Salta al contenuto principale
Repair guides, user manuals, and technical specification for the Acer Aspire 5552. The Acer Aspire 5552 is a budget laptop equipped with a 15.6 inch screen, 250GB of storage, and a DVD writer. A laptop with modest performance for a cheap price.
Power On No display
Its Power on but gives display sometimes and sometimes not give display
Questa è una buona domanda?
Punteggio 0
1 Commento
maybe a loose cable
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
Punteggio 3
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Punteggio 0
Aggiungi la tua risposta
Tech Team sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 752
