Salta al contenuto principale
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Error code is eet?
What does this code mean?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @nancywillman
What is the model number of the washer?
da
Model number is 11045972400
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @nancywillman
That error code is not shown in the tech sheet for your model.
What is happening with the washer? Does it work OK or if not, what doesn't work e.g. fill, wash, dispense detergent, drain, rinse, spin etc?
Go to p.7 in the tech sheet to see the procedure to perform the diagnostic tests and check if any error codes are shown by the tests.
If there are any, then on p.2→p.6 you'll find the error codes and possible causes and checks.
Post back with any results if you need any further assistance.
Punteggio 1
Parti e strumenti popolari
Aggiungi la tua risposta
Nancy Willman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 61
