Salta al contenuto principale
Sostituzione SSD Blade iMac 27" 2017
Cosa ti serve
  1. Sostituzione SSD Blade iMac 27" 2017, Installa il cuneo di supporto: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    iMac Intel 27" Cardboard Service Wedge
    What’s the point of this? You run the wheel around the outside, and then you lay it down anyway to pull the glass and do the rest. The wedge is not needed.
    ebay - Replica
    I have a story to tell about this teardown. It all went wonderfully well until after I completed the process and attempted to format my new SSD drive only to discovery that the capacity of the drive was 256GB… not the 2TB I was sure I had ordered. iFixit was very supportive and helpful in sending me a new set of sticky tape strips and and RMA to return the SSD and some of the other parts.
    I finally had received my new set of strips and the 2TB SSD…. I figured, piece of cake… I already know how to do this… but I watched the video again and started following the teardown…
    …apparently the new sticky tape strips was way more powerful that the original tape and while using the pizza cutter tool and not advancing much, I proceeded to use one of the iFixit credit card style wedges…. I now have 2 pretty severe cracks on the glass of my display, which as clearly explained by @mayer can only be replaced by an entire display… which runs at about $500. Cosmetically it looks horrible, but it works… for now.
    Erich Hentschel - Replica
  2. Sostituzione SSD Blade iMac 27" 2017, Infila uno strumento di apertura: passo 2, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Infila uno strumento di apertura: passo 2, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Infila uno strumento di apertura: passo 2, immagine 3 di 3
    • Iniziando dalla sinistra del display, vicino al tasto di accensione, inserisci lo strumento di apertura per iMac nello spazio tra il vetro e la scocca posteriore.
    • Il perno dell'iMac Opening Tool eviterà che la rotella entri troppo all'interno. Se usi un attrezzo diverso, inseriscilo non più di 9,5mm nel display. Potresti rovinare i cavi dell'antenna e causare gravi danni se lo inserisci troppo a fondo.
    Should you run a hair dryer along the edges first?
    Al Val - Replica
  3. Sostituzione SSD Blade iMac 27" 2017, Taglia l'adesivo dello schermo: passo 3, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Taglia l'adesivo dello schermo: passo 3, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Taglia l'adesivo dello schermo: passo 3, immagine 3 di 3
    • Usa l'attrezzo come una rotella tagliapizza: fallo girare nella fessura per tagliare la parte centrale dell'adesivo in schiuma.
    • Assicurati di spingere l'impugnatura dietro la rotella. Se tirassi, la rotella potrebbe uscire dal manico.
    • Fai scorrere l'attrezzo lungo la parte sinistra del display.
  4. Sostituzione SSD Blade iMac 27" 2017, Taglia l'adesivo restante: passo 4, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Taglia l'adesivo restante: passo 4, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Taglia l'adesivo restante: passo 4, immagine 3 di 3
    • Continua a far scorrere la rotella lungo l'angolo superiore sinistro.
  5. Sostituzione SSD Blade iMac 27" 2017: passo 5, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 5, immagine 2 di 2
    • Taglia l'adesivo lungo la parte superiore sinistra del display.
  6. Sostituzione SSD Blade iMac 27" 2017: passo 6, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 6, immagine 2 di 2
    • Continua lungo la parte superiore del display.
    • Puoi far scorrere la rotella avanti e indietro per assicurarti di separare il più possibile l'adesivo.
  7. Sostituzione SSD Blade iMac 27" 2017: passo 7, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 7, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 7, immagine 3 di 3
    • Spingi l'attrezzo intorno all'angolo superiore destro del display.
  8. Sostituzione SSD Blade iMac 27" 2017: passo 8, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 8, immagine 2 di 2
    • Fai scorrere la rotella lungo il lato destro del display.
  9. Sostituzione SSD Blade iMac 27" 2017: passo 9, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 9, immagine 2 di 2
    • Finisci di spingere lo strumento di apertura fino alla parte bassa del lato destro del display.
    • A questo punto dovresti far scorrere l'attrezzo intorno a tutto il display per una seconda volta, per assicurarti di separare il più possibile l'adesivo.
  10. Sostituzione SSD Blade iMac 27" 2017, Separa lo schermo: passo 10, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Separa lo schermo: passo 10, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Separa lo schermo: passo 10, immagine 3 di 3
    Plastic Cards
    $2.99
    • Quando lo strumento di apertura avrà fatto la maggior parte del lavoro, il display sarà ancora leggermente attaccato al case. Servirà una scheda di plastica per staccare l'adesivo rimanente.
    • Posiziona l'iMac a faccia in su sopra un tavolo.
    • Partendo dall'angolo superiore destro, inserisci una scheda di plastica tra il display e la scocca.
    • Fai attenzione a non inserire la scheda più di 9,5 mm per non danneggiare i componenti interni.
  11. Sostituzione SSD Blade iMac 27" 2017: passo 11, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 11, immagine 2 di 2
    • Torci delicatamente la scheda di plastica per allargare la fessura tra il display e la scocca e taglia l'adesivo rimanente vicino agli angoli.
    • Usare troppa forza potrebbe rompere il vetro. Lavora con attenzione e non provare ad allargare la fessura oltre 6 mm circa.
  12. Sostituzione SSD Blade iMac 27" 2017: passo 12, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 12, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 12, immagine 3 di 3
    • In questo passo, assicurati di interrompere il taglio prima della fotocamera iSight o potresti danneggiarla.
    • Fai scorrere la scheda verso il centro del display per tagliare l'adesivo rimanente.
  13. Sostituzione SSD Blade iMac 27" 2017: passo 13, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 13, immagine 2 di 2
    • Inserisci di nuovo la scheda nell'angolo e lasciala lì per evitare che l'adesivo si riattacchi.
  14. Sostituzione SSD Blade iMac 27" 2017: passo 14, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 14, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 14, immagine 3 di 3
    • Inserisci una seconda scheda nella fessura tra lo schermo e la scocca nell'angolo superiore sinistro.
  15. Sostituzione SSD Blade iMac 27" 2017: passo 15, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 15, immagine 2 di 2
    • Torci delicatamente la scheda, allargando lievemente la fessura tra lo schermo e la scocca.
    • Come per l'altro lato, procedi lentamente per dar tempo all'adesivo di staccarsi e fai attenzione a non sollecitare troppo il vetro.
  16. Sostituzione SSD Blade iMac 27" 2017: passo 16, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 16, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 16, immagine 3 di 3
    • Fai scorrere la scheda di plastica verso il centro, fermati anche questa volta prima della fotocamera iSight.
  17. Sostituzione SSD Blade iMac 27" 2017: passo 17, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 17, immagine 2 di 2
    • Inserisci di nuovo la scheda nell'angolo superiore sinistro.
  18. Sostituzione SSD Blade iMac 27" 2017: passo 18, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 18, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 18, immagine 3 di 3
    • Con le schede inserite come mostrato vicino agli angoli, torci delicatamente le schede stesse per allargare la fessura tra display e scocca.
    • Se c'è ancora qualche punto che sembra incollato e non vuole separarsi, smetti di torcere le schede e usane una per tagliare l'adesivo in quel punto.
    • Comincia a sollevare dalla scocca la parte superiore dello schermo.
    • Solleva il display solo di pochi centimetri - è ancora collegato all'iMac dai cavi dati e alimentazione.
