Salta al contenuto principale
A asus asustek monitor is a work monitor which was released in 2022 it has a led screen built in speakers and it’s the perfect office monitor.
How to fix internal screen damage
Hi this monitor has a broken screen internally how can I fix it and what is broken? Pls help!
Questa è una buona domanda?
Punteggio 1
2 Commenti
What exactly do you mean by "broken"? A lot of people use it to mean not working, or it can indicate physical damage such as cracks in the screen, so it's important we know your definition. Adding a photo would be a big help so we can see what you see.
Aggiungere immagini ad una domanda
da
@dadibrokeit now look at the photo for the. Wiki. Then you will see
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@thecat847 Yup, that's a broken screen. Obviously you'll need a new LED panel. Depending on the size of the monitor, it may or may not be cost-effective to repair. Over a certain size, the cost of a replacement part can easily exceed the price of the entire monitor.
However, there's no way of knowing that without the model number. What's yours?
Punteggio 2
Aggiungi la tua risposta
The cat15 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 128
Tutti i Tempi: 260
