Salta al contenuto principale
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
20 Domande Visualizza tutte
Car showing maintenance required
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @nader79085,
If you mean that the check engine light is showing, get the vehicle's OBDII port scanned with an appropriate scantool to see what DTC codes have been logged. The code(s) will tell you what the problem is.
da
Aggiungi un commento
1 Risposta
@nader79085 yes, that is good. Continue to perform the maintenance according to the mileage of the vehicle.
I am certain that is really not the answer you needed. I somehow think that your question is not quite asking everything you want to know. Consider rephrasing or adding to the question. What is it that you want to know
Punteggio 0
Aggiungi la tua risposta
Nader sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 18
