Salta al contenuto principale
Samsung Galaxy A32 5G Battery Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch e un altro collaboratore
Ultimo aggiornamento il September 28, 2024
45 minuti - 1 ora
Moderato
Guida In Evidenza
Introduzione
Vai al passo 1
Use this guide to replace a worn-out or dead battery in your Samsung Galaxy A32 5G.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach components when reassembling the device.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Samsung Galaxy A32 5G Battery Replacement, Heat the back cover: passo 1, immagine 1 di 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy A32 5G Battery Replacement, Slice the adhesive: passo 3, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Slice the adhesive: passo 3, immagine 2 di 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A32 5G Battery Replacement, Slice the adhesive: passo 4, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Slice the adhesive: passo 4, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Slice the adhesive: passo 4, immagine 3 di 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Samsung Galaxy A32 5G Battery Replacement: passo 5, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement: passo 5, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A32 5G Battery Replacement: passo 6, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement: passo 6, immagine 2 di 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  7. Samsung Galaxy A32 5G Battery Replacement, Remove the back cover: passo 7, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Remove the back cover: passo 7, immagine 2 di 2
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Samsung Galaxy A32 5G Battery Replacement, Eject the SIM card tray: passo 8, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Eject the SIM card tray: passo 8, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Eject the SIM card tray: passo 8, immagine 3 di 3
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  9. Samsung Galaxy A32 5G Battery Replacement, Unfasten the midframe screws: passo 9, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Unfasten the midframe screws: passo 9, immagine 2 di 2
    • Use a Phillips screwdriver to remove the sixteen 4.1 mm-long screws securing the midframe.
    It would be useful to show a picture,here, highlighting the 7 screws below the battery that also require removal.
    Robin Lewis - Replica
  10. Samsung Galaxy A32 5G Battery Replacement, Disconnect the power and volume button flex cable: passo 10, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Disconnect the power and volume button flex cable: passo 10, immagine 2 di 2
    • Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
  11. Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 11, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 11, immagine 2 di 2
    • The midframe of the Samsung Galaxy A32 5G is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the left edge of the phone where the SIM tray slot is located.
  12. Samsung Galaxy A32 5G Battery Replacement, Release the plastic clips: passo 12, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Release the plastic clips: passo 12, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Release the plastic clips: passo 12, immagine 3 di 3
    • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
    • Slide the opening pick along the left edge of the phone to release the plastic clips.
  13. Samsung Galaxy A32 5G Battery Replacement: passo 13, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement: passo 13, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement: passo 13, immagine 3 di 3
    • Slide the opening pick around the bottom left corner.
    • Slide the opening pick along the bottom edge of the phone to release the plastic clips.
  14. Samsung Galaxy A32 5G Battery Replacement: passo 14, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement: passo 14, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement: passo 14, immagine 3 di 3
    • Slide the opening pick around the bottom right corner.
    • Slide the opening pick along the right edge of the phone to release the plastic clips.
  15. Samsung Galaxy A32 5G Battery Replacement: passo 15, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement: passo 15, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement: passo 15, immagine 3 di 3
    • Slide the opening pick around the top right corner.
    • Slide the opening pick along the top edge of the phone to release the remaining plastic clips.
  16. Samsung Galaxy A32 5G Battery Replacement, Remove the midframe: passo 16, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Remove the midframe: passo 16, immagine 2 di 2
    • Place your phone with the display facing downwards on your working surface.
    • Remove the midframe.
  17. Samsung Galaxy A32 5G Battery Replacement, Disconnect the battery cable: passo 17, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Disconnect the battery cable: passo 17, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  18. Samsung Galaxy A32 5G Battery Replacement, Disconnect the display cable: passo 18, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Disconnect the display cable: passo 18, immagine 2 di 2
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
  19. Samsung Galaxy A32 5G Battery Replacement, Loosen the battery adhesive: passo 19, immagine 1 di 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath the battery. Apply the iOpener for at least five minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • Do not apply heat directly onto the battery as doing so is a potential safety hazard.
  20. Samsung Galaxy A32 5G Battery Replacement, Free the battery: passo 20, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Free the battery: passo 20, immagine 2 di 2
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Fold the display flex cable towards the charging port in order to get free access to the battery.
    • You might want to use a small piece of tape to temporarily stick the cable onto your working surface to avoid accidentally damaging it during the battery removal.
  21. Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 21, immagine 1 di 2 Samsung Galaxy A32 5G Battery Replacement, Insert an opening pick: passo 21, immagine 2 di 2
    • The battery adhesive of the Samsung Galaxy A32 5G is strong. If you can't manage to remove the battery by only using your iOpener, you can apply a few drops of high concentration isopropyl alcohol (over 90%) into the gaps between the battery and the midframe.
