Salta al contenuto principale
Generatore inverter Watt Bluetooth RYOBI 2020 - 2.300 Watt di spunto e 1.800 Watt in funzione. Il numero di modello è RYI2300VNM.
overloading with nothing plugged in
Why is my Ryobi 2300 bta generator all the sudden overloading soon as it's started with nothing plugged in, also I noticed that the display indicates that it's pulling more watts to run the same load that it was previously using less watts to run I have replaced carb, sparkplug oil, fuel filter air cleaner and the problem still present
Questa è una buona domanda?
Punteggio 2
2 Commenti:
Do you have the GENControl app on your phone? It might give more information.
da
@nest2g Yes ,it only displays fuel level watts used and kill switch function there's no diagnostics option
da
Aggiungi un commento
2 Risposte
Punteggio 0
Have you figured out any additional information , looks like I have the same issue , id hate to have to tear this thing apart I only used it 4 times
Punteggio 0
Aggiungi la tua risposta
Robert Alexovich sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 34
Tutti i Tempi: 789
