Instant Pot IP-DUO80 V2 LED Display Replacement
Introduzione
Vai al passo 1The LED display is how you communicate with your Instant Pot. This guide will show you how to remove the display from the front of your device.
Cosa ti serve
Open the lid by turning it counter-clockwise and lifting up.
Remove the inner pot.
Pull the power cord out of its slot.
Pull up on the edge of the black plastic base to remove the base.
Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
Pull up on the cn101 connection to detach the LED display from the motherboard.
Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
Pull out the LED display by pulling on it gently.
You say no parts? But I don’t see how you rectified the issue just by removing the LED display. Do you need a replacement LED display?
Altre 7 persone hanno completato questa guida.
2Commenti sulla guida
Where can I get the replacement for the display?
