Salta al contenuto principale
Model number DSC-2100. Sony 12.1 mega-pixel point-and-shoot camera
Why is camera not turn ON
Camera not turning on
Questa è una buona domanda?
Punteggio 1
4 Commenti
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
da
Yes, I already checked it
da
Start problem not running
da
Camera is 1year old please recover
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Punteggio 1
Aggiungi la tua risposta
Priyeshcamera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 40
Tutti i Tempi: 617
