Salta al contenuto principale
Google Pixel 10 Battery Replacement
Cosa ti serve
  1. Google Pixel 10 Battery Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 1
    • Unplug all cables from your phone.
    • Let your Pixel's battery drain completely (until it dies) before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 10 Battery Replacement, Cracked glass preparation: passo 2, immagine 1 di 3 Google Pixel 10 Battery Replacement, Cracked glass preparation: passo 2, immagine 2 di 3 Google Pixel 10 Battery Replacement, Cracked glass preparation: passo 2, immagine 3 di 3
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
    • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
    • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 10 Battery Replacement, Heat the bottom edge: passo 3, immagine 1 di 1
    • Adhesive secures the back glass to the frame. Heating the glass softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the back glass.
    • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 10 Battery Replacement, Apply a suction handle: passo 4, immagine 1 di 2 Google Pixel 10 Battery Replacement, Apply a suction handle: passo 4, immagine 2 di 2
    • Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 10 Battery Replacement, Insert an opening pick: passo 5, immagine 1 di 3 Google Pixel 10 Battery Replacement, Insert an opening pick: passo 5, immagine 2 di 3 Google Pixel 10 Battery Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 10 Battery Replacement, Back glass adhesive information: passo 6, immagine 1 di 3 Google Pixel 10 Battery Replacement, Back glass adhesive information: passo 6, immagine 2 di 3 Google Pixel 10 Battery Replacement, Back glass adhesive information: passo 6, immagine 3 di 3
    • The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
    • A cable connects the back glass near the power button. Don't insert your pick here to avoid damaging the cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 10 Battery Replacement, Separate the bottom edge adhesive: passo 7, immagine 1 di 3 Google Pixel 10 Battery Replacement, Separate the bottom edge adhesive: passo 7, immagine 2 di 3 Google Pixel 10 Battery Replacement, Separate the bottom edge adhesive: passo 7, immagine 3 di 3
    • If the back glass feels stuck at any point when separating the adhesive, apply heat to the area and try again.
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 10 Battery Replacement, Separate the bottom left adhesive: passo 8, immagine 1 di 3 Google Pixel 10 Battery Replacement, Separate the bottom left adhesive: passo 8, immagine 2 di 3 Google Pixel 10 Battery Replacement, Separate the bottom left adhesive: passo 8, immagine 3 di 3
    • Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
    • Leave the pick inserted to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 10 Battery Replacement, Separate the right edge adhesive: passo 9, immagine 1 di 3 Google Pixel 10 Battery Replacement, Separate the right edge adhesive: passo 9, immagine 2 di 3 Google Pixel 10 Battery Replacement, Separate the right edge adhesive: passo 9, immagine 3 di 3
    • Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
    • Leave the pick inserted under the top right corner.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 10 Battery Replacement, Separate the top edge adhesive: passo 10, immagine 1 di 3 Google Pixel 10 Battery Replacement, Separate the top edge adhesive: passo 10, immagine 2 di 3 Google Pixel 10 Battery Replacement, Separate the top edge adhesive: passo 10, immagine 3 di 3
    • Insert a fourth pick under the top right corner.
    • Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
    • Don't try to fully remove the back glass yet, as it's still connected by a ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 10 Battery Replacement, Prop up the back glass: passo 11, immagine 1 di 3 Google Pixel 10 Battery Replacement, Prop up the back glass: passo 11, immagine 2 di 3 Google Pixel 10 Battery Replacement, Prop up the back glass: passo 11, immagine 3 di 3
    • Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
    • If the back glass still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 10 Battery Replacement, Remove the bracket screws: passo 12, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove the bracket screws: passo 12, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the back glass connector bracket.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 10 Battery Replacement: passo 13, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 13, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 13, immagine 3 di 3
    • Use tweezers or your fingers to remove the bracket.
