides, you may not need to remove the front assembly. Guides should have the steps slotted in only if they are pertinent to the procedure.
    Arthur Shi -
    amclean78 -
    Im reassembling and notice there are no threaded screw holes to secure the speaker/sensor assembly on the new display. no way to secure it at all. Do i not need to secure it?
    Ashley Fitzgerald - Replica
    Hi Ashley,
    There should definitely be screw holes to secure the assembly to the new display. If you purchased the part from iFixit, please contact our customer support, and we will sort things out for you!
    Arthur Shi -
    Same. No screw holes. Now what?
    M Schmidt - Replica
    Please contact our customer support and we will get the issue resolved!
    Arthur Shi -
  26. iPhone XR LCD and Digitizer Replacement, Flip the speaker over: passo 26, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Flip the speaker over: passo 26, immagine 2 di 2
    • Using tweezers, gently flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via a very thin flex cable. Be careful not to strain or damage the cable.
    I don’t understand. It clearly appears that one should stop disassembling after this step. Peeling off the tape here should provide access to the solder connections. Why remove a bunch of other adhered parts? ESD concerns?
    Of course, taking care not to transmit heat to the screen assembly below would be prudent. But it’s unlikely much if any heat would conduct even without using any sort of insulating spacer, assuming one’s soldering technique is acceptable. With a thermal mass that small, overheating the connection is the big concern. Especially since it is lead-free solder.
    (It has a high melting point. If you didn’t already know that, this is definitely not the best project to develop your soldering skills! You can still do it, but should def practice on similar connections until you feel proficient. Lifting a pad or overheating a nearby component are both dangers. Yet, the cost of the part is low enough you could buy two (just in case) and still come out ahead of Apple’s fee. Use flux or you’ll struggle!)
    Ryan Lewis - Replica
    Hey Ryan,
    You are right in that after this step, you could de-solder and replace the earpiece individually, if you choose to do some careful de-soldering and soldering. Alas, not everyone has the background and skill to do so! By instructing users to replace the complete assembly, we bypass the need to solder, and allow a wider audience to successfully complete the repair.
    Arthur Shi -
    When reassembling or placing the whole sensor module on a replacement screen, make sure to gently rock the speaker back into place. There is a rubber gasket lip around the speaker that must be seated all of the way against the screen and speaker grill to function properly. You should feel a gentle click when is goes in. If is not seated correctly it still easily can be screwed in making it difficult to tell if the speaker is in correctly.
    Hey, I actually ended up accidentally ripping that ribbon off the speaker. What happens now?
    lanize - Replica
  27. iPhone XR LCD and Digitizer Replacement, Heat the front sensor strip: passo 27, immagine 1 di 1
    • Use a hairdryer, a heat gun, or a heated iOpener applied to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
    Review steps 24-29 prior to doing this. Step 27 shows removing ambient sensor. It is attached….barely…to the rest of this assembly. I thought I was being overly cautions, and it still broke. Don’t be afraid to use heat. Do not force. Any resistance, do not force it.. Heat it up and then try. Other than that, sound and camera works fine, and it appears that FaceID works. Not my phone, so I can’t test that part without unlocking customer’s phone. No error messages appeared, so Im assuming all is good. With the touch home button on older models, if touch wouldn’t work, you’d receive a message as soon as you booted the phone up. OK.. That’s enough. Just be careful over the next 5 steps..
    Shawn Bailey - Replica
  28. iPhone XR LCD and Digitizer Replacement, Pry up the microphone: passo 28, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Pry up the microphone: passo 28, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Pry up the microphone: passo 28, immagine 3 di 3
    • Carefully slide the flat edge of a spudger underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel. If the microphone remains difficult to separate, apply more heat.
  29. iPhone XR LCD and Digitizer Replacement, Pry up the proximity sensor: passo 29, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Pry up the proximity sensor: passo 29, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Pry up the proximity sensor: passo 29, immagine 3 di 3
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
    what happens if the metal plate from the sensor separates from the flood illuminator module?