  19. Sostituzione SSD Blade iMac 27" 2017, Scollega i cavi dello schermo: passo 19, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017, Scollega i cavi dello schermo: passo 19, immagine 2 di 2
    • Mentre tieni lo schermo con una mano, usa l'altra per scollegare il cavo di alimentazione del display.
    • Solleva il display quanto basta per raggiungere i contatti ma non troppo per evitare di sollecitare i cavi e i connettori (circa 20 cm).
    Der Stecker muss seitlich wie die meisten anderen Stecker in diesem Modell komprimiert werden, um ihn aus der Buchse auf dem Logicboard zu ziehen. Die Zugrichtung ist parallel zum Logicboard in Richtung Oberkante des iMac. Ziehen ohne seitliches Zusammendrücken der Backen am Stecker könnte den Stecker oder die Buchse beschädigen.
    Ernest Bumblebee - Replica
    These instructions are unclear. They imply the cable can just be pulled out but this step had me stuck for a bit. Searching the webs, I discovered that there are little tabs on either side of the connector. I used my prod tool and poked one side and the connector came out a little. I poked the other side the connector came out without a fight.
    Peter Akey - Replica
    The instruction for this step state this but I was still not expecting two cables. Finally figured out there is a Display Power and a separate Display Data cable.
    wsrb - Replica
    As others have mentioned later on, it is not necessary to fully remove the screen or disconnect these cables. I managed with just the screen held wedged open with a small cardboard box.
    Jamie Bamborough - Replica
  20. Sostituzione SSD Blade iMac 27" 2017: passo 20, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 20, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 20, immagine 3 di 3
    • Solleva la piastra metallica che assicura il cavo dati del display.
    • Scollega il cavo dati dello schermo.
    • Questa è una connessione delicata che può rompersi facilmente. Assicurati di estrarre il connettore del cavo dati del display direttamente dal suo zoccolo, tirandolo verso parte superiore dell'iMac.
  21. Sostituzione SSD Blade iMac 27" 2017, Solleva lo schermo: passo 21, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017, Solleva lo schermo: passo 21, immagine 2 di 2
    • Solleva il display in posizione quasi verticale.
    • A questo punto ci sarà sempre una striscia di adesivo nella parte inferiore del display che lo terrà incollato alla scocca come una cerniera. Puoi allentare questo adesivo muovendo il display su e giù un po' di volte.
    After rocking the display back and forth a bit, I found it helpful to use my iMac opening tool to gently slide ever so slightly underneath the bottom of the glass to cut the adhesive. This was with the display lowered back into it its normal position. I just worked about 1 millimetre deep at a time and eventually cut through the ~8” adhesive strip at the bottom centre.
    Henry Rose - Replica
    It's possible to skip this step and go to step 24, leaving the display attached. You'll want to open the display just enough to replace the drive, with the machine upright and supported so the display doesn't swivel (I fold up a small pillow and wedge it in there). This way you don't have to worry about damaging the display when removing it, or aligning it when replacing it (which can be difficult to do solo as it's big and heavy).
    Using a T8 with a short handle is helpful here, and make sure it's well magnetized so you don't drop the screws for the hard drive (just leave the other ones in the speakers).
    maccentric - Replica
  22. Sostituzione SSD Blade iMac 27" 2017, Rimuovi l'adesivo rimasto: passo 22, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Rimuovi l'adesivo rimasto: passo 22, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Rimuovi l'adesivo rimasto: passo 22, immagine 3 di 3
    • Attenzione a non toccare i contatti dei condensatori o qualunque punto di saldatura esposto sul retro dell'alimentatore (riquadro rosso).
    • Prendi le piccole alette all'estremità di una delle strisce adesive sul bordo inferiore dello schermo e tirala verso il bordo superiore dell'iMac per rimuoverla.
    • Ripeti questo passaggi per l'altra striscia adesiva e rimuovila.
    • Se una delle due strisce si rompe prima di rimuoverla, usa una scheda in plastica per tagliare l'adesivo rimasto.
  23. Sostituzione SSD Blade iMac 27" 2017, Rimuovi lo schermo: passo 23, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Rimuovi lo schermo: passo 23, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Rimuovi lo schermo: passo 23, immagine 3 di 3
    • Fai attenzione a maneggiare il display - è grande, pesante e fatto di vetro. Il display ha i bordi fragili. Evita di sollevarlo dagli angoli.
    • Solleva il display dalla scocca e rimuovilo dall'iMac. Appoggia il display faccia in giù su una superficie piana e morbida.
    • Potrebbe essere necessario sollevare lentamente lo schermo da una parte per staccare l'adesivo rimanente.
    • Dopo che l'adesivo è stato tagliato, non può essere riutilizzato per riattaccare il display. Segui questa guida quando la tua riparazione sarà completa per sostituire le strisce adesive e assicurare il display alla scocca.
  24. Sostituzione SSD Blade iMac 27" 2017, Rimuovi la staffa di supporto: passo 24, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017, Rimuovi la staffa di supporto: passo 24, immagine 2 di 2
    • Usa un cacciavite a croce Phillips per svitare le nove viti da 3,2 mm che tengono ferma la staffa di supporto.
    • Potresti dover rimuovere l'adesivo dello schermo dal bordo inferiore dell'iMac per accedere alle viti.
    These are new steps from when I did this on my late 2015 retina iMac so I believe step 25 and 26 are optional (you can cope without doing it).
    Amuseme - Replica
    I did not find it necessary to remove these screws and this bar
    James Orwin - Replica
    I lost these 8 during the reassemble. The manual tells I need eight 3.2mm screws.
    Can anyone help to clarify what screws I need. I don't really understand this size. Is this M2x3mm?
    Daniel - Replica
  25. Sostituzione SSD Blade iMac 27" 2017: passo 25, immagine 1 di 1
    • Rimuovi la staffa di supporto inferiore dall'iMac.
    No comments on this ?
    It's quite possibly the most difficult part to put back in the entire process
    The screws are tiny and the there is no easy way to line up the holes on the bracket with the screws
    Having got this far - it wasn't even all that necessary to remove this part in the first place
    Severe pain in the neck
    Eoin - Replica
    After an hour of painstaking mess - I managed to get 7 out of the 9 back in
    By that time I could care less about the remaining 2
    Eoin - Replica
    With the right tools and technique, the bracket can easily be replaced in under a couple of minutes.
    Use a screwdriver with a magnetized tip which frees up one hand and place a screw on the tip first.
    Then line up the screw hole on just one end of the bracket and using a pair of tweezers from the side, hold the bracket in place while you put in the screw.
    Next, do the same on the other end of the bracket. After that, all of the screws in the middle are quick to replace. I didn't really have to touch the bracket again after the end screws were in place.
    Hope that helps someone else since removing this bracket does make later steps a bit easier.
    Max Z - Replica
    I used Max Z tweezers technique but screwed one screw in at the end and then worked my way to the other end.
    Stephen B - Replica
    Max & Stephen are correct. Not difficult at all if you start at the right end (either end, probably, but I liked staying away from the power supply), and use a magnetic driver.
    jiclark - Replica
  26. Sostituzione SSD Blade iMac 27" 2017, Rimuovi l'altoparlante sinistro: passo 26, immagine 1 di 1
    • Rimuovi due viti Torx T10 da 10 mm.
