Salta al contenuto principale
Dell XPS 15 9560 Battery  Replacement
Jada Houser
Jada Houser e 8 altri collaboratori
Ultimo aggiornamento il February 25, 2025
20 - 25 minuti
Moderato
Foto Azione
Necessarie Più Immagini
Studente al lavoro
Introduzione
Vai al passo 1
If your Dell XPS 15 9560 fails to charge, the battery dies unusually quick, or the laptop cannot power on without being connected to the charger, the battery may be faulty and in need of a replacement.
A battery is responsible for providing power to the device. Overcharging the laptop by leaving it on the charger after it has reached its maximum charge or exceeding the number of charging cycles the battery can withstand will deteriorate the functionality of the battery.
When examining the your laptop or battery, take care to see if it is swollen. A swollen battery, when punctured, can cause a fire or an explosion. Follow this informative guide on possible signs, causes, and removal.
Ensure that the laptop is turned off and unplugged before beginning.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Battery  Replacement: passo 2, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Battery  Replacement: passo 3, immagine 1 di 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
    I used PH0 screwdriver
    Gerald Dennett - Replica
  4. Dell XPS 15 9560 Battery  Replacement: passo 4, immagine 1 di 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Battery  Replacement, Battery: passo 5, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
    On the Dell XPS 15 9560 that I just did a battery replacement on the battery was not held in by torx screws. It was the larger 97wh battery and was held in by 6 phillips head screws. I was able to get them out with a PH1 bit.
    Nick Hamblen - Replica
    Seconded. In the photo the author isn't even holding a torx driver.
    Gregory Robben -
    Same, by me it was held by 8 philips screws labeled M2X4.
    Sven Oelker - Replica
    Mine is the smaller battery, held in by four PH0 screws. The two towards the middle of the computer in the photo above are not present.
  6. Dell XPS 15 9560 Battery  Replacement: passo 6, immagine 1 di 1
    • Unplug the battery cable.
  7. Dell XPS 15 9560 Battery  Replacement: passo 7, immagine 1 di 1
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 10 persone hanno completato questa guida.
Jada Houser
Membro da: 09/28/21
839 Reputazione
7 Guide realizzate
Clemson, Team 4-5, Hunter Fall 2021 Membro di Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Membri
17 Guide realizzate
1Commento della guida
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 236
Tutti i Tempi: 11,908