    Yeison rodriguez - Replica
    At this point I thought looking at the image that I was lifting the speaker away and tore off the thin cable completely unaware. Please read and view the next two instruction stages before doing this one and then come back and ensure you keep the speaker very close to the screen as you do it.
    Sally-ann - Replica
  30. iPhone XR LCD and Digitizer Replacement, Remove the ambient light sensor bracket: passo 30, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Remove the ambient light sensor bracket: passo 30, immagine 2 di 2
    • Use tweezers to slide the small bracket straight up and off of the ambient light sensor.
    I tore the ribbon cable that connects to the light sensor, what do I do? will the phone work even if the sensor doesn’t?
    wittyahole - - Replica
    When you are putting this clip on, you can practice without putting the light sensor on it. It takes some practice. I also may not stay on tightly but it's not a big deal.
    J Olin - Replica
    This clip is a nightmare to get back on!
    Ronald - Replica
    I gave up trying to get the clip back on. Appears to function properly without it.
    Paul Chipelo - Replica
    Definitely one for the tweezers in order to get the brackets little sleeve to fit back over the backet/post sticking up
    Jono Official - Replica
  31. iPhone XR LCD and Digitizer Replacement, Lift the ambient light sensor: passo 31, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Lift the ambient light sensor: passo 31, immagine 2 di 2
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
    • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
    On picture two, the thin transparent thread between the sensor and the display is not the “very thin flex cable” they are talking about but just some glue remains. In my case this thread of glue was sticking onto the sensor in the exact same way which made me suspicious at first.
    Konstantin - Replica
    The top part of the ambient light sensor easily breaks off from the bottom part. In that case do not despair. Pry the stuck part from the old display and transfer it to the new display. Put the assembly back together without glue. It should hold together just fine. Usually the auto brightness feature will still work.
    Heiko Quant - Replica
    I broke the flex cable from the light sensor that connects to the rest. Anything I can do?
    Matias Bedoya - Replica
  32. iPhone XR LCD and Digitizer Replacement: passo 32, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement: passo 32, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement: passo 32, immagine 3 di 3
    • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
    • If the white diffuser strip is detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
    • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
    • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
    so I was able to wiggle the part out and everything came out except the white strip, like a sticker coming off the bottom so my situation isn't displayed in the diagrams is that white strip important? should I remove it and try to adhere it to the bottom of the ambient light sensor?
    Shadowind98 - Replica
  33. iPhone XR LCD and Digitizer Replacement, Remove the speaker + front sensors: passo 33, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Remove the speaker + front sensors: passo 33, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Remove the speaker + front sensors: passo 33, immagine 3 di 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
    To replace just the earspeaker, you will have to re-use the the flex assembly which is soldered to the earspeaker…….
    the 2 solder connection are hidden under a tiny piece of thin black tape, on the underside of the speaker.
    Alan Sears - Replica
    forgot to mention to take the clear plastic mold off from the old screen!!
    BKimc - Replica
    Before attaching the sensor module to your replacement screen, ensure there is nothing blocking the earpiece screen on the new screen part. Mine had a mfg defect or something where there was a black foam like film on the outside of the speaker grill that I couldn’t remove with tape or sticky putty. I had to blow through the back of the grill with a computer duster compressed air can. Otherwise the call volume via the earpiece is extremely low, even when turned to max volume.
    Hey there, if I have an iPhone bit damage and I remove the top speaker and sensor and put it on my other iPhone XR. Will it work? It is original iPhone XR and please let me know
    Nash G Krish - Replica
    The Face ID hardware is paired to the logic board and will not work if you transfer the front sensor assembly. Everything else should work.
