Salta al contenuto principale
Google Pixel 8 Bottom Speaker Replacement
Cosa ti serve
  1. Google Pixel 8 Bottom Speaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 3 di 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 8 Bottom Speaker Replacement, Mark your opening picks: passo 2, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Mark your opening picks: passo 2, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Mark your opening picks: passo 2, immagine 3 di 3
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 8 Bottom Speaker Replacement, Heat the bottom edge adhesive: passo 3, immagine 1 di 1
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 8 Bottom Speaker Replacement, Secure the Anti-Clamp: passo 4, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Secure the Anti-Clamp: passo 4, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Secure the Anti-Clamp: passo 4, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 8 Bottom Speaker Replacement, Twist the handle: passo 5, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Twist the handle: passo 5, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Twist the handle: passo 5, immagine 3 di 3
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 8 Bottom Speaker Replacement, Insert an opening pick: passo 6, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Insert an opening pick: passo 6, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 8 Bottom Speaker Replacement, Apply a suction cup: passo 7, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Apply a suction cup: passo 7, immagine 2 di 2
    • Apply a suction handle to the center of the screen's bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 8 Bottom Speaker Replacement, Insert an opening pick: passo 8, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Insert an opening pick: passo 8, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Insert an opening pick: passo 8, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 8 Bottom Speaker Replacement, Prevent damage to your phone: passo 9, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Prevent damage to your phone: passo 9, immagine 2 di 2
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 8 Bottom Speaker Replacement, Separate the bottom edge adhesive: passo 10, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Separate the bottom edge adhesive: passo 10, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Separate the bottom edge adhesive: passo 10, immagine 3 di 3
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 8 Bottom Speaker Replacement, Heat the right edge adhesive: passo 11, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 8 Bottom Speaker Replacement, Separate the right edge adhesive: passo 12, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Separate the right edge adhesive: passo 12, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Separate the right edge adhesive: passo 12, immagine 3 di 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 8 Bottom Speaker Replacement, Leave a pick in the bottom left corner: passo 13, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Leave a pick in the bottom left corner: passo 13, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Leave a pick in the bottom left corner: passo 13, immagine 3 di 3
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 8 Bottom Speaker Replacement, Heat the left edge adhesive: passo 14, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 8 Bottom Speaker Replacement, Separate the left edge adhesive: passo 15, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Separate the left edge adhesive: passo 15, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Separate the left edge adhesive: passo 15, immagine 3 di 3
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 8 Bottom Speaker Replacement, Heat the top edge adhesive: passo 16, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 8 Bottom Speaker Replacement, Separate the top edge adhesive: passo 17, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Separate the top edge adhesive: passo 17, immagine 2 di 2
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 8 Bottom Speaker Replacement, Prop up the screen: passo 18, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Prop up the screen: passo 18, immagine 2 di 2
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • Be careful not to strain the screen cable.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 8 Bottom Speaker Replacement, Remove the screen cable cover: passo 19, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Remove the screen cable cover: passo 19, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Remove the screen cable cover: passo 19, immagine 3 di 3
    • Use an opening pick to pry up the upper edge of the screen cable cover.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 8 Bottom Speaker Replacement, Disconnect the screen: passo 20, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Disconnect the screen: passo 20, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Disconnect the screen: passo 20, immagine 3 di 3
    • Insert the point of a spudger under the top left corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 8 Bottom Speaker Replacement, Screen information: passo 21, immagine 1 di 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 8 Bottom Speaker Replacement, Reassembly information: passo 22, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Reassembly information: passo 22, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Reassembly information: passo 22, immagine 3 di 3
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Use the pull tabs to remove the liners covering the front camera cutout, the rear camera pad, the back of the screen, and the perimeter adhesive.
    • Reconnect the screen cable and reinstall its cover.
    • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
    • Firmly press the screen into place on the frame. You should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 8 Bottom Speaker Replacement, Remove the shim: passo 23, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Remove the shim: passo 23, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Remove the shim: passo 23, immagine 3 di 3
    • A plastic shim is lightly adhered to the midframe and bottom speaker.
    • Slide the tip of an opening pick under the plastic shim until you can grip it with tweezers or your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 8 Bottom Speaker Replacement: passo 24, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement: passo 24, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement: passo 24, immagine 3 di 3
    • Use tweezers, or your fingers, to peel off and remove the shim from the midframe and the bottom speaker.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 8 Bottom Speaker Replacement, Unfasten the USB-C port bracket: passo 25, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Unfasten the USB-C port bracket: passo 25, immagine 2 di 2
    FixMat
    $31.41
    • While the Pixel 8 uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx driver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port bracket.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 8 Bottom Speaker Replacement, Remove the USB-C port bracket: passo 26, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Remove the USB-C port bracket: passo 26, immagine 2 di 2
    • Use tweezers, or your fingers, to remove the USB-C port bracket.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 8 Bottom Speaker Replacement, Reassembly information: passo 27, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Reassembly information: passo 27, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Reassembly information: passo 27, immagine 3 di 3
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the clear liner from the shim.
    • Use the markings on the midframe to align the left side of the shim and press it into place.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the blue liner.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 8 Bottom Speaker Replacement, Unfasten the bottom speaker: passo 28, immagine 1 di 2 Google Pixel 8 Bottom Speaker Replacement, Unfasten the bottom speaker: passo 28, immagine 2 di 2
    • Use a T3 Torx driver to remove the 5 mm‑long screw securing the bottom speaker.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 8 Bottom Speaker Replacement, Remove the bottom speaker: passo 29, immagine 1 di 3 Google Pixel 8 Bottom Speaker Replacement, Remove the bottom speaker: passo 29, immagine 2 di 3 Google Pixel 8 Bottom Speaker Replacement, Remove the bottom speaker: passo 29, immagine 3 di 3
    • Insert the point of a spudger between the top right corner of the bottom speaker and the frame.
    • Pry the bottom speaker up with the spudger to dislodge it from its recess.
    • Remove the bottom speaker.
    • During reassembly, insert the edge of the speaker with an black gasket at a downward angle into its recess. Then press the speaker firmly into place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 8 Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
239.576 Reputazione
1.171 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
26.050 guide realizzate
2Commenti sulla guida
If I broke the mesh on the speaker, is it a concern or do I need to take it out and cover it with something?
Azrael - Rispondi Condividi
Do you have instruction on how to replace the bottom microphone and where to buy it ??
Regards
Huw p - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 45
Ultimi 30 giorni: 204
Tutti i Tempi: 4,726