    • Be careful not to scratch or smudge the rear cameras.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 10 Battery Replacement, Disconnect the back glass: passo 14, immagine 1 di 2 Google Pixel 10 Battery Replacement, Disconnect the back glass: passo 14, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 10 Battery Replacement, Remove the back glass: passo 15, immagine 1 di 1
    • Remove the back glass.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 10 Battery Replacement, Remove the motherboard cover screws: passo 16, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove the motherboard cover screws: passo 16, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 10 Battery Replacement, Remove the motherboard cover: passo 17, immagine 1 di 3 Google Pixel 10 Battery Replacement, Remove the motherboard cover: passo 17, immagine 2 di 3 Google Pixel 10 Battery Replacement, Remove the motherboard cover: passo 17, immagine 3 di 3
    • Use a spudger to lift the motherboard cover, then grip the cover and slowly peel the graphite sheet off the battery.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 10 Battery Replacement, Disconnect the battery: passo 18, immagine 1 di 2 Google Pixel 10 Battery Replacement, Disconnect the battery: passo 18, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: passo 19, immagine 1 di 2 Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: passo 19, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the interconnect cable press connector from the bottom right of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 10 Battery Replacement, Remove the USB‑C board cover: passo 20, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove the USB‑C board cover: passo 20, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the USB‑C board cover.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 10 Battery Replacement: passo 21, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 21, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 21, immagine 3 di 3
    • Remove the USB‑C board cover.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: passo 22, immagine 1 di 2 Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: passo 22, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the interconnect cable press connector from the USB‑C board.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 10 Battery Replacement, Remove the interconnect cable: passo 23, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove the interconnect cable: passo 23, immagine 2 di 2
    • Remove the interconnect cable.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 10 Battery Replacement, Peel up the battery pull tab: passo 24, immagine 1 di 3 Google Pixel 10 Battery Replacement, Peel up the battery pull tab: passo 24, immagine 2 di 3 Google Pixel 10 Battery Replacement, Peel up the battery pull tab: passo 24, immagine 3 di 3
    • Use your fingers to peel up the entire battery tab on the left side of the battery, including the skinny strip running along the side.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 10 Battery Replacement, Use finger stalls: passo 25, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    Finger Stalls
    $8.99
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 10 Battery Replacement, Separate the battery adhesive: passo 26, immagine 1 di 3 Google Pixel 10 Battery Replacement, Separate the battery adhesive: passo 26, immagine 2 di 3 Google Pixel 10 Battery Replacement, Separate the battery adhesive: passo 26, immagine 3 di 3
    • Secure the right side of your phone with one hand, and use your free hand to grip the battery pull tab.
    • Make sure your hand securing the phone is mainly pressing on the frame—it shouldn't be covering the battery or pressing down on delicate components.
    • Pull straight up on the tab and apply constant, steady force until the adhesive separates.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 10 Battery Replacement, Remove the battery: passo 27, immagine 1 di 3 Google Pixel 10 Battery Replacement, Remove the battery: passo 27, immagine 2 di 3 Google Pixel 10 Battery Replacement, Remove the battery: passo 27, immagine 3 di 3
    • Grip the battery and slowly pull it away from your phone to peel the plastic sleeve out of the recess.
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 10 Battery Replacement, Disassembly complete: passo 28, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 10 Battery Replacement, Clean the battery recess: passo 29, immagine 1 di 3 Google Pixel 10 Battery Replacement, Clean the battery recess: passo 29, immagine 2 di 3 Google Pixel 10 Battery Replacement, Clean the battery recess: passo 29, immagine 3 di 3
    • Before installing a new battery, check the recess for leftover bits of plastic, as well as adhesive residue from the battery sleeve.
    • If the battery came out cleanly, you can skip this step.
    • Remove any bits of plastic from the old battery sleeve.
    • Use one or two drops high‑concentration (>90%) isopropyl alcohol and a microfiber or lint‑free cloth to clean up any adhesive residue.
    • Be careful not to get alcohol in the cutouts in the battery recess—the bottom of the screen is exposed and may get damaged.
