Power On No display
Its Power on but gives display sometimes and sometimes not give display
Questa è una buona domanda?
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Ultime 24 ore: 6
Ultimi 7 giorni: 7
Ultimi 30 giorni: 15
Tutti i Tempi: 1,013
1 Commento
maybe a loose cable
da daniel
