Why is camera not turn ON
Camera not turning on
Questa è una buona domanda?
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 620
4 Commenti
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
da jayeff
Yes, I already checked it
da Priyeshcamera
Start problem not running
da Binod Saw
Camera is 1year old please recover
da Display is on but don't work
