Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
Screen dim in half the screen
My phone took water damage and half of the screen is dim even with a new lcd. How can I fix this and if complicated who should I send it to?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
First things first, use the teardown to complete a water damage repair on your phone.
Once you are done with this, you will need toreplace your screen. Keep in mind you will need to transfer your home button and front camera assembly to the new screen. Be careful with the home button as you will LOSE touch ID if this gets broken.
Good luck!
(Here is the part: iPhone 6 Plus Screen)
Immagine Replace a screen compatible with iPhone 6 Plus. Includes all of the small parts preinstalled in the assembly. Features a 5.5 inch 1080 x 1920 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, Home Button Link Cable, and LCD Shield Plate.
Prodotto
$59.99
Immagine iPhone 6 Plus
Guida
Smontaggio iPhone 6 Plus (Italiano)
Difficoltà:
Moderato
Immagine iPhone 6 Plus Gruppo pulsante home
Guida
Sostituzione gruppo pulsante home dell'iPhone 6 Plus
Difficoltà:
Moderato
30 minutes - 1 hour
Immagine iPhone 6 Plus Gruppo fotocamera anteriore e sensore
Guida
Gruppo fotocamera anteriore e sensore dell'iPhone 6 Plus
Difficoltà:
Moderato
1 - 2 hours
Immagine iPhone 6 Plus Schermo
Guida
Sostituzione schermo iPhone 6 Plus
Difficoltà:
Moderato
1 - 2 hours
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Your iPhone has two lines for the backlight. If you had water damage, one of the lines is probably down causing half of the screen to be darker. You will need board repair. Probably a backlight filter. There probably won't be a whole lot of shops willing to work on it, because of the water damage.
Punteggio 1
3 Commenti:
What are lines? I have a similar problem and I am trying to determine if a repair is possible. My entire screen is dim. Does this mean that replacing the display will not make a difference?
da
The lines I am talking about are basically wires printed on the circuit board. They both come from different power controllers. Have you tried checking the accessibility settings and making sure the white level isn't turned down? Also be sure that the zoom function isn't on full screen and set to dim the screen. The backlight isn't completely out is it? A photo may be helpful. I will help as much as I can.
da
@kaniggit49 is correct about getting your logic Board properly cleaned right away...sooner the better! It requires removing the shields from the logic board and using an ultrasonic cleaner with a solution for electronics to properly decontaminate and clean it (Like Branson EC). Then as @carsandiphones explained, the backlight circuit is most likely damaged and in need of Microsoldering (NOT a DIY job). You can Google Repair shops near you to find a reputable shop that does this kind of repair or search the IFIXIT Pros page to find one that offers mail in service. Replacing the LCD would not repair this issue due to a short somewhere in the backlight circuit. Either a bad IC Chip, Coil, Diode, Filter (Fuse), or capacitor has been damaged and you will need an experienced tech to troubleshoot which component(s) will need replaced.
The problem you now face is, even if that issue is repaired...water damaged phones have hundreds of small components on the Logic board which can have corrosion under them and cause future issues. Most repair shops do not like to do this type of repair because of this and there would be no way of offering a warranty and would offer the service mostly for Data recovery and then you could just use it till you couldn't any longer...a hour, day, week, month....year...no telling. Just do not attempt to charge it, power it on and even disconnect the battery if you can. Water on the motherboard should be cleaned as soon as possible to prevent the growth of corrosion and causing further damage.
da
Aggiungi la tua risposta
kevdes4 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 5,016
