Salta al contenuto principale
Dell XPS 15 9560 Battery Replacement
Cosa ti serve
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Battery  Replacement: passo 2, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Battery  Replacement: passo 3, immagine 1 di 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
    I used PH0 screwdriver
    Gerald Dennett - Replica
  4. Dell XPS 15 9560 Battery  Replacement: passo 4, immagine 1 di 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Battery  Replacement, Battery: passo 5, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
    On the Dell XPS 15 9560 that I just did a battery replacement on the battery was not held in by torx screws. It was the larger 97wh battery and was held in by 6 phillips head screws. I was able to get them out with a PH1 bit.
    Nick Hamblen - Replica
    Seconded. In the photo the author isn't even holding a torx driver.
    Gregory Robben -
    Same, by me it was held by 8 philips screws labeled M2X4.
    Sven Oelker - Replica
    Mine is the smaller battery, held in by four PH0 screws. The two towards the middle of the computer in the photo above are not present.
  6. Dell XPS 15 9560 Battery  Replacement: passo 6, immagine 1 di 1
    • Unplug the battery cable.
  7. Dell XPS 15 9560 Battery  Replacement: passo 7, immagine 1 di 1
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 10 persone hanno completato questa guida.
Jada Houser
Membro da: 09/28/21
839 Reputazione
7 Guide realizzate
Clemson, Team 4-5, Hunter Fall 2021 Membro di Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Membri
17 Guide realizzate
Un commento
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 210
Tutti i Tempi: 11,801
