Salta al contenuto principale
Google Pixel 10 Screen Replacement
Cosa ti serve
  1. Google Pixel 10 Screen Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 2 Google Pixel 10 Screen Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 10 Screen Replacement, Cracked glass preparation: passo 2, immagine 1 di 3 Google Pixel 10 Screen Replacement, Cracked glass preparation: passo 2, immagine 2 di 3 Google Pixel 10 Screen Replacement, Cracked glass preparation: passo 2, immagine 3 di 3
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow this step.
    • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
    • Make sure there's a single strip (not overlapping) of tape across the top edge, big enough for a suction cup to fit on.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 10 Screen Replacement, Heat the screen: passo 3, immagine 1 di 3 Google Pixel 10 Screen Replacement, Heat the screen: passo 3, immagine 2 di 3 Google Pixel 10 Screen Replacement, Heat the screen: passo 3, immagine 3 di 3
    • Adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Use a hair dryer, heat gun, or heat pad to heat the entire screen until it's almost too hot to touch.
    • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
    • If you're using a heat pad, set it to 60° C (140° F) and place your phone screen side down for 10 minutes.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 10 Screen Replacement, Apply a suction handle: passo 4, immagine 1 di 2 Google Pixel 10 Screen Replacement, Apply a suction handle: passo 4, immagine 2 di 2
    • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 10 Screen Replacement, Insert an opening pick: passo 5, immagine 1 di 3 Google Pixel 10 Screen Replacement, Insert an opening pick: passo 5, immagine 2 di 3 Google Pixel 10 Screen Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • Inserting an opening pick is difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
    • Insert the tip of an opening pick completely under the screen.
    • When inserting your pick, make sure it's fully underneath the screen, and not only under the glass panel—separating the glass panel from the screen will make removal difficult.
    • Only insert the pick slightly (a few millimeters) to prevent damaging the front camera.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 10 Screen Replacement, Separate the screen adhesive: passo 6, immagine 1 di 3 Google Pixel 10 Screen Replacement, Separate the screen adhesive: passo 6, immagine 2 di 3 Google Pixel 10 Screen Replacement, Separate the screen adhesive: passo 6, immagine 3 di 3
    • Slide the opening pick along the top edge to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 10 Screen Replacement: passo 7, immagine 1 di 3 Google Pixel 10 Screen Replacement: passo 7, immagine 2 di 3 Google Pixel 10 Screen Replacement: passo 7, immagine 3 di 3
    • Continue sliding the pick around the perimeter of the screen until all the adhesive has been separated, leaving picks inserted at the corners to prevent the adhesive from re‑sealing.
    • Reheat the screen at any point if it feels stuck.
    • Don't try to fully remove the screen yet, as it's still connected by a ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 10 Screen Replacement, Prop up the screen: passo 8, immagine 1 di 3 Google Pixel 10 Screen Replacement, Prop up the screen: passo 8, immagine 2 di 3 Google Pixel 10 Screen Replacement, Prop up the screen: passo 8, immagine 3 di 3
    • Flip the top edge of the screen over the bottom edge and use the suction handle (or a sturdy object) to prop it up, so you have access to the screen cable connector.
    • If the screen still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 10 Screen Replacement, Remove the screen cable bracket: passo 9, immagine 1 di 3 Google Pixel 10 Screen Replacement, Remove the screen cable bracket: passo 9, immagine 2 di 3 Google Pixel 10 Screen Replacement, Remove the screen cable bracket: passo 9, immagine 3 di 3
    • Use the flat end of a spudger to push in the clip on the screen cable bracket until it releases.
    • Remove the bracket.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 10 Screen Replacement, Disconnect the screen: passo 10, immagine 1 di 2 Google Pixel 10 Screen Replacement, Disconnect the screen: passo 10, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 10 Screen Replacement, Peel up the screen cable: passo 11, immagine 1 di 2 Google Pixel 10 Screen Replacement, Peel up the screen cable: passo 11, immagine 2 di 2
    • Grip the screen cable just above its connector and gently peel it up.
    • If you're having trouble, use a hair dryer or heat gun to lightly heat the cable.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 10 Screen Replacement, Remove the screen: passo 12, immagine 1 di 1
    • Remove the screen.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 10 Screen Replacement, Clean the frame: passo 13, immagine 1 di 2 Google Pixel 10 Screen Replacement, Clean the frame: passo 13, immagine 2 di 2
    • Before installing adhesive, all the old adhesive must be completely removed from the frame.