    • If you're using isopropyl alcohol let the alcohol penetrate the battery adhesive for at least two to three minutes before removing the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • For this step, insert the opening pick into the edge with a wider gap between the midframe and the battery so that you have more space for the opening pick and get a better leverage.
    • Insert an opening pick into the gap between the edge of the battery and the frame.
  22. Samsung Galaxy A32 5G Battery Replacement, Slice the battery adhesive: passo 22, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Slice the battery adhesive: passo 22, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Slice the battery adhesive: passo 22, immagine 3 di 3
    • Slide the tip of your opening pick underneath the edge of the battery.
    • Slide the the opening pick along the edge of the battery to slice its adhesive and to widen the gap between battery and frame.
  23. Samsung Galaxy A32 5G Battery Replacement, Insert a plastic card: passo 23, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Insert a plastic card: passo 23, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Insert a plastic card: passo 23, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • In case you're struggling to insert a plastic card apply more heat to the screen and/or isopropyl alcohol around the battery and try again.
    • Insert a plastic card at the edge you priorly worked with your opening pick.
    • Slide the plastic card underneath the battery.
    • Use the plastic card to slice the adhesive underneath the battery and pry it up.
  24. Samsung Galaxy A32 5G Battery Replacement, Remove the battery: passo 24, immagine 1 di 3 Samsung Galaxy A32 5G Battery Replacement, Remove the battery: passo 24, immagine 2 di 3 Samsung Galaxy A32 5G Battery Replacement, Remove the battery: passo 24, immagine 3 di 3
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 11 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
118 Membri
19.552 Guide realizzate
9 Commenti
Thanks for this tutorial. I was dismayed to learn that Samsung has followed Apple down this path of selling phones with sealed batteries that can't be quickly replaced by just popping off the back and dropping in a new battery. It seems crazy to me that phones that cost $500 to $1200 are considered to be so "disposable" that they're being manufactured without any consideration, that it might be better to just replace a $20 battery and get 5 more years of use out of the phone, instead of adding even more e-waste to the burden of responsibly recycling the tens of millions of unwanted phones, tablets, and laptops that are already ending up in landfills. This battery replacement, while technically "possible", looks far too difficult for the average cell phone owner who isn't a professional small-electronics repair technician.
LAURA-ANN CHARLOT - Replica
Could not have said it better myself 100% agree
Xgred -
This is ridiculous! My phone cost almost $300, and around a year later, the battery can't hold a charge more than 24 hours! It used to last 3-5 days! I live on Social Security, and can't afford to throw money around like crazy. I stayed away from cell phones for over fifteen years because their operating systems were written by morons and idiots, but now it's so ridiculous you can't FART ubless you have a smartphone. I don't call this progress.
William Kuns - Replica
The tutorial is helpful, and also the tools, but there is no answer to the most important question - where to buy original battery.
Dimiter - Replica
I got one from eBay, Now I need to source the tools so i can do this proper
Redacted “Case” -
The tutorial is helpful, and also the tools suggested are good. My email address is ipi38482@gmail.com. Can someone advise me how to order
the necesary items. I see someone bought a bettery from ebay. I would prefer an online order application. Regards Ian.
Ian Pilgrim - Replica
Way too complicated, by the time you add the cost of necessary tools and the actual battery, you might just as well buy a new phone. Hence, buy the cheapest phone you can get and just throw the old phone in the dumpster. And don't worry about the environmental impact it has. Apparently Samsung doesn't care, so why should I? I'm going back to Motorola, at least you can change the battery out easier. I've never been happy with my Samsung phone, cheap crap as far as I'm concerned.
Joshua Kincaid - Replica
Samsung wants to keep customers buying replacement phones indefinitely. Same idea as Microsoft replacing the Operating System every few years to keep customers to buy new computers with the new Operating System. The cell phone companies are making phones with smaller components that forego convenience for the owner. I see the same problem with the newer Motorola phones as well. Only those from over five years ago had a replaceable battery. The last model with one that I have is the Moto E6 model with a replaceable 3000 mAh battery. I am not aware of any phone with a 5000 mAh battery that is easily replaceable if you are looking for extended power usage.
e s -
Solid guide, but %#*@ that looks like a royal pain in the ass. I came here because 1. Ifixit guides are usually solid, and 2. They usually have an option to purchase oem or 3rd party products that ifixit offers a warranty on.
That said, I'm with the other users that an oem replacement battery would be ideal, or at least one that ifixit stands behind. Buying a battery off of eBay, Amazon, aliexpress, etc. isn't ideal to me. I don't want to do all the work to replace an old battery with some inferior product that only lasts a few months, or worse, catches on fire. Thanks for the guide though. I'll definitely refer to it if I go the repair route.
Daniel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 21
Ultimi 7 Giorni: 130
Ultimi 30 Giorni: 611
Tutti i Tempi: 23,976
