Salta al contenuto principale
10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
I submerged my tablet in water how to repair
I dropped my tablet in the tub. I did the rice thing and it still will not charge or show anything on the screen
Questa è una buona domanda?
Punteggio 1
1 Commento
Thank you I will post my results
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @sexydrummerman
The water causes corrosion and provides circuit paths for the electricity which were not in the tablet’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Rice does not fix the problem Rice is for dinner, not repair
First do not try to charge or to turn on your tablet and then remove the battery as soon as possible from the tablet to minimize any further damage.
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible, do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there also. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the tablet might possibly work correctly again.
Here is a link to the ifixit Samsung Galaxy Tab 10.1 guides for repairing your tablet that may help.
If this process seems too daunting, take your tablet to a reputable, professional mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself.
Punteggio 1
Aggiungi la tua risposta
ben ford sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 20
Ultimi 30 giorni: 85
Tutti i Tempi: 7,183