    • Take your time during the next two steps. A clean frame allows replacement adhesive to lay totally flat, ensuring a better seal for your new screen.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 10 Screen Replacement: passo 14, immagine 1 di 2 Google Pixel 10 Screen Replacement: passo 14, immagine 2 di 2
    • This step will take some time, as removing the adhesive can be very tricky.
    • Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 10 Screen Replacement: passo 15, immagine 1 di 2 Google Pixel 10 Screen Replacement: passo 15, immagine 2 di 2
    • Wrap a microfiber or lint‑free cloth around a spudger and apply a single drop of high‑concentration (>90%) isopropyl alcohol to the end.
    • Use the spudger to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
    • Let the alcohol dry completely before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 10 Screen Replacement, Orient the adhesive: passo 16, immagine 1 di 3 Google Pixel 10 Screen Replacement, Orient the adhesive: passo 16, immagine 2 di 3 Google Pixel 10 Screen Replacement, Orient the adhesive: passo 16, immagine 3 di 3
    • Before applying any adhesive, check if your replacement screen comes with adhesive pre‑installed around its perimeter. If it does, skip down nine steps. If it doesn't, follow the next nine steps to install new screen adhesive on the frame.
    • Before applying the screen adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use cutouts in the liner and the contours of the adhesive to help visualize how it will lay in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 10 Screen Replacement, Tape the screen cable down: passo 17, immagine 1 di 2 Google Pixel 10 Screen Replacement, Tape the screen cable down: passo 17, immagine 2 di 2
    • The screen cable sticks up off the frame, making it difficult to apply new screen adhesive.
    • Tape the middle of the cable down to the frame, making sure the tape isn't covering anywhere the new adhesive will go.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 10 Screen Replacement, Apply the adhesive: passo 18, immagine 1 di 1
    • Peel up the bottom half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 10 Screen Replacement: passo 19, immagine 1 di 3 Google Pixel 10 Screen Replacement: passo 19, immagine 2 di 3 Google Pixel 10 Screen Replacement: passo 19, immagine 3 di 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • With the larger, clear liner folded towards the top of the phone, lay the exposed bottom edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 10 Screen Replacement: passo 20, immagine 1 di 3 Google Pixel 10 Screen Replacement: passo 20, immagine 2 di 3 Google Pixel 10 Screen Replacement: passo 20, immagine 3 di 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 10 Screen Replacement, Secure the adhesive: passo 21, immagine 1 di 3 Google Pixel 10 Screen Replacement, Secure the adhesive: passo 21, immagine 2 di 3 Google Pixel 10 Screen Replacement, Secure the adhesive: passo 21, immagine 3 di 3
    • Use a spudger to press down firmly on the screen adhesive to secure it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 10 Screen Replacement, Remove the larger liner: passo 22, immagine 1 di 3 Google Pixel 10 Screen Replacement, Remove the larger liner: passo 22, immagine 2 di 3 Google Pixel 10 Screen Replacement, Remove the larger liner: passo 22, immagine 3 di 3
    • Slowly peel up and remove the large colored liner, peeling from the cutout near the top edge.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 10 Screen Replacement: passo 23, immagine 1 di 3 Google Pixel 10 Screen Replacement: passo 23, immagine 2 di 3 Google Pixel 10 Screen Replacement: passo 23, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 10 Screen Replacement, Remove the tape: passo 24, immagine 1 di 1
    • Remove the tape securing the screen cable.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 10 Screen Replacement, Remove the cable adhesive: passo 25, immagine 1 di 2 Google Pixel 10 Screen Replacement, Remove the cable adhesive: passo 25, immagine 2 di 2
    • If your new screen comes with cable adhesive installed just above the connector on the back of the screen, follow this step to remove the old adhesive. Otherwise, skip this step and leave the old adhesive.
    • Use a spudger to gently scrape up and remove the piece of adhesive on the screen cable, near the connector.
    • Be very careful not to damage the cable or its connector. Otherwise, your screen may not work.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 10 Screen Replacement, Check for plastic liners on the screen: passo 26, immagine 1 di 3 Google Pixel 10 Screen Replacement, Check for plastic liners on the screen: passo 26, immagine 2 di 3 Google Pixel 10 Screen Replacement, Check for plastic liners on the screen: passo 26, immagine 3 di 3
    • Your replacement screen has various protective liners and pieces of tape on the underside that must be removed before installation. Your screen may have different pieces in different locations, so make sure to check carefully!
