Salta al contenuto principale
A LED bulb 230V is a type of light bulb that uses Light Emitting Diodes (LEDs) as a source of illumination and is designed to operate at a voltage of 230 volts. This type of bulb is commonly used in areas with higher voltage electrical systems, such as in Europe and other parts of the world that use 220-240V AC power.
Led bulb 120wt repair
Led light bulb 💡 repair
Questa è una buona domanda?
Punteggio 4
2 Commenti
Charging LED bulb repair
da
Yes my led bulb is dead
da
Aggiungi un commento
1 Risposta
Risposta più utile
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Aggiungere immagini ad una domanda
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine LED Birne 230V LED
Guida
LED-bulb 230V E27 repair
Difficoltà:
Moderato
30 minutes
Guida
Difficoltà:
Moderato
Punteggio 1
3 Commenti:
Como puedo reparar mi ampolletas Led quemadas?
da
Como puedo arreglar mis ampolletas Led quemadas
da
@victormarcelo the guides in the original answer should help. The LEDs are usually soldered to the circuit board.
@victormarcelo Las guías de la respuesta original deberían ser útiles. Los LED suelen estar soldados a la placa de circuito.
da
Aggiungi la tua risposta
Hamza Jutt sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 23
Tutti i Tempi: 1,262
