Salta al contenuto principale
Google Pixel Slate Screen Replacement
Spencer Alonge
Spencer Alonge e 8 altri collaboratori
Ultimo aggiornamento il 21 dic 2021
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to remove and replace the screen from Google Pixel Slate.
A screen replacement is necessary if your screen display is cracked or damaged that can inhibit the view and touchscreen functionality of the device.
Before you start, make sure to completely turn off the power of the phone and disconnect all external power sources.
Please be aware that the replacement of the screen must be done with great care, as you can potentially damage other parts of the device.
Cosa ti serve
Strumenti
Mostra di più…
  1. Google Pixel Slate Screen Replacement, Screen: passo 1, immagine 1 di 3 Google Pixel Slate Screen Replacement, Screen: passo 1, immagine 2 di 3 Google Pixel Slate Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
    The tool and suction does not work for me. The adhesive is too strong.
    beep - Replica
    It’s so easy to crack the screen here. I recommend using heat to soften the bond and avoid cracking the screen. Ideally a heating pad ($$$), but a heat gun or hair dryer also does the trick. I’ve seen a temperature range of 80-90 C (matching specs from a heating pad). I heated a pizza stone to temperature to make a homemade heating pad. That worked to soften the adhesive here.
    beep - Replica
    The adhesive is very strong, and they are not just at the edge. Some of them a little further inside, and be careful not to cut the speak grill.
    Kings Lee - Replica
  2. Google Pixel Slate Screen Replacement: passo 2, immagine 1 di 3 Google Pixel Slate Screen Replacement: passo 2, immagine 2 di 3 Google Pixel Slate Screen Replacement: passo 2, immagine 3 di 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
    Where can I source the screen?
    Brandon Price - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team S2-G5, Maness Spring 2019 Membro di Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Membri
5 Guide realizzate
13Commenti sulla guida
Where did you source the replacement screen? Can we get a link added to the parts list?
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - Replica
me too! the resource replacement link plz!!
gabriela urquidi - Replica
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - Replica
where can i buy a replacement screen? Please tell me/ us.
E. Ö. - Replica
Anyone ever find somewhere to get a replacement screen??
Russell Porter - Replica
The manufacturer won’t sell parts. They keep it to themselves, since they’d rather make money off doing the repair for you. Plus, they won’t trust you. Hope this helps with parts sourcing. I’d check eBay, just because you could potentially get a used one that would do the job.
ayeeeee - Replica
Yep. The screen glued with adhesive strips. Hot air makes screen removing much easier.
Alexey Rybakov - Replica
anybody find out how to get the replacement glass/screen?? google or 3rd party version?
Bradley Collins - Replica
one last time before I dump this tablet, does anyone know where I can get a replacement screen?
Hi @brandondacrib, Unfortunately, we don't have any replacement screens in our store currently. However, you might try sourcing a used Pixel Slate on eBay for the parts. Just make sure to check with the seller to ensure that the screen is working before purchase.
Sarah Westberg -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 5,200
