Introduzione
Segui questa guida per rimuovere e sostituire l'altoparlante in un iPhone 13 Pro Max.
Cosa ti serve
Spegni il tuo iPhone prima di iniziare lo smontaggio.
Rimuovi le due viti Pentalobe P2 da 6,8 mm dal bordo inferiore dell’iPhone.
Misura 3 mm dalla punta del plettro e segna questa distanza con un pennarello indelebile.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Posiziona strisce sovrapposte di nastro trasparente da pacchi sullo schermo dell'iPhone finché non l'hai coperto tutto.
Se, nei prossimi passi, non riesci a far aderire la ventosa, piega un pezzo di nastro adesivo resistente (come del nastro adesivo americano) come fosse una maniglia e usa quella per sollevare lo schermo.
Attrezzo utilizzato in questo passaggio:Clampy - Anti-Clamp$24.95
Tira la maniglia blu all'indietro per sbloccare i bracci dell'Anti-Clamp.
Fai scorrere i bracci sopra l'estremità sinistra o destra del tuo iPhone.
Posiziona le ventose vicino l'estremità inferiore dell'iPhone, una davanti e una dietro.
Comprimi insieme le ventose per applicare la suzione all'area desiderata.
Appoggia il tuo iPhone su un oggetto resistente prima di continuare, come un libro con la copertina rigida, così che stia parallelo al pavimento senza tenerlo fermo. Questo rende più facile il lavoro nei prossimi passi.
Usa un asciugacapelli per scaldare il bordo inferiore dell'iPhone. Il vetro dovrebbe essere leggermente troppo caldo da toccare.
Aspetta un minuto per dare la possibilità all'adesivo di lasciarsi andare e creare una fessura.
Inserisci un plettro di apertura sotto la scocca di plastica dello schermo quando l'Anti-Clamp crea una fessura abbastanza grande.
Salta i prossimi tre passi.
Usa un asciugacapelli o una pistola termica per scaldare il bordo inferiore dell'iPhone per 90 secondi, o finché lo schermo è leggermente troppo caldo da toccare.
Applica una ventosa alla parte inferiore del telefono, evitando proprio il bordo.
Tira la ventosa con pressione forte e costante per creare una fessura tra lo schermo e la cornice.
Inserisci un plettro di apertura nella fessura sotto la scocca di plastica dello schermo.
Usa un asciugacapelli per scaldare il bordo destro dell'iPhone (quello con il tasto di accensione) per 90 secondi o finché lo schermo è leggermente troppo caldo al tatto.
Fai scorrere il plettro di apertura intorno all'angolo in basso a destra dell'iPhone per separare l'adesivo.
Continua a farlo scorrere lungo il bordo destro dell'iPhone, finché non raggiungi l'angolo in alto a destra.
Lascia il plettro sotto l'angolo in alto a destra, prima di continuare.
Usa un asciugacapelli per scaldare il bordo superiore dell'iPhone per 90 secondi o finché lo schermo è leggermente troppo caldo al tatto.
Fai scorrere il plettro intorno all'angolo superiore destro dell'iPhone per separare l'adesivo in alto.
Lascia il plettro sotto l'angolo in alto a sinistra prima di continuare.
Usa un asciugacapelli per scaldare il bordo sinistro dell'iPhone per 90 secondi o finché lo schermo è leggermente troppo caldo al tatto.
Inserisci un secondo plettro nell'angolo in basso a sinistra dell'iPhone.
Ruota entrambi i plettri nello stesso momento finché non si sganciano le clip del bordo sinistro.
Rimuovi la ventosa dallo schermo.
Ruota l'iPhone, posizionandolo con il bordo destro verso di te.
Apri il tuo iPhone aprendo lo schermo come la copertina posteriore di un libro, partendo dal lato destro.
Appoggia il display contro qualcosa per tenerlo sollevato mentre lavori sul telefono.
Usa un cacciavite Y000 per rimuovere le tre viti da 1,3 mm che fissano la copertura del connettore della batteria.
Usa la punta di uno spudger per scollegare il cavo della batteria, sollevando il connettore direttamente dalla sua presa sulla scheda madre.
Piega leggermente il connettore per allontanarlo dalla scheda logica, per evitare che faccia contatto con la presa e fornisca energia al telefono durante la riparazione.
Usa la punta di uno spudger o un'unghia pulita per sollevare il connettore dello schermo direttamente dalla sua presa sulla scheda madre.
Usa un cacciavite Y000 per rimuovere le due viti da 1,1 mm dalla copertura del connettore dei sensori frontali.
Usa un cacciavite a croce Phillips per rimuovere le due viti rimaste dalla copertura del connettore dei sensori frontali:
Una vite da 1,5 mm
Una vite da 1,8 mm
Usa un cacciavite a croce Phillips per svitare le quattro viti da 1,5 mm che tengono fermo l'altoparlante:
Due viti con la testa più grande
Due viti con la testa più piccola
Fai scorrere un plettro di apertura tra il bordo superiore del Taptic Engine e la striscia adesiva.
Usa le dita per rimuovere la striscia adesiva dall'altoparlante.
Confronta la tua parte di ricambio con quella originale: potrebbe essere necessario il trasferimento di alcuni componenti o la rimozione di protezioni adesive dalla nuova parte prima di installarla.
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Porta i tuoi rifiuti elettronici a un riciclatore certificato R2 o e-Stewards.
La riparazione non è andata come previsto? Prova delle soluzioni di base ai problemi, oppure rivolgiti alla nostra comunità Risposte per trovare aiuto.
Altre 6 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Sara Balestra ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
your website is really useful. Thanks a million :)
Sam, great detail and clear photos but I wanted to see all sides of the loudspeaker and didn’t see them. Could you add more loudspeaker pictures to your post?
Are waterproof seals part of the replacement kit, if not why?
Jim Langston - Replica
I ordered the screwdriver for the 13 ProMax (Y000) as well as the full kit which has this Y000 head. Neither tip works to remove the screws. Any suggestions?
Barbara Nuckles - Replica
