Salta al contenuto principale
Acer Aspire E5-571-58CG Keyboard Replacement
Cosa ti serve
  1. Acer Aspire E5-571-58CG Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire E5-571-58CG Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Keyboard Replacement: passo 2, immagine 1 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 2, immagine 2 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 2, immagine 3 di 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Keyboard Replacement: passo 4, immagine 1 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 4, immagine 2 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 4, immagine 3 di 3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  5. Acer Aspire E5-571-58CG Keyboard Replacement: passo 5, immagine 1 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 5, immagine 2 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 5, immagine 3 di 3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  6. Acer Aspire E5-571-58CG Keyboard Replacement: passo 6, immagine 1 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 6, immagine 2 di 3 Acer Aspire E5-571-58CG Keyboard Replacement: passo 6, immagine 3 di 3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
Conclusione
Matthew Barboza
Membro da: 10/19/18
159 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 459
