Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Trigger assembly issue . Not fixing
Ribbon between rubber strip and plastic tool got removed mistakenly while opening controller
Questa è una buona domanda?
Punteggio 0
5 Commenti
Hey there, can you elaborate on the issue that you are having with your controller? Also some pictures could help us better give you advice. Aggiungere immagini ad una domanda
da
can you send a picture?
da
When I was opening my PS3 controller, mistakenly the left side trigger along with rubber strip and plastic tool beneath ribbon got removed. I am not able to attach them
da
Unable to send pics due to complicated process. Can you send a video or online video guidance if possible
da
@divyarthsingh im sure there are plenty of you tube videos on how to disassemble a PS controller you can find. but without pictures of your device we wont be able to help you really.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
iFixit does have a guide for replacing the trigger buttons, along with a guide for removing the wiring for the buttons. If the ribbon cable for the trigger button was damaged/severed, then it will need to be replaced.
Immagine DualShock 3 Grilletti
Guida
Sostituzione grilletti DualShock 3
Difficoltà:
Moderato
15 - 45 minutes
Immagine DualShock 3 Front Shell Cover.
Guida
DualShock 3 Front Shell Cover Replacement
Difficoltà:
Moderato
30 - 45 minutes
Punteggio 1
Aggiungi la tua risposta
Divyarth Singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 64