    Arthur Shi -
    Are you suposeted to do it backwards when your done
    hewi fewi - Replica
    super gemacht , danke der olli
    schlüppi punkstrumpf - Replica
    The iPhone XR Screen Replacement Kit comes with an adhesive replacement on a blue plastic sheet. I didn’t know what this was and thought it was just protection for the screen during shipping.
    Don’t throw it out - At this step 29 remove the old adhesive using this guide -> Sostituzione guarnizione adesiva display iPhone
    Don’t be dumb like me.
    Toby BC - Replica
    I would definitely add a step at the end –
    30) Replace the adhesive seal -> iPhone Display Adhesive Replacement.
    Steve Koontz - Replica
    How do I configure True Tone on the new screen?
    Armando - Replica
    You need to use an EEPROM programmer. This will read code from the old screen to the new screen (assuming the replacement screen is of decent quality and supports True Tone programming). Check out YouTube and you will find plenty of information on how to do this. It really should be mentioned in screen replacement guides/videos, that if you just replace the screen without this specialist equipment, the True Tone function is not available. This is the same for all iPhones that have True Tone.
    Mark Affleck -
    i just saw recently where the ear hole in the new display was occluded - needed to drill it out. can see with a microscope - may want to check this before reassembly.
    greg - Replica
    Add a comment: remove blue protective covers from back of screen when installing
    Thanks! I left them on until I got everything hooked up…..so frustrating lol
    ryandlent -
    Removed the big blue one but couldn’t get the little one with what looked like a QR code on it. It goes literally between the 2 cables.
    ryandlent - Replica
    Thanks for the excellent guide! My replacement screen came with no sensor bracket, so I had to remove that from the old screen and remove the earpiece grill from the new screen (because the old grill remained attached to the bracket).
    Goda Choi - Replica
  34. iPhone XR LCD and Digitizer Replacement, Unscrew the LCD shield plate: passo 34, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Unscrew the LCD shield plate: passo 34, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Unscrew the LCD shield plate: passo 34, immagine 3 di 3
    • Use a Y000 driver to remove the 1.1 mm screws securing the LCD shield:
    • Three screws on the side nearest the display cables
    • Two more screws on the opposite side
    • Press your driver firmly into the screw while turning it. If needed, you can use your spudger to brace each screw from behind, in order to apply more pressure to the screws without bending the shield.
    There is two more screws at the bottom !
    ubrunner - Replica
    L’appui sur les vis est réellement important, au risque de foirer celles-ci. N’hésitez donc pas à appuyer, en faisant contre-poids du côté opposé bien évidemment.
    Tristan Nans - Replica
    This is the bit that was difficult. The tri'point screwdriver y0000 barely fits this tricky size. It could have been the cheap screwdriver that came with the screen replacement kit. Stripped 2 screws, drilled out with an appropriate size drill bit ' frame still intact. I had more success using a size 0.7mm flathead screwdriver.
    noname - Replica
  35. iPhone XR LCD and Digitizer Replacement: passo 35, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement: passo 35, immagine 2 di 2
    • Remove the remaining 1.1 mm Y000 screws from the top and bottom edges of the LCD shield:
    • Two screws near the camera cutouts
    • Two screws at the bottom corners
  36. iPhone XR LCD and Digitizer Replacement, Add a little heat: passo 36, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Add a little heat: passo 36, immagine 2 di 2
    • Apply a little heat from an iOpener (or hair dryer / heat gun) to the back of the display, in order to soften the adhesive securing the display cables to the LCD shield.
  37. iPhone XR LCD and Digitizer Replacement, Unstick the display cables: passo 37, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Unstick the display cables: passo 37, immagine 2 di 2
    • Insert an opening pick between the display cables and LCD shield.
    • Slide it toward the bottom edge of the display to begin separating the cables.
    • Stop when you reach the end of the first cable.
  38. iPhone XR LCD and Digitizer Replacement, Separate the two cables: passo 38, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Separate the two cables: passo 38, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Separate the two cables: passo 38, immagine 3 di 3
    • Re-insert your opening pick, this time between the two cables.
