Why is wifi not working
When i switch on wifi, it does not show available routers & it does not access any wifi connection
Questa è una buona domanda?
Hi,
Try using the phone's WiFi as close as possible to your network router i.e. <10cm and check if it detects the networks and connects to it.
If it does then it may be a loose antenna problem.
Here's an image of the phone taken from a teardown video that shows the antenna connections at both ends of the phone.
(click on image)
If it still doesn't work it may be a problem on the systemboard. Here's an image of the no BT/WiFi troubleshooting flowchart that may help.
(click on image)
Parti & Attrezzi Popolari
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 403
2 Commenti
WiFi not work
=== Update (05/11/24) ===
Samsung A10 WiFi not work
da Nauman rajput bhtti
