Salta al contenuto principale
RYOBI Bluetooth Watt Inverter Generator 2020 - 2,300 Starting Watts and 1,800 Running Watts. The model number is RYI2300VNM.
overloading with nothing plugged in
Why is my Ryobi 2300 bta generator all the sudden overloading soon as it's started with nothing plugged in, also I noticed that the display indicates that it's pulling more watts to run the same load that it was previously using less watts to run I have replaced carb, sparkplug oil, fuel filter air cleaner and the problem still present
Questa è una buona domanda?
Punteggio 2
2 Commenti:
Do you have the GENControl app on your phone? It might give more information.
da
@nest2g Yes ,it only displays fuel level watts used and kill switch function there's no diagnostics option
da
Aggiungi un commento
1 Risposta
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
Robert Alexovich sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 342
