How to put off the maintenance light
I have the method of removing one of the battery terminal and replaced after few seconds but it does not work
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Your maintenance light will illuminate when it's time to schedule a service, so it's important to stay up-to-date on your oil changes and tire rotations. But if you take care of your routine maintenance at home, you might need to reset the light manually.
What if your attempt didn't work? Try again. Sometimes it takes a few tries to get the timing right.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 34
Sorry you don’t have enough information about the problem.
Just turning light off is not a fix if cause is not known.
da Helpful Harry