    • Slide the pick to the bottom edge of the display to separate the cables from each other.
  39. iPhone XR LCD and Digitizer Replacement: passo 39, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement: passo 39, immagine 2 di 2
    • Grab each cable near its 90° bend, and peel them apart.
  40. iPhone XR LCD and Digitizer Replacement: passo 40, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement: passo 40, immagine 2 di 2
    • Peel the entire digitizer cable away from the LCD shield, and fold it aside.
    Be very careful of all parts of the ribbon cable connected to the screen, especially the segment close to the top, as it can tear easily at this
    crtrue - Replica
  41. iPhone XR LCD and Digitizer Replacement, Lift the shield plate: passo 41, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement, Lift the shield plate: passo 41, immagine 2 di 2
    • Insert an opening pick under the top edge of the LCD shield, and twist to separate it from the display.
  42. iPhone XR LCD and Digitizer Replacement: passo 42, immagine 1 di 2 iPhone XR LCD and Digitizer Replacement: passo 42, immagine 2 di 2
    • Grab the LCD shield by its top edge and swing it upward a few degrees.
    • Using your spudger, press gently on the lower part of the display cable, pushing it through the cutout in the LCD shield.
  43. iPhone XR LCD and Digitizer Replacement: passo 43, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement: passo 43, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement: passo 43, immagine 3 di 3
    • Raise the top edge of the LCD shield a bit higher, and feed the rest of the display cable through the cutout in the shield.
  44. iPhone XR LCD and Digitizer Replacement, Separate the display cable: passo 44, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Separate the display cable: passo 44, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Separate the display cable: passo 44, immagine 3 di 3
    • Raise the LCD shield up at a higher angle, until you can see the rest of the display cable stuck to the back.
    • Slide a spudger between the LCD shield and the display cable, and separate them completely.
  45. iPhone XR LCD and Digitizer Replacement, Check the EMI fingers: passo 45, immagine 1 di 3 iPhone XR LCD and Digitizer Replacement, Check the EMI fingers: passo 45, immagine 2 di 3 iPhone XR LCD and Digitizer Replacement, Check the EMI fingers: passo 45, immagine 3 di 3
    • As you lift the LCD shield, note the metal prongs on the bottom edge.
    • During reassembly, make sure these prongs (a.k.a. EMI fingers) are correctly inserted into the LCD frame as shown.
    hello whaty if one of the golden contact pins ( i guess it is) to be exact right one has freyed up a bit and looks messy. could it cause harm or it is not very important?
    thetroll1401 - Replica
    On reassembly leave the adhesive cover on the digitizer cable so that it doesn’t get caught on the LCD shield while working the other cable in place and positioning the shield on the frame. When you are ready to stick the digitizer cable to the shield remove the protective plastic.
    pgrobin - Replica
  46. iPhone XR LCD and Digitizer Replacement, Remove the shield: passo 46, immagine 1 di 1
    • Remove the LCD shield.
  47. iPhone XR LCD and Digitizer Replacement: passo 47, immagine 1 di 1
    • Only the LCD and digitizer remains.
    Tech nor working my iphone xr
    Mohammed Chand - Replica
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
Altre 99 persone hanno completato questa guida.
Jeff Suovanen
Membro da: 08/06/13
442.336 Reputazione
259 Guide realizzate
iFixit Membro di iFixit
Staff
119 Membri
21.019 Guide realizzate
15Commenti sulla guida
So it’s like the X had a baby with an 8
James Heinrich - Replica
Hello everyone! Hoping I can get some feedbacks on a problem I’m having. I’m doing a screen replacement on an XR but the bottom half of the screen is unresponsive to touch. The replacement screen is from another XR with original Apple screen. When I put the replacement screen back, it works fine so it can’t be anything that’s damaged on the replacement screen. Also this replacement screen does the same thing to any iphone XR I put in so I know it means there’s no problems with the logic board. The replacement screen only works with its original but not on any other XR.
duc - Replica
i have same problem. Need Help
RNS -
Did you find a way Around this ??im experiencing the same thing
abooismail1234 -
What if I just needed to replace the front outer glass only, what steps are needed? Do you have to disassemble the phone?
