Failing to run software update
Hi, my desktop rolls back windows 10 updates when I am trying to run updates. How can I solve this problem?
Questa è una buona domanda?
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
Well I will suggest you to checkout the following video it might help you in fixing the issue which you are facing: https://www.youtube.com/watch?v=-SgSFn35...
Thank you very much @gtip for the post. I think it would help for sure but it needs gurus I would say. I don't think I can to do it on my own I am not as tech savvy as this guy in the video. I appreciate.
Try running the Windows Update troubleshooter and check if that fixes the problem or if it shows any error codes when trying to fix it.
Hi @jayeff, the troubleshooter did not help. I had already tried it numerous times.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 60