    I found i didn’t need to remove the speaker nor the hard drive. In fact I managed to remove the old PSU without even removing the chin strap. However, to install the replacement PSU, I had to remove the chin strap. So I would say, remove the chin strap, but you can optionally leave the speaker and hard drive in.
    Cool_Breeze - Replica
    While you do not need to fully remove the screws as once you loosen them a few turns the speaker becomes free. I found that after the removal of the speaker, I turned it over and popped the screws out as this made it easier to replace it later as I could see the alignment before putting the screws back in. If not you may be off a little and you do not want to force the screw back in.
    I used a pill container that I got from Walgreens to hold all of the fasteners I removed during the disassembly process. The container has 14 compartments (individual compartments for each morning and evening of the week). I put a small piece of paper in the compartment with the fasteners to note the name and step of the procedure and the size of the tool I used. Hopefully this will be useful when I go to put it back together again.
    Dan Smith - Replica
  27. Sostituzione SSD Blade iMac 27" 2017: passo 27, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 27, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 27, immagine 3 di 3
    • Disconnetti il cavo dello speaker tirandolo direttamente dalla sua porta sulla scheda madre. Stai attento a sfilare il cavo rimanendo in direzione dell'asse della presa.
    • Sfila il cavo dalla fessura tra l'hard drive e la scheda madre.
    • Se la fessura tra hard drive e scheda madre è troppo sottile per il cavo dell'altoparlante, disconnettilo e lascia il cavo dov'è.
    I didn’t unplug and de-route this cable. Later, Step 29, has you remove the left speaker. This isn’t necessary. If you can just move the speaker over to expose the hard drive mounting screws, so if you’re not going to remove the speaker, you don’t need to unplug it.
    Anthony Zimmerman - Replica
    on the 2019 iMac, it is horizontal not vertical so pull it horizontally out.
    tarex7 - Replica
  28. Sostituzione SSD Blade iMac 27" 2017: passo 28, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 28, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 28, immagine 3 di 3
    • Stai attento a non toccare nessuna saldatura sul retro dell'alimentatore. I condensatori potrebbero essere abbastanza carichi da darti uno shock elettrico pericoloso.
    • Usa uno spudger per disconnettere il connettore del pulsante di accensione dalla sua sede sulla scheda madre.
    Can someone explain what are the solder joint? Or tell me what it looks it?
    brianyu - Replica
    The silver spots on the circuit boards. You may not want to tackle this alone. If you touch these areas, you can possible get a shock -- harming you and your computer.
    Robert -
    there is no need to disconnect the speaker, just unscrew it and move aside slightly to reach the HDD screws (about 5mm) - if you want to replace just the main HDD
    Thomas Webb - Replica
    Take note of exactly what direction this tiny little wire was.
    Joseph Ashe - Replica
    The connector has a plain black side and the other side you can see the 2 silver connectors.. the side you can see the 2 silver connectors faces the front.. the plain side is to the back/against the logic board.
    paul.lynch1 -
    If I leave my iMac unplugged for an extended period, say 24 or 48 hours, is it still possible to get an electric shock from the PSU? Do the capacitors eventually discharge?
    Dominic Pettifer - Replica
    you can do this method, or just wear latex gloves.
    Philip Sedlmair -
    make sure you’ve actually unplugged the mac when running this cable, and not had it plugged in to test the diagnostic LEDs, because one of those wee silver spots is carrying 230v, and its 6mm away from the place the cable runs, So if you have fat fingers like mine, that’s a free wake up zap
    flow in - Replica
    I don't understand how people can say that you don't need to remove the speaker, unless all they were doing was replacing the SATA drive with a 2.5-inch SSD. If you're using this guide to replace the SSD on the back side of the logic board, you definitely need to remove all the components.
    jiclark - Replica
  29. Sostituzione SSD Blade iMac 27" 2017: passo 29, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 29, immagine 2 di 2
    • Solleva con attenzione l'altoparlante sinistro fino a quando il cavo del pulsante di accensione diventa visibile (1-2 cm).
    This is MUCH easier to do if the support bracket along the bottom is removed first. See Sostituzione scheda logica iMac Intel 21.5" Display Retina 4K (2017) step 25.
    Use a P00.
    To replace it, introduce it like in the photo at the link to be able to hold the right most holes of the chassis and bracket. Replace the first screw, align the bracket to the horizontal and add the screws from right to left. Each one will bring up the next hole in the bracket close enough to screw through. Reverse those directions if you are a leftie.
    Andrew Gough - Replica
  30. Sostituzione SSD Blade iMac 27" 2017: passo 30, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 30, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 30, immagine 3 di 3
    • Sfila delicatamente il cavo del pulsante di accensione dal suo incavo sull'altoparlante sinistro.
    Pay attention: if pulling out the loudspeaker tear off the wire of the power button, Apple have not any service parts except for the whole rear housing!
    Fabio Braga - Replica
    Use a P00.
  31. Sostituzione SSD Blade iMac 27" 2017: passo 31, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 31, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 31, immagine 3 di 3
    • Solleva l'altoparlante sinistro e toglilo dall'iMac.
    • Se la fessura tra hard drive e scheda madre è troppo sottile per liberare il cavo dell'altoparlante, tira fuori il cavo mentre rimuovi l'altoparlante.
    • Spingi dalla parte terminale del connettore mentre tiri dalla parte terminale dell'altoparlante per infilare il cavo sotto il supporto destro dell'hard drive.
    I found it wasn't necessary to remove the speaker from the left side to remove the hard drive. You can remove the screws, and then slide it over to the left — giving more than enough room to access the hard drive.
    Robert - Replica
    me too. don't need to remove it if you only want to change the hd
    Alber Einsten -
    Agreed, wast of time to fully remove the speaker.
    Matthew Gonzalez -
    It is difficult to remove the bottom of the speaker because it bends into the frame. Be careful to remove the power button cable, which also routes in a channel in the bottom of the speaker.
    Eric - Replica
    easier to remove the speakers if you unscrew the front ‘chin strap’ - 6/9 phillips screws that you can see in the picture hold that aluminum piece in place
    flow in - Replica
    Agree. This is MUCH easier to do if the support bracket along the bottom is removed first. See Sostituzione scheda logica iMac Intel 21.5" Display Retina 4K (2017) step 25.
    Use a P00.
    Andrew Gough -
    The trick with removing the left speaker is that you have to slide it up toward the top of the iMac (continuing to de-route the power button cable carefully as you go) to get it out from under the chin before you lift it up to remove it.
    ace - Replica
  32. Sostituzione SSD Blade iMac 27" 2017, Rimuovi il disco rigido: passo 32, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017, Rimuovi il disco rigido: passo 32, immagine 2 di 2
    • Tira verso l'alto il cavo dati/di alimentazione SATA per scollegarlo dal disco.
  33. Sostituzione SSD Blade iMac 27" 2017: passo 33, immagine 1 di 1
    • Svita le due viti Torx T8 da 7,3 mm che fissano la staffa sinistra del disco rigido alla copertura posteriore.
  34. Sostituzione SSD Blade iMac 27" 2017: passo 34, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 34, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 34, immagine 3 di 3
    • Prendi insieme il disco rigido e la sua staffa sinistra.
    • Allontana il bordo sinistro dalla copertura posteriore e fai scorrere il gruppo verso sinistra.
    • Rimuovi il disco rigido e la sua staffa sinistra dall'iMac.
