Salta al contenuto principale
How to Open the Logitech G903
Dominik Schnabelrauch
Dominik Schnabelrauch e 6 altri collaboratori
Ultimo aggiornamento il 18 giu 2024
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to open a Logitech G903 for cleaning or repair.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Open the Logitech G903, Turn off the mouse: passo 1, immagine 1 di 2 How to Open the Logitech G903, Turn off the mouse: passo 1, immagine 2 di 2
    • Before you begin, flip the mouse's power switch into the red OFF position.
  2. How to Open the Logitech G903, Heat the mouse foot: passo 2, immagine 1 di 1
    • If you’re planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and apply it to the bottom mouse foot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage.
  3. How to Open the Logitech G903, Separate the mouse foot adhesive: passo 3, immagine 1 di 3 How to Open the Logitech G903, Separate the mouse foot adhesive: passo 3, immagine 2 di 3 How to Open the Logitech G903, Separate the mouse foot adhesive: passo 3, immagine 3 di 3
    • Slide an opening pick under an edge of the bottom mouse foot.
    • Go slowly, and make sure the pick is underneath both the foot and its adhesive layer if you want to reuse the foot. It's easy to separate the foot from its adhesive.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide the pick under the rest of the foot until you can lift it off the mouse.
    • Remove the foot.
  4. How to Open the Logitech G903, Clean off the old adhesive: passo 4, immagine 1 di 3 How to Open the Logitech G903, Clean off the old adhesive: passo 4, immagine 2 di 3 How to Open the Logitech G903, Clean off the old adhesive: passo 4, immagine 3 di 3
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Peel the adhesive off.
    • Before installing new feet or reinstalling old ones, wipe away any adhesive residue from the mouse with a lint-free cloth and high-concentration isopropyl alcohol.
  5. How to Open the Logitech G903, Remove the pentagonal mouse feet: passo 5, immagine 1 di 2 How to Open the Logitech G903, Remove the pentagonal mouse feet: passo 5, immagine 2 di 2
    • Repeat the previous mouse feet removal procedure and remove the two pentagonal mouse feet on the left and right side.
  6. How to Open the Logitech G903, Heat the Logitech sticker: passo 6, immagine 1 di 1
    • The Logitech sticker at the bottom of the mouse is very heat sensitive and crumbles easily. In case you want to keep that sticker intact apply as little heat as possible and remove the sticker carefully.
    • If you don't want to remove the sticker all the way, you can puncture it with a screwdriver where the two screws are located beneath it. Use this picture to make sure you're hitting the right spots.
    • Heat an iOpener and apply it to the Logitech sticker to loosen its adhesive.
  7. How to Open the Logitech G903, Remove the Logitech sticker: passo 7, immagine 1 di 3 How to Open the Logitech G903, Remove the Logitech sticker: passo 7, immagine 2 di 3 How to Open the Logitech G903, Remove the Logitech sticker: passo 7, immagine 3 di 3
    • Slide an opening pick under an edge of the Logitech sticker.
    • If you want to reuse the sticker, go slowly and avoid tearing or crumbling it.
    • If the sticker feels stuck, apply a little bit more heat before continuing.
    • Slide the pick under the rest of the sticker until you can peel it off the mouse.
    • Remove the sticker.
    You don't need to fully remove this sticker, all you need to do is flip the thinnest part (like till you reach the part like in the photo above), put the screwdriver in, unscrew the screw, take the screw out and stick the sticker back on. Do the same with the other screw and during the assembly.
    Adam “Mavi” Kroupa - Replica
  8. How to Open the Logitech G903, Remove the case screws: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the seven 4.5 mm screws securing the two halves of the mouse together.
    • The top middle screw may be a Torx T5.
    You'll need a T5 bit to remove the seventh top screw.
    Olivier Charbonneau - Replica
    It used to be that on the older models, but on the newer one I just opened it had a Philips for that last one too, just like the guide shows.
    Remy Monsen -
  9. How to Open the Logitech G903, Open the mouse: passo 9, immagine 1 di 3 How to Open the Logitech G903, Open the mouse: passo 9, immagine 2 di 3 How to Open the Logitech G903, Open the mouse: passo 9, immagine 3 di 3
    • Don't completely separate the two halves yet—they're still tethered together by a delicate cable.
    • For better access, open the top half of the mouse in the direction of the rear end.
  10. How to Open the Logitech G903, Open the ZIF connector: passo 10, immagine 1 di 2 How to Open the Logitech G903, Open the ZIF connector: passo 10, immagine 2 di 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable ZIF connector.
  11. How to Open the Logitech G903, Disconnect the interconnect cable: passo 11, immagine 1 di 2 How to Open the Logitech G903, Disconnect the interconnect cable: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of blunt nose tweezers or your fingers to slide the interconnect cable out of its socket.
  12. How to Open the Logitech G903, Disconnect the battery: passo 12, immagine 1 di 3 How to Open the Logitech G903, Disconnect the battery: passo 12, immagine 2 di 3 How to Open the Logitech G903, Disconnect the battery: passo 12, immagine 3 di 3
    • Use a pair of blunt tweezers to grasp the sides of the battery connector.
    • Pull the connector up and out of its socket, gently rocking it back and forth to loosen the clips securing it.
  13. How to Open the Logitech G903, Remove the top half of the mouse: passo 13, immagine 1 di 1
    • Remove the top half of the mouse.
Conclusione
Altre 19 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
121 Membri
20.636 Guide realizzate
1Commento della guida
Would this let me remove the left and right buttons to clean under? Because if there's an easier way to clean this godforsaken design I'd rather start there ;P
CrazineX UnbounD - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 100
Ultimi 30 Giorni: 441
Tutti i Tempi: 29,372
