Introduzione
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the rear camera assembly in your Google Pixel 7 Pro.
This guide was made using the GE2AE model, which features a 5G mmWave antenna. If you have a non-mmWave model, you can still use this guide—just ignore the mmWave antenna steps.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Caution: The Pixel 7 Pro contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You'll need replacement adhesive in order to complete this repair.
Cosa ti serve
Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame.
There are several plastic clips around the whole screen. If your opening pick gets blocked during the screen removal procedure, you've inserted your pick too deep underneath the screen.
Strumento utilizzato in questo passaggio:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your phone.
Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
Squeeze the cups together to apply suction.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the phone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
Insert an opening pick into the gap.
The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a third opening pick underneath the bottom left corner of the screen.
Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick at the top left corner of the screen.
Slide the opening pick along the top edge of the phone to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
Lift the right edge of the screen up and towards the left side of the device, like opening a book.
Rest the screen upside down and parallel to the frame.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
Push the bracket inwards and pry up to release it.
Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the camera.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
When handling your screen, grip it by its edges.
When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
Separate the screen from the phone assembly.
Check that all screws are tightened and there are no loose parts.
Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Follow this guide if you're using custom-cut adhesives for your device.
Follow this guide in case you're using a pre-cut adhesive card.
Use a pair of tweezers to carefully peel the graphite foil off the battery and midframe.
Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the charging port bracket.
Use a pair of tweezers to remove the charging port bracket.
Use a Torx T3 screwdriver to remove the six 5.1 mm-long screws securing the midframe.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the mmWave antenna bracket.
Use a pair of tweezers to remove the mmWave antenna bracket.
Use a spudger to disconnect the mmWave antenna cable by prying the connector straight up from its socket.
Slide an opening pick underneath the mmWave antenna cable starting at its bottom end.
Use the opening pick to separate the mmWave antenna cable from the motherboard.
Use a pair of tweezers to lift the mmWave antenna including its cable out of its recess.
Remove the mmWave antenna assembly.
Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the rear camera assembly.
Use a pair of tweezers to remove the spring at the top left corner of the rear camera assembly.
Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
Fold the cable upwards to free the rear camera assembly.
Use a spudger to disconnect the telephoto camera cable by prying the connector straight up from its socket.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 Pro answers community for help.
Altre 4 persone hanno completato questa guida.
2Commenti sulla guida
Thanks for the guide, I successfully replaced the back cameras with its help.
Unfortunately I damaged the screen somewhere in the screen removal steps, it now has a vertical white stripe of about 1/2 inch at the center; it happened somewhere between step 1 and step 10, I know because while sliding the pick across the right edge I accidently turned the phone back on and saw the stripe for the first time; it is unclear to me exactly what caused the damage.
This is not a medium 30-45 minute repair for a DIY'r. Unless you can get the display screen off quick, then maybe. Its a piece of cake after that.
The screen was nearly impossible to remove. I used their heating pad as instructed. I couldn't get the screen to lift, or the guitar pick to slide in after an hour of applying heat as directed, lifting a little to check if any gap would appear under the screen. Nothing. I resorted to getting frustrated and employing a heat gun. After getting the Pixel's edge almost too hot to touch, I was finally able to see a gap big enough to fit the "guitar pick" through.
I eventually got the whole thing apart, the camera replaced, only to find out I orange and black screened my phone. Dead OLED. I don't plan on doing this again.