  35. Sostituzione SSD Blade iMac 27" 2017: passo 35, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 35, immagine 2 di 2
    • Rimuovi la staffa sinistra del disco rigido.
  36. Sostituzione SSD Blade iMac 27" 2017, Rimuovi l'alimentatore: passo 36, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017, Rimuovi l'alimentatore: passo 36, immagine 2 di 2
    • Quando si lavora sull'alimentatore fai molta attenzione a non toccare i contatti dei condensatori o qualsiasi saldatura esposta sul retro dell'alimentatore. Maneggia la scheda solo dagli angoli.
    • Disconnetti il cavo di controllo dall'alimentatore.
    I found this cable very difficult to disconnect, be very careful because the cable is between a black tape and it's stuck very hard to the logic board and the cable is very short and you don't have space to move and separate it from the connection! Be patient and take the time you need
    MrSchaeffer - Replica
    I found than putting the flat end of the spudger at the center of the cable, and tilting it got the cable out without an issue.
    jimboom006 - Replica
    I was able to use the flat end of the spudger on the sides. You can see a tiny little clip on each side. Be very gentle!
    I simultaneously used the fingernails on my 2 index fingers to dislodge the tabs and continue to pull the cable out. It took a couple seconds.
    Eric - Replica
    ultimately the trick for me was to just pull hard enough, but that part is the scariest part. any tips welcome
    Boris - Replica
    These connectors seem pretty tough to remove until one understands the latch. Each side of the plug are two little sprung tabs (the tab is part of the spring clip which runs down the side of the plug on each side - makes sense once you see the removed plug!). Squeeze them in towards each other and then gently pull the plug from the socket. No great force, or even the spudger, needed once that is done.
    Pete Mackenzie - Replica
    One more tip, has worked on other cables for me. Fish the skinniest spudger tip you have under the cable, and with a finger of your other hand put opposite pressure on the cable against the spudger and gently work it out
    Mike Fleming - Replica
    If u are right handed, i can recomend to use your index left nail to press de bottom sprung, and a flat spudger on the right hand, came off so easy
    Davo Montiel - Replica
    Davo Montiel's tip worked for me. Use the fingernail on your left index finger to press in the tab on the bottom side of the connector and with the right hand use a flat spudger to press in the tab on the top side of the connector.
    Dan Smith - Replica
    If you have a insulated long nose pliers along with a splugger and can get underneath the cable WITH the long nose pliers on the RIGHT side of the cable, towards the logic board, with the splugger on the LEFT Side of the cable doing the same, you can get the leverage to GENTLY pull this cable out very easily.
    George Martinez - Replica
  37. Sostituzione SSD Blade iMac 27" 2017: passo 37, immagine 1 di 1
    • Rimuovi le seguenti 4 viti che fissano l'alimentatore al case (T8 o T10 a seconda del modello):
    • 2 viti Torx da 23,7 mm
    • 2 viti Torx da 7,3 mm
  38. Sostituzione SSD Blade iMac 27" 2017: passo 38, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 38, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 38, immagine 3 di 3
    • Non tentare di rimuovere l'alimentatore dal case; è ancora fissato alla scheda logica da due cavi.
    • Sposta la scheda dell'alimentatore verso il bordo sinistro del case e verso l'alto per liberarla dall'incavo nella scheda logica.
    Use a P00.
    The top right screw on the power supply actually screws into a stand-off screw connected to the back of the iMac case. Once you have removed the 4 x Torx 8 or 10 screws you can move the power supply enough to see the upper face of it.
    It has a Torx 25 slot in it and comes out easily. This will give you a lot more room for your fingers in Step 40, depressing the tab on the DC power cable connector to pull it out, and when replacing it on reassembly. You may find it won’t require you removing the support bracket as in the suggestion above.
    John Blagden - Replica
  39. Sostituzione SSD Blade iMac 27" 2017: passo 39, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 39, immagine 2 di 2
    • Premi la linguetta sul connettore del cavo di alimentazione DC, quindi estrai il connettore dalla sua presa sul retro della scheda logica.
    • Se il cavo è troppo difficile da scollegare, puoi rimuovere la scheda dell'alimentatore e la scheda madre insieme.
    Remember to push in the disconnect tab on the large connector. Carefully insert your finger and push on the tab before you pull on the connector.
    Manuel Collazo - Replica
    Thank you Manuel, this was a tricky one.
    David Zemsky - Replica
    Yes, I pulled the whole socket out because I didn’t know about the tab. Fortunately I was able to place it back in. Not sure if it was glued or how it was anchored but it seems to have a solid connection and I can’t easily pull it out by hand. Once I plug the power cable back in should be ok.
    P. Hisada - Replica
    This connector was very difficult for me to remove (even after pushing the disconnect tab). Eventually I had to use a pair of needle nose pliers to wiggle it back and forth out of the socket. A lot of the cables on the my late 2015 model were very tight and a struggle to get out.
    I'm struggling with this step. I presume that the tab to which you are referring is behind the connector. I can see a plastic protrusion there but it does not move when I push it. Just to get my finger behind it requires the power board to be moved quite a bit btw.
    Dave Sands - Replica
    Pressing on the release on the back with my finger and at the same time using a needle nose pliers to wiggle the connector with my other hand worked for me.
    Kimbo M - Replica
    i could not get it out by the force of my fingers, so what i did was slightly turn the imac 90 degrees so i could reach the area better, push up (so, vertically) the power control board, push in the tab on the bottom of the connector with my right hand, and slightly wiggle the connector out of its socket with a plier
    Boris - Replica
    removing the chin strap (the front bit of metal running along the bottom of where the screen was) makes this much easier as you can rotate the board and get to the underside
    flow in - Replica
    Left index finger pushing on the tab from behind the connector, using needle pliers in right hand to rock up & down did the trick thanks @starfleet_tone
    Frédérick Charette - Replica
    Just be careful! I’ve seen two systems where the socket was pulled fully off! So the logic board then needs repairs or replacing being just a bit too aggressive!
    Dan -
    Needle nose and wiggling worked for us too. We were stuggling like heck with it when just using hands!
    Mike Manasewitsch - Replica
    This is MUCH easier to do if the support bracket along the bottom is removed first - more space to angle the board upwards. See Sostituzione scheda logica iMac Intel 21.5" Display Retina 4K (2017) step 25.
    Use a P00.
    I did as Andrew Gough did, per other videos reviewed. Removed it right away. Just makes things easier, more space for just a few screws :)
    Mike Rehbein - Replica
    I used your suggestion to remove the stand-off and then used my left hand index finger to press the tab while rocking the connector side to side with a needle nose pliers. Plug came out easily.
    Dan Smith -
    The tab is a pain in the a$$$ to get your finger in there. I was so horrified at the size of the capacitors that I put on gloves to reduce any amount of shock :-) . To get it loose I would pull out carefully the power board as far as I could than I wedge my index finger under and press the tab and slowly pull until I saw a slight gap between the end of the socket and the plug. I than place the flat part of the black spudger or blue one into the gap and use as it as a wedge to help move the plug forward as I kept the tab pressed.
    Andrew Phillips - Replica
  40. Sostituzione SSD Blade iMac 27" 2017: passo 40, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 40, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 40, immagine 3 di 3
    • Fai molta attenzione a non toccare i condensatori o qualsiasi saldatura esposta sul retro dell'alimentatore. Maneggia la scheda solo dagli angoli.
