Xbox Series X Motherboard Removal (Thermal Paste/Putty)
Introduzione
Vai al passo 1Use this guide to replace the motherboard in an Xbox Series X.
You can also use this guide to reapply thermal paste in your Xbox.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm pancake screw
Two 8.8 mm screws
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
Grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
Lift up the optical drive's vibration isolator to remove it.
Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
Use your fingers to pull up and disconnect the data cable from the optical drive.
Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
Gently peel the taped USB port ribbon cable off of the heatsink.
Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
Lift out the center chassis assembly to remove it from the shell.
Unlatch the chassis strap from the right side of the power supply.
Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
Two 13.1 mm screws
One 35 mm screw
Unlatch and open the lid on the power cable's plastic guide.
Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
Use a T8 Torx driver to remove the nine screws securing the board shield:
Six 8.8 mm black screws
Two 35 mm silver screws
One 13.1 mm silver screw
Disconnect the chassis strap from the locking tabs on either side of the power supply.
Grip and compress the locking tab on the 10-pin power connector.
While compressing the locking tab, lift the connector straight up to disconnect it from the board.
Use a T8 Torx driver to remove the three 35 mm‑long silver screws from the power supply—leave the fourth black screw in place.
Grip the edges of the center chassis (not the power supply) and lift it off of the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
Use the flat end of a spudger to pry up the edges of the metal SSD shield.
Remove the SSD shield.
Use a T8 Torx driver to remove the 5.2 mm screw securing the SSD.
Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
Grip the base of the interconnect cable connector with your fingers.
Depress each side of the connector to unlock the cable locking tabs.
With the locking tabs depressed, grip the edges of the interconnect cable and pull it straight out of the connector to disconnect it.
Remove the interconnect cable.
Use the flat end of a spudger to pry up the edges of the large metal shield in the center of the motherboard.
Use a T8 Torx driver to remove the four 12.3 mm‑long APU tension bracket screws.
Check the condition of the thermal putty—it'll be on the heatsink and/or the motherboard.
If any pieces are damaged or dried out, follow the next four steps to remove and replace them.
If you're only replacing the thermal paste, skip to this step.
Roll the thermal putty into a ball.
Place the thermal putty where the damaged thermal pad was, making sure it's centered over the component—in this case a memory chip.
Optionally, you can use the flat end of a spudger (or an included applicator) to spread the thermal putty over the surface of the component.
Attrezzo utilizzato in questo passaggio:Cotton Swabs$4.99
Apply a few drops of isopropyl alcohol (>90%) to the processor and use a coffee filter or a lint-free cloth to wipe away any residue.
Apply a small bead of thermal paste to the center of the APU.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
