How to repair leakage in water piepline?
In my outdoor water pipeline there was a leakage and i don't understand how to fix it without changing the whole pipeline??
Questa è una buona domanda?
Punteggio
0
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 44
Hi @mohityogi,
What is the pipe made of, pvc plastic, LDPE poly, copper, G.I. (steel) etc?
Can't you cut out the section where the leak is, and simply replace a small section of the pipe using the appropriate fittings?
da jayeff
The pipe is made of PVC plastic. Can you pls suggest me how can i do this small saction fitting and which are things that are used to do this?
da Mohit Yogi
@mohityogi post some pictures of where and what this damage looks like. PVC is easily fixed, if you are in an area where you can purchase the right repair parts :-) Aggiungere immagini ad una domanda
da oldturkey03
