"C" and "V" keys not working
My "C" and "V" keys won't work except for when I use CTRL.
So far I have tried uninstalling the keyboard driver
Questa è una buona domanda?
Long shot maybe but try running a sfc /scannow command and check if that finds anything and if it fixes the problem.
Note: Yes there is a space between the sfc and the / character in the command.
I didn't even have to run the prompt, I went to type the c in sfc without thinking and it registered properly and both keys worked fine after that. Thank you for your help
All good.
I would run the command anyway just in case.
It is a test that check that all the Windows system files are all OK and fixes them if they're not.
Cheers
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 44
Tutti i Tempi: 655
