Car showing maintenance required
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
@nader79085 yes, that is good. Continue to perform the maintenance according to the mileage of the vehicle.
I am certain that is really not the answer you needed. I somehow think that your question is not quite asking everything you want to know. Consider rephrasing or adding to the question. What is it that you want to know
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 16
Tutti i Tempi: 31
Hi @nader79085,
If you mean that the check engine light is showing, get the vehicle's OBDII port scanned with an appropriate scantool to see what DTC codes have been logged. The code(s) will tell you what the problem is.
da jayeff
