Salta al contenuto principale
The Panasonic Lumix DMC-G7 is an entry-level mirrorless interchangeable lens camera released in May, 2015. The camera has a 16MP resolution and is capable of 4K video capture. The model numbers are DMC-G7 in most of the world and DMC-G70 in Europe.
None of the back buttons work
Have you found a fix for this? I ran into this exact same problem. Fixed a loose piece in the camera and now the buttons won't work.
Update (10/18/23)
The entire inside element that holds the lens as well as the sensor was loose. So the lens and sensor wiggled around. I took it apart and put in two small screws and that fixed the issue. At work we have 4 G7s, and theyre all slowly giving out.
Questa è una buona domanda?
Punteggio 0
1 Commento:
@joelvanbeek same camera Lumix DMC-G7? What part did you fix?
da
Aggiungi un commento
1 Risposta
@joelvanbeek try the service code on your camera to see if there is an error code. Make sure that after your work on your camera, that both Flex cables are properly re-connected and that the mainboard is free of any corrosion etc. Also make sure that you check the connectors for the flex cables. Remove the cables and then restart them. Check the ends for any tears etc. Here is the SM Panasonic DMC G7 that will help you with the diagnostic as well as the service for your camera. Let us know what you find.
There is of course always a possibility that this is Firmware related, but check the parts etc. first.
Punteggio 0
Preparati per le riparazioni future
Aggiungi la tua risposta
Joel Van Beek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 108
