Salta al contenuto principale
Repair and support for ceiling-mounted bladed fans.
My ceiling fan is not working
When I on my fan switch,, the fan is not moving But I checked alot but there is no wire damage, no
Capacitor problem and not making humming sound
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @khirasariya7759,
Did you use an Ohmmeter to check if the fan motor windings were OK and not open circuit, did you check if the switch is working electrically and not just mechanically?
You said "...I checked a lot..." but you didn't specify what you checked, so we don't know what you did and what you didn't check
da
Aggiungi un commento
1 Risposta
Does the fan turn freely with the power off? Have you tried turning the fan with the power on?
Ron
Punteggio 0
Aggiungi la tua risposta
Khirasariya Madhavdas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 141
