Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
20 Domande Visualizza tutte
Spilled Water on PS3 Controller
i spilt water on my ps3 controller and my L2 button stopped working, is there any way to fix it? or do i have to buy a new controller
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
It sounds like there may be a short on the input board. Check out this guide for access. Check for corrosion or other signs of damage. Using some rubbing alcohol, clean the contacts. If there is a large amount of corrosion, you can use some steel wool to try and get rid of it.
Good luck, and let us know how it works out.
Punteggio 2
1 Commento:
Make sure if you use steel wool you clean thoroughly to remove any steel particles. +
da
Try this for water damage: Electronics Water Damage
Punteggio 1
you could get a new L2 peice
Punteggio 0
2 Commenti:
Give more info on the L2 piece. Exactly what is it referring to?
da
its reffering to the L2 button
da
Aggiungi la tua risposta
tim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 8,441