    • Don't remove the screen cable adhesive liner near the bottom of the screen yet—you'll do so after reconnecting the cable.
    • Check around the front facing camera cutout, and near the bottom edge of the screen—you'll remove these in the next step.
    • Usually, you can identify the liners by their pull tabs.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 10 Screen Replacement, Remove screen liners: passo 27, immagine 1 di 3 Google Pixel 10 Screen Replacement, Remove screen liners: passo 27, immagine 2 di 3 Google Pixel 10 Screen Replacement, Remove screen liners: passo 27, immagine 3 di 3
    • The exposed back of the screen is very fragile—even a small scratch can cause damage. Be very careful not to damage the screen during the remaining steps.
    • Use your fingers or tweezers to remove the plastic liners and tape from the back of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 10 Screen Replacement, Prop up the screen: passo 28, immagine 1 di 1
    • Use a sturdy object to prop up the screen so you can reconnect its cable.
    • Make sure the screen is oriented so it's in the proper position when you flip it back down.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 10 Screen Replacement, Connect the screen: passo 29, immagine 1 di 3 Google Pixel 10 Screen Replacement, Connect the screen: passo 29, immagine 2 di 3 Google Pixel 10 Screen Replacement, Connect the screen: passo 29, immagine 3 di 3
    • Loop the screen cable around and use your fingers to reconnect the press connector, pressing on one side first and then the other.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 10 Screen Replacement, Install the bracket: passo 30, immagine 1 di 3 Google Pixel 10 Screen Replacement, Install the bracket: passo 30, immagine 2 di 3 Google Pixel 10 Screen Replacement, Install the bracket: passo 30, immagine 3 di 3
    • Insert the small arm of the screen cable bracket into its slot next to the connector.
    • Press down on the bracket and slide it into place until it clicks, making sure the outer edge hooks into place.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 10 Screen Replacement, Secure the screen cable: passo 31, immagine 1 di 3 Google Pixel 10 Screen Replacement, Secure the screen cable: passo 31, immagine 2 di 3 Google Pixel 10 Screen Replacement, Secure the screen cable: passo 31, immagine 3 di 3
    • If your screen has screen cable adhesive pre‑installed, remove the plastic liner.
    • Press the cable into place above the connector to secure it to the screen.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 10 Screen Replacement, Remove the remaining liners: passo 32, immagine 1 di 3 Google Pixel 10 Screen Replacement, Remove the remaining liners: passo 32, immagine 2 di 3 Google Pixel 10 Screen Replacement, Remove the remaining liners: passo 32, immagine 3 di 3
    • Flip the screen down and hold it above the frame.
    • Remove all remaining liners from the adhesive (either on the frame, or from the underside of the screen).
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 10 Screen Replacement, Install the new screen: passo 33, immagine 1 di 3 Google Pixel 10 Screen Replacement, Install the new screen: passo 33, immagine 2 di 3 Google Pixel 10 Screen Replacement, Install the new screen: passo 33, immagine 3 di 3
    • Firmly push the screen into place on the frame.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 10 Screen Replacement: passo 34, immagine 1 di 3 Google Pixel 10 Screen Replacement: passo 34, immagine 2 di 3 Google Pixel 10 Screen Replacement: passo 34, immagine 3 di 3
    • Hold your phone up and squeeze firmly around the perimeter to strengthen the adhesive bond.
    • For an even stronger bond, you can stack books on the back glass or use screen vise clamps.
    • Before powering on your Pixel for the first time, lay the phone screen-side up on a clean, flat surface. Remove the plastic liner from the screen, making sure nothing touches the phone while you do so (fingers, screen protectors, or cases).
    • Follow any other specific instructions that may be on the screen's adhesive liner.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations on completing your repair!
To calibrate your display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membro da: 09/14/22
191.474 Reputazione
1.204 guide realizzate
2Commenti sulla guida
Finished the screen replacement on Pixel 10. Now the fingerprint sensor doesn't work. Pixel Diagnostic shows {type: "ultrasonic", status: "fail"} I attempted to calibrate the sensor as advised using the google repair tool linked on this page but it states that the Pixel 10 is not a compatible device. Took the device to certified google repair shop Ubreakifix and they said they can't calibrate it. Anyone have luck fixing this?
Michael A - Rispondi Condividi
i have a similar issue, were you able to solve it ?
Julio Manero Iglesias - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 30
Ultimi 7 giorni: 177
Ultimi 30 giorni: 694
Tutti i Tempi: 4,411