    • Capovolgi verso di te la parte superiore dell'alimentatore per rivelare il connettore del cavo di ingresso AC.
    • Scollega il connettore del cavo di ingresso CA.
    To reassemble, do the same in reverse but keep power supply board more upright than slanted down when re-inserting it in to the lower right corner. The lower right screw post has an protrusion under/behind it and the Power Supply's small 2 wire plug must fit between the front of your Mac and the obstruction. Then it just slides right in and then screw it down.
    Dan H - Replica
    There is a small release tab on the cable.
    Eric - Replica
    Wear gloves when doing this to reduce any shock. The size of those capacitors are very unnerving and scary. Also those solder joints.
  41. Sostituzione SSD Blade iMac 27" 2017, Rimuovi lo speaker destro: passo 41, immagine 1 di 1
    • Svita le due viti Torx T8 da 9,8 mm.
    These are T10's, not T8's
    loren - Replica
    I had one shorter one screw, and one screw shorter than the other two equal size speaker screws, but longer than the stubby screw. :) And I can confirm that these are T10s.
    Patrick Vickers - Replica
  42. Sostituzione SSD Blade iMac 27" 2017: passo 42, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 42, immagine 2 di 2
    • Fai ondeggiare leggermente lo speaker destro verso destra per riuscire ad accedere al connettore del suo cavo sulla scheda madre.
  43. Sostituzione SSD Blade iMac 27" 2017: passo 43, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 43, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 43, immagine 3 di 3
    • Usa uno spudger per rilasciare il connettore del cavo dello speaker destro dalla sua presa sulla scheda madre.
    • Tira il connettore verso destra per scollegarlo dalla sua presa.
  44. Sostituzione SSD Blade iMac 27" 2017: passo 44, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 44, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 44, immagine 3 di 3
    • Solleva lo speaker e rimuovilo dall'iMac.
  45. Sostituzione SSD Blade iMac 27" 2017, Rimuovi la ventola: passo 45, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Rimuovi la ventola: passo 45, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Rimuovi la ventola: passo 45, immagine 3 di 3
    • Usa l'estremità a punta di uno spudger per scollegare i connettori dei cavi dalla presa nella scheda logica.
  46. Sostituzione SSD Blade iMac 27" 2017: passo 46, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 46, immagine 2 di 2
    • Distacca parzialmente il nastro adesivo nero che connette la ventola al condotto di scarico.
    • Lascia il nastro sul condotto di scarico: ti basta solo esporre la giunzione per liberare la ventola.
  47. Sostituzione SSD Blade iMac 27" 2017: passo 47, immagine 1 di 1
    • Rimuovi tre viti Torx T10 da 12,4 mm che fissano la ventola al case posteriore.
  48. Sostituzione SSD Blade iMac 27" 2017: passo 48, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 48, immagine 2 di 2
    • Rimuovi la ventola dall'iMac.
    Use a piece of tape around the antenna cables to keep them in the same order, makes reassembly a little easier.
    Walter Hayden - Replica
    On reassembly, start the fan power connector into its socket while you slide the fan in.
    ebay - Replica
    I left the antennas attached to the wifi card and removed the wifi card with wires attached. I accidentally broke one of the connectors on the wifi card and had to replace the entire card....
    S. Baxter - Replica
  49. Sostituzione SSD Blade iMac 27" 2017, Rimuovi la scheda madre: passo 49, immagine 1 di 1
    • Usa un cacciavite Torx T5 per rimuovere le due viti da 4 mm che tengono fermi i cavi delle antenne AirPort/Bluetooth.
    Rather than unscrew the antenna cables, I usually unscrew the screws on the board and slide out the whole AirPort/Bluetooth module, which means I need not keep track of which antenna cable goes where.
    johann beda - Replica
    Fully agree with comment of johann! I did it that way and was glad to not having to deal with the microscopic IPEX "coax" antenna connectors and order of them.
    I'd like to add that after removing the 2 screws, the wifi/bt module is still holding into these 2 holes with 2 metal pieces.
    Before pulling the module out of its socket, one has to slightly lift it away from the mainboard (maybe 1mm, so the metal pieces leave the holes).
    Thomas Waldmann -
    Confirmed. 2 T5 screws, and pull the board straight up out of its socket behind he motherboard. Leave all cables attached.
    ebay - Replica
    Fully agree. It is not only handy for order of cables but especially eliminates risk of damaging the quite delicate IPEX connectors on the broadcomm wifi/bluetooth board when removing and reconnecting later. This happened to me. It is a huge hassle to replace / repair.
    This should be main option!! Wish I read this comment first.
    Starting Genius - Replica
    Does anyone know if this board can be upgraded to Bluetooth 5
    Christopher C.S. - Replica
  50. Sostituzione SSD Blade iMac 27" 2017: passo 50, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 50, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 50, immagine 3 di 3
    • Usa la parte piatta di uno spudger per scollegare tutti i quattro connettori delle antenne dalla scheda AirPort/Bluetooth.
    • Ricordati la posizione originale di ogni connettore mentre ricolleghi i cavi. Da sinistra a destra, sulla scheda, i connettori sono collegati nel seguente ordine:
    • Il più a sinistra
    • Quello in alto
    • Quello sopra a destra
    • Quello sotto a destra
    TIP: Tape all 4 cables first to keep them in the correct position when re-assembling.
    Les Lesaca - Replica
    My 2019 i9 has a bluetooth/airport card that doesn't look like this and it is not removable like this image suggests. If you look in the service manual, you'll see that a service wedge is required to hold this card in position while removing the logic board. When I upgraded my machine I didn't know this and detached the cables as you describe. Once upgraded and rebuilt, bluetooth no longer functioned - although wifi did. This card cannot be replaced either as it is soldered to the board. A costly mistake for me meaning I now have to use a wired mouse. Apple supplies the service wedge to authorised outfits only but I would love to get my hands on one if anyone knows where I can get one. Thanks, Rich :)
    Richard Ellis McCallum - Replica
  51. Sostituzione SSD Blade iMac 27" 2017: passo 51, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 51, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 51, immagine 3 di 3
    • Questo è un connettore delicato che si può rompere facilmente.
    • Ruota verso l'alto la staffa di bloccaggio in metallo sul cavo della fotocamera iSight.
    • Sfila il connettore del cavo della fotocamera dalla sua presa, tirandolo verso la parte superiore dell'iMac.
  52. Sostituzione SSD Blade iMac 27" 2017: passo 52, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 52, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 52, immagine 3 di 3
    • Usa la parte piatta di uno spudger per scollegare il connettore del cavo della presa jack dalla sua presa sulla scheda madre.
    • Sposta delicatamente da parte il cavo.
  53. Sostituzione SSD Blade iMac 27" 2017: passo 53, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 53, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 53, immagine 3 di 3
    • Usa la punta di uno spudger per aprire, ruotandola, l'aletta di bloccaggio sul connettore ZIF del cavo a nastro del microfono.
    • Assicurati di star facendo leva sull'aletta di bloccaggio incernierata e non sulla presa.
    • Usa delle pinzette per sfilare delicatamente il cavo a nastro del microfono dalla sua presa.
    Make a 10x macro photo of that connection with a good camera (showing how far the ribbon cable is inserted into the connector) BEFORE opening/pulling and later AFTER reinserting/closing it. Then carefully compare the photos concerning how far the cable is inserted.
