Salta al contenuto principale
Domanda Chiusa
Single out the hardware error
Has anyone information for determining which component is giving trouble?
Situation: PC shuts down and does not power up anymore. Power LED alluminated but all that is active is the fan. How can I confirm that the power button is giving trouble?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Depending on your specific hardware. I would start off with a multimeter and see what the power supplies does. I have had PC's that did this with bad CPU's , CMOS that needed to be cleared as well as as bad Caps and numerous other errors.
da
Which pc? Model no. ?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If your computer is running slower than usual, randomly freezes or restarts, or refuses to boot, see the Motherboard Has a Faulty Capacitor problem page for capacitor troubleshooting help.
Here is a link to a troubleshooting process to help determine your problem. If that doesn't clear your problem please google "PC shuts down and does not power up" for further links that may be a help to you.
http://pcsupport.about.com/od/findbysymp...
Punteggio 3
Parti e strumenti correlati
I have replaced capacitors on several boards to bring them back to life. If any of the capacitors on the board are puffed up on top or are leaking; then that's the problem.
Just read the side of the capacitor to get the type and ohms. I get mine from mcm electronics. They carry a wide selection and good prices.
You un-solder the old one. Note the orientation before removing, that determines the +\- side. Solder in the new one.
That should do it. Most times there was more than one that popped. Check the board carefully. Good luck.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,240
