Salta al contenuto principale
Indice dei contenuti
Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Keys on Keyboard Won’t Function
Keyboard is unresponsive or certain keys are not working.
Filter Keys Is Enabled
Click the start menu at the bottom left of your screen, then click Settings. Click Ease of Access. Click keyboard. Check to see if the Filter Keys option is enabled. If enabled, turn off and test your keyboard to see if the problem has been fixed.
Outdated IO Driver
Click the following link to the Acer website for device support. Click Menu, then click Drivers and Manuals. Click the Driver tab and download the Serial IO Driver. Go to the start menu, search for Device Manager. Click on the application that shows up in the search results. Go Keyboards. Click on your keyboard, go to the Driver tab, and click Update Driver. Select the driver you downloaded earlier, then restart the computer.
Faulty Keyboard
You may need to replace the keyboard. Learn how to remove and replace the keyboard here.
Device Overheating
Device becomes abnormally hot for no apparent reason.
Outdated Turbo Boost Driver
Click the following link to the Acer website for device support. Click Menu, then click Drivers and Manuals. Click the Driver tab and download the Turbo Boost Driver (Broadwell). Run the installation program. During the installation, select the Repair option. Restart the device.
Faulty CPU Fan
A malfunctioning CPU fan may be causing the CPU to overheat and not work properly. Learn how to remove and replace the CPU fan here.
Faulty Battery
You may need to replace the laptop battery. Learn how to remove and replace the battery here.
Slow Processing Speed
Laptop is all around slow and sluggish in performance.
Too Many Startup Applications
Unwanted startup applications may be slowing down your system. Click the start menu at the bottom left of your screen. Search for system configuration and run the System Configuration application from the search results. Click on the startup tab and click Open task manager. From here you can right click on any application and disable it from opening every time you start your system.
Too Many Performance and Appearance Options Enabled
Click the start menu at the bottom left of your screen and search for system. Run the System application from the search results. Click Advanced system settings on the left hand side of the screen. On Advanced tab, click on Settings... underneath Performance. From here, you can choose which options you wish to keep or disable. The more options you disable, the less strain that will be placed on your system. Once you've selected all of the options you want to disable, click OK.
Short Battery Life
Laptop battery will drain abnormally fast and hold little to no charge.
Uncalibrated Battery
Shut down the laptop, plug in the power cord, and wait until the charging LED indicates that the laptop has a full charge. Once this is done, start up the laptop. Go to the search bar at the bottom left of your screen and type Edit power plan. Click on the application from your search. At the bottom of the window, click Change advanced power settings. From here, scroll down to the Battery dropdown menu. Under Critical battery action, make sure On battery: is set to Hibernate, and Plugged in: is set to Do Nothing. Under Critical batter level, make sure On battery: and Plugged in: are both set to 5%. Once all settings have been updated, close all applications and remove the power cord from the laptop. Wait for the laptop battery to drain and wait a few hours. After waiting, plug the power cord back. The battery should now be fully calibrated.
Faulty Battery
Device Won't Charge
The battery will not hold a charge or not power on at all.
Outdated BIOS
Click the following link to the Acer website for device support. Click Menu, then click Drivers and Manuals. Click the BIOS/Firmware tab and download the BIOS. Load the BIOS onto a blank USB drive. Turn off your laptop. Insert the USB containing the BIOS into the laptop. Hold down the FN and Esc at the same time and turn on the laptop. Wit until the power button starts flashing before letting go of the keys. Allow the computer to update the BIOS for 5 minutes. Once this is done, charge the computer fully and it should be working properly.
Charge Cycle Out of Sync
Power down the laptop, remove the battery, and unplug the power cord. Hold down the power button for 2 minutes to drain all remaining charge. Release the button, install the battery, and power up the computer. The laptop should now recognize the battery and begin charging normally.
Faulty Power Jack
You may need to replace the power jack. Learn how to remove and replace the power jack here.
Touchpad Not Working
Touchpad is fully unresponsive.
Touchpad Is Disabled
Hold down the FN key and press F7, or whichever function key with the touchpad icon. If the touchpad has been disabled, this should enable the touchpad.
Outdated Touchpad Driver
Click the following link to the Acer website for device support. Click Menu, then click Drivers and Manuals. Click the Driver tab and download the Touchpad Driver. Go to the start menu, search for Device Manager. Click on the application that shows up in the search results. Go Mice and other pointing devices. Click on your touchpad, go to the Driver tab, and click Update Driver. Select the driver you downloaded earlier, then restart the computer.
Faulty Touchpad
You may need to replace the touchpad. Learn how to remove and replace the touchpad here.
Daniel Mello
Membro da: 10/16/18
258 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,649