    The only mistake I made while fixing my iMac was not to fully reinsert that ribbon cable and thus the mic did not work at first.
    Thomas Waldmann - Replica
    ¿Porque en mi Imac no esta este conector? También he visto otras fotos en las que tampoco aparece este conector, hay varios modelos de placa base para el mismo año? Si este conector no lo tengo en mi placa base ¿Donde se conecta este cable ya que me ha quedado suelto en la carcasa y ahora no funciona el microfono interno y no veo donde estaba conectado antes. Gracias!
    Javier Blf - Replica
    Es el conector del micrófono y no en todos los modelos viene así, las 2017 y 2019 así lo tienen, no se que otro modelo viene como en la foto.
    Pksin - Replica
  54. Sostituzione SSD Blade iMac 27" 2017: passo 54, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 54, immagine 2 di 2
    • Svita le seguenti viti che tengono ferma la scheda madre:
    • Due viti Torx T8 da 23,7 mm
    • Una vite distanziale Torx T25 da 20,1 mm
    • Una vite Torx T8 da 17,6 mm
    • Una vite Torx T8 da 7,2 mm
    • Tre viti Torx T8 da 7,1 mm
    • Una vite imperdibile Torx T8
    • Questa vite è dietro un foro nella scheda madre. Se non stai usando una cacciavite iFixit, potresti dover usare una prolunga o un cacciavite con un collo più lungo.
    A 3.0 Hex driver worked for the T25 spacer screw.
    1/8” hex worked, too
    ebay - Replica
    For the T25 I used a regular chisel tip screw driver that was exactly the width between two opposite sides of the Torx star
    The standoff is only screwed in by two or so turns and came out very easily for me
    So you shouldn't have to force it and damage threads
    Eoin - Replica
  55. Sostituzione SSD Blade iMac 27" 2017: passo 55, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 55, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 55, immagine 3 di 3
    • Tira il cavo SATA del disco rigido e il connettore attraverso la staffa destra del disco rigido. Sposta il cavo alla destra dell'iMac, lasciando libera la porta dello scarico.
    • Non cercare di rimuovere del tutto il cavo: non può ancora essere rimosso, ma intralcerà la rimozione della scheda madre.
    When reassembling one should not "pull it through the right bracket", but rather "pull it through between the right bracket and the case".
  56. Sostituzione SSD Blade iMac 27" 2017: passo 56, immagine 1 di 1
    • Usa un cacciavite Torx T8 per svitare le due viti da 5,6 mm dalla parte superiore del condotto di scarico del dissipatore.
    For the life of me I jut could not get these two screws to go back in neatly
    I had the same issue on both a 2017 and 2019 iMac 5K
    After some thinking I realised the don't do much anyways so I left them out
    No harm was done to either machine
    Eoin - Replica
  57. Sostituzione SSD Blade iMac 27" 2017: passo 57, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 57, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 57, immagine 3 di 3
    • Mentre rimuovi e installi la scheda madre, stai attento a non danneggiare il delicato cavo a nastro del microfono in basso a sinistra sulla scheda.
    • Inclina leggermente in avanti la scheda.
    • Solleva la scheda madre e rimuovila dall'iMac. Stai attento a non rompere nessuna delle prese per le viti fissate all'interno della copertura posteriore.
  58. Sostituzione SSD Blade iMac 27" 2017: passo 58, immagine 1 di 2 Sostituzione SSD Blade iMac 27" 2017: passo 58, immagine 2 di 2
    • Mentre rimonti il tuo iMac, stai molto attento ad allineare correttamente le porte I/O esterne. La scheda può essere storta anche con tutte le sue viti avvitate.
    • Puoi usare una chiavetta USB o un cavo ethernet per assicurarti che la scheda madre sia posizionata correttamente mentre la avviti.
    Insbesondere die USB3.1 Port sollten mit einem Stecker belegt werden! Ich habe nur die USB3.0 (A?) Ports mit Steckern belegt und konnte nach dem Zusammenbau alle Port benutzen, aber nicht die USB3.1 (C) Ports. Am besten überall einen Stecker rein.
    Boris Boesler - Replica
    Boris is correct. I reassembled mine usig the USB3.1 ports for alignment and found that my USB-C plugs would not go in. Be sure to use USB-C ports for alignment!!!
    Please update the instructions with this information.
    Erik - Replica
    Confirmed. Used the rightmost USB-C and the leftmost USB-A connector and it aligned perfectly.
  59. Sostituzione SSD Blade iMac 27" 2017, Cavo SATA: passo 59, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017, Cavo SATA: passo 59, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017, Cavo SATA: passo 59, immagine 3 di 3
    • Tira verso l'alto il connettore del cavo SATA per scollegarlo.
    • Scollega il connettore del cavo SATA sganciando la sua aletta di bloccaggio e tirandolo verso l'alto sul connettore.
    • Rimuovi il cavo SATA dal gruppo della scheda logica e spostalo in un punto dove non interferisca per prevenire un eventuale danneggiamento.
    Where is this cable sold
    mert - Replica
    Is this picture correct with 7 pins? Or is it form the 5k version? (See comments on that case below).
    There is an cable on eBay with 5 pins.
    Steve Nilsen - Replica
    This guide was written the year before the 5K model first came out. The cable in the photo is definitely for the model listed, although it’s always possible Apple made more than one variation.
    Jeff Suovanen -
    Hey, if you got this far and your iMac is getting along in years, maybe pick up a BR2032 battery and replace the PRAM battery while you’re at it, as you have to get to this point to access it.
    Tom - Replica
    I'm waiting on the battery now! I have a CR2032 in the house, but I looked them up, and they're too different to make me comfortable using one. And I accidentally ordered the BR3032, AAAGH. Sigh. Stupid Amazon put them side by side, and I clicked on the wrong one. :) Must've been Amazon's fault. :) But for sure, I was looking at my computer in pieces, and I looked at that battery, and I thought, wait, when was this thing built? 2017? Um. Might be time for a change.
    Patrick Vickers -
    TOM...on the 2019 5K 27" IT'S NOT a BR2032 battery!! It's a smaller diameter Panasonic BR1632A. You will break the cradle that holds the battery if you try to force in the bigger sized BR2042
    Macrepair SF -
    Tom, great tip on the battery. I put a new one in my 3½ year old iMac.
    Dave Hoppenrath - Replica
    Could have used a warning that this cable is not present in models that shipped with a SSD. I was replacing my blade SSD and adding a new SSD at the same time, only to find that I was missing this cable while my iMac was in pieces. Had to reassemble it without adding the SATA SSD, major hassle.
    Matt Stamm - Replica
    This is a bit of a grey space.
    Clearly you don’t need the cable if you are replacing the HDD or switching it out of a SSD. Its only when you are enhancing your system by adding a drive which you didn’t have before.
    Dan -
    Hello congratulations on your ssd blade upgrade. Have you used the owc blade or a samsung + adaptor? Regarding the cable, do you know if we can buy the cable and plug it into the logic bard so to add another ssd in the aluminum frame ? thanks a lot have a niceday
    Patrick -
    @patrick7508 - I encourage you to stick with a pin-compatible drive not use a M.2 adapter as they are not reliable and some drives are not compatible. Stick with a real Apple drive or OWC. Just think of the work you needed to do just to get to the drive.
