Salta al contenuto principale
Xbox Series X Power Button Board Replacement
Cosa ti serve
  1. Xbox Series X Power Button Board Replacement, Uncover the back panel screws: passo 1, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Uncover the back panel screws: passo 1, immagine 2 di 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Power Button Board Replacement: passo 2, immagine 1 di 3 Xbox Series X Power Button Board Replacement: passo 2, immagine 2 di 3 Xbox Series X Power Button Board Replacement: passo 2, immagine 3 di 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Recommend using a hair dryer to soften the label adhesive.
    Crash - Replica
    Microsoft can void your warranty. They can use whatever excuse if it is sent in because you opened it and you cannot prove you didn’t damage it.
    DirtyD - Replica
    actually those stickers would look better after removal if you use a really sharp blade to slide under it and get a corner up, then use your fingers to peel it, since it wouldn't leave those wrinkles and rough edges.
    Leooooo1061 - Replica
  3. Xbox Series X Power Button Board Replacement, Remove the back panel screws: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $17.96
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Power Button Board Replacement, Unclip the back panel: passo 4, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Unclip the back panel: passo 4, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Unclip the back panel: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Power Button Board Replacement: passo 5, immagine 1 di 2 Xbox Series X Power Button Board Replacement: passo 5, immagine 2 di 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Power Button Board Replacement, Remove the back panel: passo 6, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Remove the back panel: passo 6, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Remove the back panel: passo 6, immagine 3 di 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Power Button Board Replacement: passo 7, immagine 1 di 3 Xbox Series X Power Button Board Replacement: passo 7, immagine 2 di 3 Xbox Series X Power Button Board Replacement: passo 7, immagine 3 di 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Power Button Board Replacement, Remove the fan screws: passo 8, immagine 1 di 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
    are there any 10.5mm wide head screw for the xbox fan for sale because i need a replacement because i accidentally broke mine
    GhostMindX9 - Replica
    If the 10.5 mm screw isn’t budging, use some pliers to loosen it
    Joseph Grant - Replica
  9. Xbox Series X Power Button Board Replacement, Disconnect the fan cable: passo 9, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Disconnect the fan cable: passo 9, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Disconnect the fan cable: passo 9, immagine 3 di 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
    But don’t pull the connectors with tweezers because you will inevitably still damage the cable as you have no grip on the connector and the tweezers will slip.
    Leif DeWolf - Replica
    Tweezers do not work
    Marquis Wylie - Replica
  10. Xbox Series X Power Button Board Replacement, Remove the fan: passo 10, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Remove the fan: passo 10, immagine 2 di 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X Power Button Board Replacement, Unlatch the base: passo 11, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Unlatch the base: passo 11, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Unlatch the base: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Power Button Board Replacement, Twist and remove the base: passo 12, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Twist and remove the base: passo 12, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Twist and remove the base: passo 12, immagine 3 di 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
    had trouble getting the base off, what worked for me is setting the console on the table sitting on the base and turning the whole console while pushing down.
    techy Waterville - Replica
  13. Xbox Series X Power Button Board Replacement, Remove the optical drive screws: passo 13, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Remove the optical drive screws: passo 13, immagine 2 di 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Power Button Board Replacement, Remove the vibration isolator: passo 14, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Remove the vibration isolator: passo 14, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Remove the vibration isolator: passo 14, immagine 3 di 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Power Button Board Replacement, Disconnect the power and data cables: passo 15, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Disconnect the power and data cables: passo 15, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Disconnect the power and data cables: passo 15, immagine 3 di 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
    Once again, DO NOT use tweezers to pull these connectors out. That’s a great way to slip and damage something.
    I managed to get the power connector unplugged, but the data cable just refuses to move. I've used quite a bit of force, and using any more feels like I would damage it. I have no clue on how to get it out safely :(
    Izaac Brånn - Replica
    Try to "walk" the connector out: pry up one side, then the other. Best of luck!
    Carsten Frauenheim -
  16. Xbox Series X Power Button Board Replacement, Remove the optical drive: passo 16, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Remove the optical drive: passo 16, immagine 2 di 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Power Button Board Replacement, Disconnect the USB port cable: passo 17, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Disconnect the USB port cable: passo 17, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Disconnect the USB port cable: passo 17, immagine 3 di 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Power Button Board Replacement: passo 18, immagine 1 di 2 Xbox Series X Power Button Board Replacement: passo 18, immagine 2 di 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
    Connector i-pex Evaflex 5-HD 24 pin
    20952-024e-02
    http://www.i-pex.com/sites/default/files...
    drops206 - Replica
    The silver ribbon cable is glued down to the center chassis, so only pulling on the black plastic pull tab will result in it pulling free from the cable as that tab is only glued to the cable.
