Trigger assembly issue . Not fixing
Ribbon between rubber strip and plastic tool got removed mistakenly while opening controller
Questa è una buona domanda?
iFixit does have a guide for replacing the trigger buttons, along with a guide for removing the wiring for the buttons. If the ribbon cable for the trigger button was damaged/severed, then it will need to be replaced.
Guida
Difficoltà:
Moderato
15 - 45 minutes
Guida
Difficoltà:
Moderato
30 - 45 minutes
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 62
5 Commenti
Hey there, can you elaborate on the issue that you are having with your controller? Also some pictures could help us better give you advice. Aggiungere immagini ad una domanda
da Jacob Mehnert
can you send a picture?
da Grant
When I was opening my PS3 controller, mistakenly the left side trigger along with rubber strip and plastic tool beneath ribbon got removed. I am not able to attach them
da Divyarth Singh
Unable to send pics due to complicated process. Can you send a video or online video guidance if possible
da Divyarth Singh
@divyarthsingh im sure there are plenty of you tube videos on how to disassemble a PS controller you can find. but without pictures of your device we wont be able to help you really.
da Logixal