    Dan -
  60. Sostituzione SSD Blade iMac 27" 2017, SSD Blade: passo 60, immagine 1 di 1
    • Rimuovi la singola vite Torx T8 da 5,3 mm che fissa l'SSD alla scheda logica.
    What type och screw is this? I just need the measurements, is it a standard M-size screw?
    Peter - Replica
    Did you find out any details about the screw in the end?
    djones -
    I am also searching for the right screw. There wasn’t one there before as there was no M.2 SSD there before (late 2015 iMac with HDD configuration). It’s definitely smaller than the T8 Torx’s I have been taking out so far.
    Boris -
    I bought the 1TB PCIe SSD for my 5K iMac (late 2015). Worked like a charm without any hiccups; great vendor: https://beetstech.com/product/solid-stat...
    Shaheen Ghiassy - Replica
    I have bought an iMac 2015 with 3TB Fusion drive, from which the SSD blade was out of order.
    A serviceman had split the Fusion drive and the iMac ran on HDD only. Awfully slow...
    On the top of it the boot time was very long since the bootloader waited 3 minutes for the defective SSD to show up.
    Since I had an Apple 121GB blade from an upgrade on a Macbook Air I replaced the SSD.
    Now my iMac boots directly from the 121GB blade (AFPS), lightning fast. The 3TB HDD is HFS+ and holds my user files and Time Machine.
    Laszlo Lebrun - Replica
    Does the 5K iMac (late 2015) with 1TB mechanical hard drive have this PCIe port?
    zi xie - Replica
    Reference this guide for the 2015 system Sostituzione SSD Blade iMac Intel 27" Retina 5K Display
    As far as what you have many of Apple systems have a Fusion Drive which is a dual drive setup a 1TB SATA HDD and a blade SSD (like this one) which is a small 128GB drive which is used as a Cache drive to speed up the I/O of often access data blocks (file/s)
    Dan -
  61. Sostituzione SSD Blade iMac 27" 2017: passo 61, immagine 1 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 61, immagine 2 di 3 Sostituzione SSD Blade iMac 27" 2017: passo 61, immagine 3 di 3
    • Per evitare di danneggiare il connettore, non alzare l'estremità dell'SSD più di circa 15°.
    • Solleva lievemente l'estremità dell'SSD e tiralo direttamente fuori dal suo zoccolo sulla scheda logica.
    • Durante la reinstallazione dell'SSD, assicurati che sia posizionato correttamente prima di reinstallare la sua vite di fissaggio.
    this ssd is not for a late 2013!
    this is 2012 year
    cslbox - Replica
    What do you mean? I'm going to buy a ssd to add it in my imac 27 late 2013 the came without it.
    Which part I need?
    MrSchaeffer -
    I think what he meant to say is the SSD shown (Samsun) is for a late 2013. The 2014 iMac uses a Sandisk unit (see the 5k teardown).
    Ifixit have made the mistake of referencing the late 2013 iMac teardown photos here.
    Brent -
    Not get confused! Apple used different vendors of their SSD’s both SanDisk & Samsung supplied SSD’s in this series.
    Dan -
    Which SSD is used in this tutorial?
    Lok - Replica
    For the 2012 iMac 27”, I can confirm the Blade SSD is an 8+18 pin SSDD and I believe this is a SATA drive, NOT a PCIe (NVMe) drive. I took my 2012 apart to try to add an NVMe drive with 2013 macbook adapter, and it does not fit. I didn’t have an adapter that worked so I just replaced the 3.5” HDD with a 2TB SATA 2.5” SSD and left the blade slot empty.
    The SSD drives available from OWC have speeds consistent with SATA drives, so I think the benefit of replacing or filling the blade slot are pretty minimal unless you’re really trying to maximize your available storage space, in which case it’s likely better to invest in an external or network attached solution.
    TL;DR 2012 iMac is an 8+18 pin setup that is likely SATA, not PCI-E so just replace the HDD with a big SATA drive.
    Jakegub - Replica
    Steve Arkwright -
    @starkoman Steve - The 21” system doesn’t always have the Blade interface populated, only the Fusion Drive or if you ordered the custom build with the blade SSD only option.
    Dan -
    Here’s a good source of info The Ultimate Guide to Apple’s Proprietary SSDs And BeetsTech is a good source for the SSD’s
    Dan - Replica
    iMac 27” 2019!
    I did it ;-) and ist works fine … but I had no microfon after reinstall. I had put the adhesive strips over the mic holes.
    So I need to open again with a new pair of adhesive strips ;-)
    I Have installed a Samsung NVME SSD 970 EVO 1TB with the “long” sintech adapter and a Sandisk Ultra SSD 2TB (SATA).
    Matthias - Replica
    I am about to do this to my 27” late 2015. Haven’t decided on which Blade SSD to use yet. But I have bought af Crucial MX500 2 TB SSD SATA.
    I have read a lot of problems with the Samsung NVME SSD 970 EVO.
    Also read a lot about needing a SATA cable from OWC (OWCDIDIMacHDD12) In-Line Digital Thermal Sensor for 27-Inch iMac, to ensure the fann does not spin uncontrollably.
    Have you had any problems with your setup with the Samsung SSD, and did you use the OWC cable ?
    Lars -
    I also did it with the same adapter, ordered for a few bucks from china.
    I’m usign the 970 EVO Plus 1TB, they have updated the firmware and it works out of the box.
    The firmware for older models can be updated directly on the mac with the updater from Samsung (can be installed on a USB stick and used to start the mac with it)
    The standard 970 EVO does not have had the firmware issues, just the Plus had in the past.
    For the blade SSD no OWC cable is required, that is only if a SATA-HDD is replaced by a SATA-SSD, thats a completely different thing.
    maccy -
    Is there supposed to be a heatsink attached to the replacement drive? I don't recall receiving one in the OWC package and I am seeing temps hitting 190 F (almost 88 C) under heavy load.
    Maurice Volaski - Replica
    No heat sink on the blade SSD, you could add one but it won’t really change what you are facing here.
    It does sound like your SSD maybe to small (and/or your system needs more RAM) given what you are doing.
    Keep in mind boot drive (SSD here) is used for virtual RAM, caching and depending on the app scratch space. You want to leave at least 1/4 of the drive empty for best performance. 256 GB or smaller drives will need 1/3 reserved.
    Dan -
    How to boot the system after replacing the ssd? Where is the recovery partition? I have followed all the steps but the screen is black and not even the question mark is displayed.
    LETRA - Replica
    Then you have an issue with your installation as you should be treated with a flashing question mark. Check your displays connections and maybe see if an external display works. Did you use the proper tools and technique within the guide to lift the display off? Many people have damaged the display in the process if they don’t follow the guide to the letter.
    Dan -
    Installed a 2019 SSD in my late 2015 iMac retina, purchased from fast_macs on eBay AOK with nearly 1900MB/s write 1800MB/s read (ish). Also installed Apple 2TB drive too whilst I was doing it.
    Amuseme - Replica
    The 2017 and 2019 SSDs should be the same (or very similar). Both are SSPOLARIS and the same generation. I’m in the middle of doing the same on mine (mid 2017), going from a 2TB Fusion to a straight 1TB blade.
    I purchased this one, based on the excellent feedback:
    https://www.ebay.com.au/itm/144429279418...
    orrelljet -
    If I install a new 2TB SSD to replace my HDD (2019 imac 27), do I have to install a new logic board SSD? I’d rather not have a fusion config any longer (S/W seems buggy - hence my fusion drive problems). I’d much rather have just the new 2TP SSD in place of the old HDD, if possible?
