Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
How to make my screen visible
My phone fell, there is no crack. I can barely see the screen and apps. Its too dim. Please help me
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @cynnerox
Even though there's no surface damage visible, that doesn't mean that the display didn't suffer any internal damage from the phone being dropped.
Here's the ifixit Sostituzione schermo Samsung Galaxy S8 guide that may help.
Once the phone is open you could check that the display flex cable is still securely connected and if so, then you would need to temporarily replace the display and check to see if it worked.
If the replacement also didn't work then there's a problem on the systemboard and further testing would be required to find out what's wrong.
If you decide to replace the display make sure that you get the correct one, (search using the model number for your phone) as there are different displays due to the many S8 variant models made for different phone service providers as the following version list shows:
Versions: G950F (Europe, Global Single-SIM); G950FD (Global Dual-SIM); G950U (USA Unlocked); G950A (AT&T); G950P (Sprint); G950T (T-Mobile); G950V (Verizon); G950R4 (US Cellular); G950W (Canada); G950S/G950K/G950L (South Korea); G9500 (China)
Punteggio 1
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
cyy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 66
