Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
23 Domande Visualizza tutte
How do I fix a loose charging port without replacement?
The charging cable was pulled at an angle and it wasn't removed properly. Now when a charging cable is inserted, it goes in but there is no audible click and is loosely fitting. Is there a way to fix this without a port replacement? Is there a way to bend something in the connector so it grips the lightning plug more?
I think it's the wings inside of the lighting plug that are loose but is there a way to bend it inward without a device disassembly? I have a photo of what I am referring to below.
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
4 Risposte
Risposta Più Utile
Hi
You to use a pair of fine tip tweezers to clean out the charging port as this can cause the charger not to sit right
As for the metal pins you mentioned you could try and bend them out with tweezers but I don’t recommend it as you could damage the port further and it might be more that the port is deformed rather than a bent component
Apart from that I would replace the port as they aren’t that hard and very inexpensive on sites like eBay
Hopefully this helps
Any questions please ask
Punteggio 2
This will help you
https://howtofixgadgets.com/iphone-charg...
I was also having the issue but i got a solution, That’s to clean my charging port i cleaned it with a brush and now my problem is thankfully solved. In apple charging port replacement cost is 10 - 20 dollars.
Punteggio 2
Replace the port, once it’s damaged it’ll never be the same. Easy enough to replace.
Punteggio 1
I recommend Getting A Volta Charger,
And putting the port adapter in the port forever Via Super glue or tape
Part: https://www.voltacharger.com/products/vo...
But Keep in mind @hellomacos 's answer is more practical,
And you won't have wired headphones anymore
Immagine Custom cut rolls of Tesa 61395 double-sided tape for repair.
Prodotto
Tesa 61395 Tape
$5.99
Punteggio 0
2 Commenti:
Please don’t superglue your phone. It’s much easier and cleaner to change the port. Loads of posts and videos on how to replace it. 👍
da
If the charging port on your device has been damaged and is no longer gripping the charging cable properly, it is possible that the port may need to be replaced. Attempting to bend something in the connector or otherwise fix it yourself may cause further damage to the port or the cable, and may not solve the problem.
da
Aggiungi la tua risposta
jimmysofat6864 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 90
Ultimi 30 Giorni: 255
Tutti i Tempi: 13,791