    Better to heat the silver ribbon cable's adhesive with a hair dryer, separate the cable from the center chassis, and then pull the cable from the connector using the black plastic pull tab.
    Crash - Replica
  19. Xbox Series X Power Button Board Replacement, Disconnect the power button cable: passo 19, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Disconnect the power button cable: passo 19, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Disconnect the power button cable: passo 19, immagine 3 di 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
    I broke this connector during disassembly. Is there a part number I can use to get a replacement on Mouser or Digikey?
    Peter LeCraw - Replica
    I broke this connector during disassembly too. Where can I get this connector?
    Oscar Cedeño - Replica
    the manufacturer of connectors in series x is I-PEX.  exact part number (as far as I'm not mistaken) 20535-010E-02 EVAFLEX 5-VS.  0.5mm pin spacing (10pin connector). a possible rescue may be to desolder the connector from the switch board and solder it permanently there.
    drops206 - Replica
    How do I purchase this from their website?
    munirbisharat12 -
    I have these connectors. Baycroc@fedtel.net
    Evenson Electronics - Replica
    Would we be able to order them from you directly
    bailey jackson -
    Yes would we be able to order these connectors directly from you?
    Blake Roan -
    XSX NEXUS FPC Socket
    kasynlife -
    There is no black pull tab on mine😬. How am I supposed to pull it safely?
    Karman Wilmot - Replica
  20. Xbox Series X Power Button Board Replacement, Remove the chassis screws: passo 20, immagine 1 di 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Power Button Board Replacement, Peel up the USB port cable: passo 21, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Peel up the USB port cable: passo 21, immagine 2 di 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X Power Button Board Replacement, Remove the center chassis assembly: passo 22, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Remove the center chassis assembly: passo 22, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Remove the center chassis assembly: passo 22, immagine 3 di 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Power Button Board Replacement, Separate the power button cable: passo 23, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Separate the power button cable: passo 23, immagine 2 di 2
    • The power button cable is adhered to the shell with pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the power button cable.
  24. Xbox Series X Power Button Board Replacement: passo 24, immagine 1 di 3 Xbox Series X Power Button Board Replacement: passo 24, immagine 2 di 3 Xbox Series X Power Button Board Replacement: passo 24, immagine 3 di 3
    iFixit Opening Picks (Set of 6)
    • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
    • Use your fingers to peel up the power button cable and fully separate it from the shell.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  25. Xbox Series X Power Button Board Replacement, Remove the power button board screws: passo 25, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Remove the power button board screws: passo 25, immagine 2 di 2
    • Use a T8 Torx driver to remove the four 5.5 mm‑long screws securing the power button board.
  26. Xbox Series X Power Button Board Replacement, Remove the board: passo 26, immagine 1 di 1
    • Remove the power button board.
  27. Xbox Series X Power Button Board Replacement, Separate the cable adhesive: passo 27, immagine 1 di 2 Xbox Series X Power Button Board Replacement, Separate the cable adhesive: passo 27, immagine 2 di 2
    • Check if your replacement power button board comes with a cable. If it doesn't, follow the next two steps to remove and transfer the original cable.
    • Gently slide an opening pick under the board's cable to separate the adhesive securing it.
    • If you're having trouble, heat the cable with an iOpener or hair dryer.
  28. Xbox Series X Power Button Board Replacement, Disconnect the cable: passo 28, immagine 1 di 3 Xbox Series X Power Button Board Replacement, Disconnect the cable: passo 28, immagine 2 di 3 Xbox Series X Power Button Board Replacement, Disconnect the cable: passo 28, immagine 3 di 3
    • Use the pointed end of a spudger to depress the metal tab on the power button cable's board connector.
    • With the metal tab depressed, use your fingers or a pair of tweezers to slide the cable out of its socket.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Spencer Day
Membro da: 09/14/22
119.118 Reputazione
838 Guide realizzate
iFixit Membro di iFixit
Staff
119 Membri
21.725 Guide realizzate
2Commenti sulla guida
Acabo de reparar conector pero funciona el ventilador pero no enciende ayuda
Antonio Moreno - Replica
So if I accidentally geodos strength disconnect the fragile terminal from the motherboard how do I replace it without buying a $400 motherboard?
Zack Taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 184
Tutti i Tempi: 1,277