Gene - Replica
@emika491 Glass-only repairs are possible for pros, but it’s not a DIY. It takes practice to perfect, and the equipment alone costs about as much as a new phone. I’d stick to replacing the whole display. ;)
Jeff Suovanen -
Hi
The last 2 cables connected to the LCD digitizer is cut and is there a way to remove then?
Behrooz Hussaini - Replica
Hallo, i have same problem, Can you help me, please?
Filip Treger - Replica
These instructions are amazing! I followed them and they worked to a T. Every detail was good, the pictures were good. My iPhone XR has a new screen, reused the old LCD metal panel, and put in a new waterproof seal. Thank you for posting this.
Kyle Closner - Replica
Hi,
So I did a screen replacement on an xr and I wanted to activate true tone, but the flex cable broke on the original screen. Now I think if I use the cover board number for activation that could work too., but I noticed that the number printed on the back of the old lcd looks very similar to it, now is that the screens serial and could I use that number too?
szbalint - Replica
Finito senza alcun problema. Il display funziona alla perfezione. Grazie.
Paolo Notaro - Replica
There are 3 types of LCD screen manufacturers that Apple use for their mobile devices – SharpToshiba and LG. The Sharp and Toshiba LCD screens are cross-compatible and you can use either of these screens on each handset, however, when you have an iPhone with an LG screen then you would only be able to use an LG screen replacement for these LG coded devices. Again, you might be wondering why.  Well, if you fit a Toshiba or Sharp LCD to an iPhone that had an LG screen previously then the chances are you will either have no touch function or intermittent touch issues, so you must identify the screen manufacturer of your iPhone before ordering a premium replacement.
See more at: https://www.iparts-4u.co.uk/blog/how-to-...
clbr - Replica
@jeffsu With all due respect, responding to someone’s post inquiring different options for repairing their iPhone XR screen with rebuttal about how hard it is and not at least pointing them in the direction of resources should they still want to try is unproductive and seemingly maligned with ifixit’s philosophy regarding user’s retaining the right to fix their own devices, unless I’m misunderstanding something here?
Isn’t it possible to advice of the technical difficulty/ potential issues AND celebrate their desire to take on such a project by equipping them with some info and pointing them in the direction of a great tool kit to get them started , whatever they decide?
Wether it should be left to a Pro or not is ultimately the consumer’s decision and border’s the same rhetoric Apple uses to justify all of its proprietary tech guides and components. And before we refute the premise of what I’m saying with the “liability” argument, remember that this is what disclosures are for.
Happy Fixing!
Sata - Replica
Thanks for your concern. I’m sorry if my comment came across as flippant or dismissive. By way of background: There are a lot of companies deceiving customers by selling “glass-only” screen repair kits for $10-20 that are in reality a waste of money—the repair requires expensive equipment and a fair bit of practice/skill. Most professional repair shops won’t attempt it, and those that do usually destroy quite a few displays getting the hang of it, even after investing in all the equipment. Few can do it consistently and with good results. Meanwhile, we’ve seen plenty of readers fall for the “glass-only” repair kit scam and then complain after being ripped off because we didn’t warn them away strongly enough. Bottom line, it doesn’t make any sense to attempt this unless you’re planning to make a business out of it. Just bite the bullet and replace the whole display. It’s cheaper, faster, and the only approach with a reasonable chance of success for a DIYer.
Jeff Suovanen -
First off, great site, all around. Iphone will not start unless unless I also pinch screen right top corner while affecting volume up and power button.
John - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 22
Ultimi 7 Giorni: 183
Ultimi 30 Giorni: 881
Tutti i Tempi: 142,181
