Salta al contenuto principale
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
Need someone to clean/replace top case w/ keyboard
I spilled water on the MBA 13 Late 2010, and 4 keys dont work. Everything else is fine.
I found a suitable replacement here:http://www.partsquad.com/pc-mac-parts/ma...
Is there anyone that would like to make the repair?
Thanks,
Chris
Questa è una buona domanda?
Punteggio 3
5 Commenti
Shure if you are in Europe.
da
remacberlin is, of course in Berlin, Pollytintop would probably handle it in the UK, rdkl in Chicago, Majesty or Gabe in New Jersey, rj713 in Alabama, OldTurkey in South Texas, Mayer in West Texas, David Iwanicki Central Texas, lemerise in Quebec, Chris Green in Deleware, and ABCellers in Ohio. I'm sure I've left out some others but these folks are regulars around here and are all well respected techs with reputations to maintain.
da
Geez, Mayer - thanks for that extensive list ;-)
da
@kyle @kaykay - a list of possible repair people that are regular contributors to the site would probably be appreciated by both us and the people that may not have the skills to do complicated repairs. Some of these repairs are tough for me.
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Here's the guide for doing this yourself: MacBook Air 13" Late 2010 Upper Case Replacement
It is pretty involved. Are you sure that's all that's wrong with it. iFixit doesn't actually do repairs, they just show you how. But there are some professionals who contribute answers for them. They are not affiliated with iFixit. You can go to Users to find one. Click on their icons to see if they are pros and where they are located. I'm one such person and others may make a post who might be willing to do this for you. You can then email them if you find one you like.
UPDATE 8/25/11
You now hold my record for the farthest away repair I've worked on. Shanghai to Lubbock, TX is quite a distance. I just got in the new Pentalobe screwdrivers from iFixit to do the repair. Do I need to order your part or will you have it shipped to me.
Punteggio 5
2 Commenti:
Excellent decision to sent it to you all the way from Singapore. Your reputation precedes you ......:-)
da
I guess I did it right, it didn't come back and the PayPal went through. It did cost about $55.00 to FedEx one way.
da
Parti e strumenti correlati
Acquista tutti
Questa risposta era destinata originariamente a un'altra domanda.
I think your best bet is to follow the guide to remove the top case. It appears to me that the procedure exposes the back of the keyboard and should allow cleaning to possibly restore full function to your keyboard. While you have it apart please do a complete cleaning of all the parts of the computer. Be advised the author of the guide list this procedure as VERY DIFFICULT. If cleaning fails you may need to replace the top case. Good luck.
Electronics Water Damage
Punteggio 4
6 Commenti:
Hi rj713, I was wondering if I can send you a new top case and my MBA, if you could perform the repair for a fee? Thanks
da
Hi, I'm not set up to do the quality work you require. If you want to talk to a working tech I would suggest you contact either mayer or rdklinc. You will find their email data on by clicking on their avatar. Good luck.
da
+ Thanks rj, I'd be glad to handle it.
da
Hi Mayer, I sent an email to you a few days ago did you get it?
da
I'm not sure, are you Larry?
da
Mostra 1 altro commento
To check out if anything else was damaged please hook it up to an external keyboard.
Punteggio 2
I had this problem (spilled some beer on a 3rd-gen MBA keyboard) and sent it to Richard Mayer (above), who did an excellent job replacing it.
Punteggio 1
1 Commento:
Thanks Sam, it was a pleasure to work with you.
da
I did the same stupid thing, spilled liquid into the keyboard.
Sent it to the Mac dealer for an estimate, they claimed it would be too expensive to repair, since the battery, top case with keyboard, touchpad and possibly other parts needed to be replaced.
Everything except a number of keys on the left side seems to be working 100%. When performing an Apple Hardware Test (pressing D while booting, I had to plug in a USB keyboard to do this since the D key is one of the missing ones), no errors or problems were reported!
I openend the *@$$ thing (using a non Pentalobe screwdriver so I destroyed some of the screws) and cleaned the keyboard and touchpad by running a lot of warm water through them, then let the parts dry overnight. After reassembly no improvement (but not worse either). It seems the keyboard signals pass through the touchpad, and I suspect that some of the IC's on the touchpad has been fried, so I would like to replace this, but the Apple dealer in Norway say they are not allowed to sell spare parts. Any idea where I could find this spare part ?
Punteggio 0
1 Commento:
I got mine from www.Welovemacs.com
da
Aggiungi la tua risposta
apricotscrub sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 6,780
