Salta al contenuto principale
Un monitor Asus Asustek è un monitor da lavoro rilasciato nel 2022, dotato di schermo LED e altoparlanti integrati; è il monitor perfetto per l'ufficio.
How to fix internal screen damage
Hi this monitor has a broken screen internally how can I fix it and what is broken? Pls help!
Questa è una buona domanda?
Punteggio 2
2 Commenti
What exactly do you mean by "broken"? A lot of people use it to mean not working, or it can indicate physical damage such as cracks in the screen, so it's important we know your definition. Adding a photo would be a big help so we can see what you see.
Aggiungere immagini ad una domanda
da Condividi
@dadibrokeit now look at the photo for the. Wiki. Then you will see
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
@thecat847 Yup, that's a broken screen. Obviously you'll need a new LED panel. Depending on the size of the monitor, it may or may not be cost-effective to repair. Over a certain size, the cost of a replacement part can easily exceed the price of the entire monitor.
However, there's no way of knowing that without the model number. What's yours?
Punteggio 3
Aggiungi la tua risposta
The cat15 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 60
Tutti i Tempi: 1,406