    • Allow the alcohol to dry completely before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 10 Battery Replacement, Remove the battery liner: passo 30, immagine 1 di 1
    • Remove the large, colored liner from the battery to expose the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 10 Battery Replacement, Install the battery: passo 31, immagine 1 di 3 Google Pixel 10 Battery Replacement, Install the battery: passo 31, immagine 2 di 3 Google Pixel 10 Battery Replacement, Install the battery: passo 31, immagine 3 di 3
    • Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
    • Temporarily reconnecting the battery ensures that it's sitting properly in its recess.
    • Lay the battery into its recess and press down firmly to secure it.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 10 Battery Replacement, Disconnect the battery: passo 32, immagine 1 di 2 Google Pixel 10 Battery Replacement, Disconnect the battery: passo 32, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 10 Battery Replacement, Remove any remaining liners: passo 33, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove any remaining liners: passo 33, immagine 2 di 2
    • Use your fingers to remove any remaining stickers or liners from the battery.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 10 Battery Replacement, Install the interconnect cable: passo 34, immagine 1 di 2 Google Pixel 10 Battery Replacement, Install the interconnect cable: passo 34, immagine 2 di 2
    • Lay the interconnect cable back in place, making sure the connectors line up with their sockets.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel 10 Battery Replacement, Connect the interconnect cable: passo 35, immagine 1 di 2 Google Pixel 10 Battery Replacement, Connect the interconnect cable: passo 35, immagine 2 di 2
    • Use your finger to press down and reconnect the interconnect cable press connector to its socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel 10 Battery Replacement: passo 36, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 36, immagine 2 di 2
    • Use your finger to press down and reconnect the interconnect cable press connector to its socket on the USB‑C board.
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel 10 Battery Replacement, Install the USB‑C board cover: passo 37, immagine 1 di 3 Google Pixel 10 Battery Replacement, Install the USB‑C board cover: passo 37, immagine 2 di 3 Google Pixel 10 Battery Replacement, Install the USB‑C board cover: passo 37, immagine 3 di 3
    • Put the USB‑C board cover back into place, sliding the tabs on the top corners under their hooks.
    Chiedi a FixBot
    Aggiungi Commento
  38. Google Pixel 10 Battery Replacement: passo 38, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 38, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the USB‑C board cover.
    Chiedi a FixBot
    Aggiungi Commento
  39. Google Pixel 10 Battery Replacement, Replace the thermal pad: passo 39, immagine 1 di 3 Google Pixel 10 Battery Replacement, Replace the thermal pad: passo 39, immagine 2 di 3 Google Pixel 10 Battery Replacement, Replace the thermal pad: passo 39, immagine 3 di 3
    • Check the condition of the motherboard thermal pad—it'll either be on the bottom edge of the board or on the underside of the cover.
    • If the thermal pad is damaged, follow the next three steps to replace it. Otherwise, skip down three steps.
    • Use the flat end of a spudger to gently scrape up and remove all the old thermal pad from the board and cover.
    Chiedi a FixBot
    Aggiungi Commento
  40. Google Pixel 10 Battery Replacement: passo 40, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 40, immagine 2 di 2
    • Use high‑concentration (>90%) isopropyl alcohol and a coffee filter (or lint‑free cloth) to clean up any thermal pad residue from the board and cover.
    Chiedi a FixBot
    Aggiungi Commento
  41. Google Pixel 10 Battery Replacement: passo 41, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 41, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 41, immagine 3 di 3
    • Remove the larger liner (without cutouts) from the thermal pad.
    • Lay the thermal pad in its square cutout on the underside of the motherboard cover.
    • Press down firmly on the entire surface of the pad with your finger or the flat end of a spudger.
    • Slowly peel up the remaining liner.
    • If the pad starts to peel up with the liner, press it back into place and try again.
    Chiedi a FixBot
    Aggiungi Commento
  42. Google Pixel 10 Battery Replacement, Connect the battery: passo 42, immagine 1 di 1
    • Use your finger to press down and reconnect the battery press connector.
    Chiedi a FixBot
    Aggiungi Commento
  43. Google Pixel 10 Battery Replacement, Check the graphite sheet: passo 43, immagine 1 di 2 Google Pixel 10 Battery Replacement, Check the graphite sheet: passo 43, immagine 2 di 2
    • Check the condition of the graphite sheet attached to the motherboard cover.
