What is causing this?
Hi recently my air filter started acting weird,
The lights are ever so slightly lit when pressing buttons it makes light get brighter and when released it goes back,
The only fix i found is unplug it and plug it into another slot,
Whats happening with this?
Questa è una buona domanda?
2 Commenti
Hi @beanman56 ,
Is the unit running in auto mode?
If so, do the lights go out completely if you block the light sensor (between the mode and timer buttons)?
Does the problem only occur when using the same power outlet? You said "The only fix i found is unplug it and plug it into another slot,..." so was wondering if it then occurred in the new outlet also or only if you had switched it back to the first one
da jayeff Condividi
@andrewsawesome - Not really
@jayeff - its in auto mode and i don't think so, i can switch the outlet back to the first one
da Ben Capehart Condividi