    Chuck Lott - Replica
    Replacing your SATA HDD for a SSD makes a lot of sense! Any size will work.
    You should pull the blade SSD which was mated to the HDD to create the Fusion Drive pair.
    Dan -
    Thanks Dan - blade SSD to be discarded!
    Hola. Quería saber que iMacs de 27” pulgadas llevan ese tipo de conector M2. Gracias
    Jorge Yerbito - Replica
    @chucklott I'm in the same situation as you were. I have a new 2.5" SSD in-hand and would like to just use that, and pull the existing blade SSD out. I think I have to purchase a SATA cable though, because the iMac doesn't appear to come with one. Is that what you did too? Any other issues that you encountered with your fix?
    kevinthoeng - Replica
    Depending on what your system was configured with for drives you may have the needed cables.
    The low end config came with a SATA HDD as such you will have the needed SATA cables
    If you bought the Mid tier config then you have a Fusion Drive which is really two physical drives the SATA HDD as well as a small blade SSD which is used as a cache drive (not visible from within the OS or Disk Utility as a mountable volume) again you will have the SATA cables. But you will need to remove the blade SSD as it gets in the way.
    The last config is the high end which is where a much larger blade SSD is installed this is the only config that will require a SATA cable.
    These setups are independent of the CPU/GPU the system also offered.
    Dan -
    I’m petty sure it would be simply faster and easier to cut out a “door” above the IO ports using a Dremel and a small cutting disk. Might not be as neat and tidy but would certainly get the job done.
    cyberlizard - Replica
    @cyberlizard - While it would have been nice to have a hatch to gain access to the RAM or the SSD, your solution would more likely kill the system between the act of blindly cutting/drilling and then all of the metal dust and crumbs getting into your logic board shorting things out would be a sizable risk. Even if you took the system apart why would you just pop in the RAM or SSD and call it a day then wasting time, still not getting the hole quite right and still have enough room to do the task
    Dan -
    merci de cette aide et accompagnement dans la maintenance du matos.
    larbi lakehal - Replica
Conclusione
Confronta la tua parte di ricambio con quella originale: potrebbe essere necessario il trasferimento di alcuni componenti o la rimozione di protezioni adesive dalla nuova parte prima di installarla.
Per riassemblare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Porta i tuoi rifiuti elettronici a un riciclatore certificato R2 o e-Stewards.
La riparazione non è andata come previsto? Prova delle soluzioni di base ai problemi, oppure rivolgiti alla nostra comunità Risposte per trovare aiuto.
Altre 48 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Adam O'Camb
Membro da: 04/11/15
212.004 Reputazione
416 Guide realizzate
11Commenti sulla guida
is there any way to replace the I.O without swapping the motherboard?
Crystal Haugh - Replica
From cutting through the adhesive to the smoke test this was just under a four hour job for me. One adhesive strip left a complete layer of glue on one side of the screen, and it took me the better part of an hour, about half my supply of wipes, and a plastic razor blade just to clean that one edge up. I’d break the time down as: removing, cleaning, or reapplying adhesives, 2 hours; non-adhesive disassembly, 50 minutes; reassembly, 40 minutes; “oh crap, where’s that tool?” 15 minutes; and about 10 minutes for cleanup, including vacuuming out the fan, heat sink, and vents.
Ed Poe - Replica
Hi there, I need your professional help. I followed all instructions to change my iMac 2017 27" 5K fusion drive with a Samsung EVO 970 PLUS 2TB (with upgraded firmware) for macOS bootable drive and extra EVO 860 SSD 4TB data drive. Then updated to Monterey. My first test was 1200w 2900r, which was different from the youtube video which was roughly 3Krw. Why was that? Then after a few days of work, the mac froze during youtube watch and again during excel spreadsheet, and restarted with a "?" in a folder. I made an online hardware check all OK, then performed first aid, and again all OK. Then rebooted to the same "?" screen. And then rebooted again and now it works. So far! I see in the system prefs - Link Width x1. I made the speed test again and the reading now is roughly 700rw. Screenshots and sys error report bellow. What have I done wrong? And what to do to fix it all? Thanks!
Peter Lane - Replica
Did anyone already thought or experienced to just cut out a square at the back of the frame? its not elegant but my imacs back just faces the wall :) for thermal reasons i can imagine just to stick it back.
dave777 - Replica
It's a shame Apple couldn't manage to put this on the front of the logic board--such a pain (by design).
maccentric -
Hi, I'm about to change my SSD as well. But I'm unsure because of the slot. In the pictures the slot is almost in the center. But on the Samsung 970 EVOPlus, the slot is almost on one side. Does anyone therefore know it this product will work?
https://www.digitec.ch/de/s1/product/sam...
I have the iMac 2017 27" 5K model with a fusion drive.
Simon Boonstra - Replica
Think that a screw part uninstall was missing, it will hold the motherboard in, until you remove it. Located at the bottom of the hard drive bracket, Requires a T20 to remove it. Then the motherboard come out easily as the instructions state. I'd post a photo, but can't on this comment section. My Mod for a customer, is to remove the "fusion", replace that PCIe "blade" with a 2TB from OWC. Reformat the internal 1TB hard drive to be used as extra storage or backup. The screw could have been referred to as : One 20.1 mm T25 spacer screw, mine was a T20. Perhaps there are some differences in models.
Carl Schultz - Replica
SSD type:
Looked at other options (OWC, Samsung/WD M.2 + sintech adaptor), then went with a used original Apple "Polaris" SSD:
- Apple seems to install firmware when upgrading macOS and there have been reports about it stumbling over 3rd party SSDs.
- M.2 adaptors seem to have insulation issues, requiring adding capton tape to avoid short circuiting with the mainboard connector shield.
- Samsung M.2 SSD controllers seem to have compatibility issues with macOS. There were recommendations to rather go with WD SSDs.
- A lot of currently (2024) available WD M.2 SSDs are not listed as compatible with the sintech adaptor. The ones listed as compatible are not available any more.
Original Apple SSD was expensive (per GB, but ok at 40 EUR for 512GB used), but it seemed like the only way to avoid all issues.
First tried an external SSD (with a realtek USB-C-PCIe bridge) and install macOS, Windows, Linux onto that:
- slow macOS boot (3mins)
- unsupported by bootcamp
- unsupported by w10 installer
- 1 USB-C port occupied
Major surgery, but not too bad if you're familiar with all the different types of connectors. FYI, the screw that's behind the logic board (accessed through the hole in the middle of the board), mine stayed in the bracket after it was unscrewed. The instructions implied that we needed to pull that screw out through the hole, but you might not need to, as I didn't.
Thanks, great guide!
jiclark - Replica
Just performed this on my old iMac that failed. External booting from SSD worked but I had to disable the internal disk as soon as I booted or else the machine hung.
Got the iFixit kit for this and just followed the instructions to replace the Blade disk Some of it is a bit fiddly, and replacing the "chin strap" wasn't obvious, since I didn't remember exactly how it was positioned, but eventually worked it out.
As long as you're methodical, I can recommend trying it - but make sure you have the correct tools.
Now have a working iMac again, so thanks for the tutorial.
ifjimmy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 156
Ultimi 30 Giorni: 764
Tutti i Tempi: 50,955
