Salta al contenuto principale
The Asus ROG Strix GL703VD is a entry level to mid-range gaming notebook released in 2017.
4 Domande Visualizza tutte
"C" and "V" keys not working
My "C" and "V" keys won't work except for when I use CTRL.
So far I have tried uninstalling the keyboard driver
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @harlannohava
Long shot maybe but try running a sfc /scannow command and check if that finds anything and if it fixes the problem.
Note: Yes there is a space between the sfc and the / character in the command.
Punteggio 2
2 Commenti:
I didn't even have to run the prompt, I went to type the c in sfc without thinking and it registered properly and both keys worked fine after that. Thank you for your help
da
@harlannohava
All good.
I would run the command anyway just in case.
It is a test that check that all the Windows system files are all OK and fixes them if they're not.
Cheers
da
Aggiungi la tua risposta
Harlan Nohava sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 36
Tutti i Tempi: 638