    • If the sheet is torn or damaged in any way, peel it up and remove it from the cover—you'll apply a new one in a few steps.
    Chiedi a FixBot
    Aggiungi Commento
  44. Google Pixel 10 Battery Replacement, Install the motherboard cover: passo 44, immagine 1 di 2 Google Pixel 10 Battery Replacement, Install the motherboard cover: passo 44, immagine 2 di 2
    • Put the motherboard cover back in place.
    Chiedi a FixBot
    Aggiungi Commento
  45. Google Pixel 10 Battery Replacement: passo 45, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 45, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  46. Google Pixel 10 Battery Replacement, Prepare the graphite sheet: passo 46, immagine 1 di 1
    • Remove the large clear liner from the graphite sheet, exposing the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  47. Google Pixel 10 Battery Replacement, Install the graphite sheet: passo 47, immagine 1 di 3 Google Pixel 10 Battery Replacement, Install the graphite sheet: passo 47, immagine 2 di 3 Google Pixel 10 Battery Replacement, Install the graphite sheet: passo 47, immagine 3 di 3
    • Lay the graphite sheet into place, so the circular portion is over the battery, and the cutouts on the top edge go into the grooves on the motherboard cover.
    • Use your fingers to press down firmly on the entire surface of the sheet to secure it.
    Chiedi a FixBot
    Aggiungi Commento
  48. Google Pixel 10 Battery Replacement: passo 48, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 48, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 48, immagine 3 di 3
    • Slowly peel up and remove the remaining liner.
    • If the sheet starts to peel up with the liner, press it back into place and try again.
    Chiedi a FixBot
    Aggiungi Commento
  49. Google Pixel 10 Battery Replacement, Remove the old back glass adhesive: passo 49, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove the old back glass adhesive: passo 49, immagine 2 di 2
    • Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
    • Take your time during the next two steps. A clean frame allows replacement adhesive to lay totally flat, ensuring a better seal for your back glass.
    Chiedi a FixBot
    Aggiungi Commento
  50. Google Pixel 10 Battery Replacement: passo 50, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 50, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 50, immagine 3 di 3
    • Removing all the old adhesive can be very tricky and time‑consuming.
    • When removing the back glass adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
    • Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
    • If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
    Chiedi a FixBot
    Aggiungi Commento
  51. Google Pixel 10 Battery Replacement: passo 51, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 51, immagine 2 di 2
    • Wrap a microfiber or lint‑free cloth around a spudger and apply a single drop of high‑concentration (>90%) isopropyl alcohol to the end.
    • Use the spudger to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
    • Let the alcohol dry completely before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  52. Google Pixel 10 Battery Replacement: passo 52, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 52, immagine 2 di 2
    • If you're reinstalling your original back glass, repeat the procedures in the previous two steps on the back glass to clean it.
    Chiedi a FixBot
    Aggiungi Commento
  53. Google Pixel 10 Battery Replacement, Orient the adhesive: passo 53, immagine 1 di 2 Google Pixel 10 Battery Replacement, Orient the adhesive: passo 53, immagine 2 di 2
    • Before applying the back glass adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  54. Google Pixel 10 Battery Replacement: passo 54, immagine 1 di 1
    • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
    Chiedi a FixBot
    Aggiungi Commento
  55. Google Pixel 10 Battery Replacement, Install the back glass adhesive: passo 55, immagine 1 di 3 Google Pixel 10 Battery Replacement, Install the back glass adhesive: passo 55, immagine 2 di 3 Google Pixel 10 Battery Replacement, Install the back glass adhesive: passo 55, immagine 3 di 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  56. Google Pixel 10 Battery Replacement: passo 56, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 56, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 56, immagine 3 di 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
    Chiedi a FixBot
    Aggiungi Commento
  57. Google Pixel 10 Battery Replacement: passo 57, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 57, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 57, immagine 3 di 3
    • Use a spudger to press down firmly on the adhesive to secure it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  58. Google Pixel 10 Battery Replacement, Remove the larger liner: passo 58, immagine 1 di 3 Google Pixel 10 Battery Replacement, Remove the larger liner: passo 58, immagine 2 di 3 Google Pixel 10 Battery Replacement, Remove the larger liner: passo 58, immagine 3 di 3
    • Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
    Chiedi a FixBot
    Aggiungi Commento
  59. Google Pixel 10 Battery Replacement: passo 59, immagine 1 di 3 Google Pixel 10 Battery Replacement: passo 59, immagine 2 di 3 Google Pixel 10 Battery Replacement: passo 59, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  60. Google Pixel 10 Battery Replacement, Remove any liners from the back glass: passo 60, immagine 1 di 2 Google Pixel 10 Battery Replacement, Remove any liners from the back glass: passo 60, immagine 2 di 2
    • If you're installing a new back glass, your replacement will have various protective liners and pieces of tape on the underside that must be removed. Your part may have different pieces in different locations, so make sure to check carefully!
    • Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
    • Usually, you can identify the liners by their pull tabs.
    Chiedi a FixBot
    Aggiungi Commento
  61. Google Pixel 10 Battery Replacement, Prop up the back glass: passo 61, immagine 1 di 1
    • Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
    • Alternatively, you can use a sturdy object (such as a stack of books) to prop up the back glass.
    Chiedi a FixBot
    Aggiungi Commento
  62. Google Pixel 10 Battery Replacement, Connect the back glass cable: passo 62, immagine 1 di 2 Google Pixel 10 Battery Replacement, Connect the back glass cable: passo 62, immagine 2 di 2
    • Use the flat end of a spudger to connect the back glass press connector to its socket.
    • This can be tricky, as there's very little play in the cable. Move the back glass as necessary to help, and don't try to force the connector into place—reposition it and try again.
    Chiedi a FixBot
    Aggiungi Commento
  63. Google Pixel 10 Battery Replacement, Install the bracket: passo 63, immagine 1 di 3 Google Pixel 10 Battery Replacement, Install the bracket: passo 63, immagine 2 di 3 Google Pixel 10 Battery Replacement, Install the bracket: passo 63, immagine 3 di 3
    • Put the cable's bracket back in place, making sure the tab on the right edge goes under its groove.
    Chiedi a FixBot
    Aggiungi Commento
  64. Google Pixel 10 Battery Replacement: passo 64, immagine 1 di 2 Google Pixel 10 Battery Replacement: passo 64, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the bracket.
    • This is a good point to power on your device and test all functions before sealing it up. If you have trouble, try some basic troubleshooting. Be sure to power back down completely before you continue working.
    Chiedi a FixBot
    Aggiungi Commento
  65. Google Pixel 10 Battery Replacement, Remove the remaining liners: passo 65, immagine 1 di 3 Google Pixel 10 Battery Replacement, Remove the remaining liners: passo 65, immagine 2 di 3 Google Pixel 10 Battery Replacement, Remove the remaining liners: passo 65, immagine 3 di 3
    • Remove the remaining liners from the back glass adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  66. Google Pixel 10 Battery Replacement, Install the back glass: passo 66, immagine 1 di 3 Google Pixel 10 Battery Replacement, Install the back glass: passo 66, immagine 2 di 3 Google Pixel 10 Battery Replacement, Install the back glass: passo 66, immagine 3 di 3
    • Flip the back glass onto the frame and press it firmly into place.
    • Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
    • For an even stronger bond, you can stack books on the back glass or use screen vise clamps.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membro da: 09/14/22
191.255 Reputazione
1.204 guide realizzate
2Commenti sulla guida
I am for India India's to delivery
Asif Asif - Rispondi Condividi
Am I missing something or should Step 48 come around the same time as Step 65? Does the removal of the blue film in Step 48 reveal adhesive that's not used until the back glass is put on? Or is there just no adhesive under that blue film in Step 48?
Lord Jair - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 25
Ultimi 7 giorni: 188
Ultimi 30 giorni: 868
Tutti i Tempi: 7,298
