Power On No display
Its Power on but gives display sometimes and sometimes not give display
Questa è una buona domanda?
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
Parti e strumenti correlati
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 758
1 Commento
maybe a loose cable
da daniel
